gear ratio question? - S-10 Forum
post #1 of 9 Old 12-10-2008, 09:34 PM Thread Starter
millertime21's Avatar
User is: millertime21 is offline
I have a 1999 s10 xtreme ext. cab. It has the 2.2L, auto, 4.10 gear. I know switching to a 3.73 would make it more of a dog, but would the difference in gas mileage on the highway be worth it? I couldn't tell you what it gets right now because I don't ever drive it. But in January I will be getting a new job that will require me to drive an hour to work so the blazer will be retired as the dd and replaced with the xtreme. I also plan on doing CAI, cat-back exhaust, pulleys, e-fan, and computer tune. So what do you think, would it be worth switching to a 3.73 gear?
1996 Blazer LT 4x4
2" PA Body lift 1.5" shackles/ AAL/ 1.5" T-bar''s cranked
32" BFG A/T Ford 8.8" rear end (4.10)
Brute Force CAI 2.5" stainlesssteel magnaflowcatback
Taurus e-fan Wait4me Tune
Underdrive pulleys
post #2 of 9 Old 12-10-2008, 09:43 PM
Local Tech
ls1s10onair's Avatar
User is: ls1s10onair is offline
Re: gear ratio question?
ehh..... probably not by very much..... yes, it would lower ur rpm's at highway speeds in top gear, but like i said, not by much...... imo, the 2.2 has so little to begin with..... why would you make it slower? especially if ur gonna spend money to make it quicker later?
2004 Commemorative Edition Corvette
2014 Lexus IS350 F-Sport
post #3 of 9 Old 12-10-2008, 09:47 PM
1996_s10_2.2's Avatar
User is: 1996_s10_2.2 is offline
ya i agree i have a s10 with the 4.10 gears and its still slower then all get out lol id leave it cause idk if it would help maybe 1 or 2 mpgs im guessing
1996 s10 2.2 bored .30 over with new rods and crank eagle pistons and felpro gasket set e-fan mod also its a long bed with 20' rims
post #4 of 9 Old 12-10-2008, 09:56 PM Thread Starter
The other mods are ment to help with mpg, not trying to make it fast. lol... But if I could pick up 2mpg or more I think it would be worth it. I realize these trucks are already very slow in stock form, but thats why I have my trans am if I want to go fast. The s10 is just needed to be a reliable dd with the best gas mileage I can get out of it.
1996 Blazer LT 4x4
Underdrive pulleys
post #5 of 9 Old 12-10-2008, 10:01 PM
Local Tech
i understand ur point, but its not worth it imo...... even if you do the job yourself, and leave everything else alone.... a gear set is about $180 give or take, plus gear oil, cover gasket..... figure $200.... how many miles would you have to drive to have that even pay for itself?
post #6 of 9 Old 12-10-2008, 10:08 PM
forum idiot
orangesonoma's Avatar
i think it would help but you would be giving it more gas to go faster since it will be slower...and that would mean less mpg
Brian
orangesonoma is offline
post #7 of 9 Old 12-10-2008, 10:10 PM
Forum Dictator
What?'s Avatar
User is: What? is offline
You need more mods to compensate the ratio change, then that's where different gearing will help you on highway mainly and city, rather improve some mpg on highway and decrease in city
R.I.P. Grant ('82-'02), BagNDragS10 ('80-'06), Loenuff ('66-'07), Terryl ('57-'09) Gearstix ('93-'10), Gimp ('84-'16)
If you have any problem, issue, thread/post change, request. Feel free to PM me.
What? is offline
post #8 of 9 Old 12-11-2008, 08:08 PM Thread Starter
Thanks for the help!
1996 Blazer LT 4x4
Underdrive pulleys
post #9 of 9 Old 12-11-2008, 08:20 PM
built for stangs
slownlo's Avatar
User is: slownlo is offline
if your looking to get better mpg. You may laugh at me but it works. look into hho/brown gas/hydrogen. If you know how to work on cars you could install one of these systems and get some serious savings. I have a tutu for a daily driver and after seeing the mpg my buddy is getting with a crappy system I am starting to buy the parts to do mine. I will post a thread once I finish it in a couple weeks. i am looking to get about 45 mpg. right now i get 30. THese system are no joke once you get it tuned you can get some serious mpg. CHeck out fuel-saver.com
355 4 bolt main, eagle cast steel crank, eagle esp rods, 10.5:1, crane .473/488 hydraulic cam, Vortec heads with three angle job 2.02/1.6, professional products manifold, 850 carb shop carb, msd pro billet, msd 6al, holley black pump, holley regulator, be cool electric fans tci 3000 stall convertor, Turbo 350, 373 posi weld prostars with MT et streets.
slownlo is offline
