Fuel pump not buzzing - S-10 Forum
post #1 of 11 Old 03-06-2005, 04:53 PM Thread Starter
NoMoreNoma
PnZrFsT's Avatar
User is: PnZrFsT is offline
Send a message via AIM to PnZrFsT
I just rewired most of my truck due to an small wiring fire. After the fire was out and work was started to fix the wires, the fuel pump would buzz when the key was turned forward but now that I replaced the wiring (the section that the heater is on) the fuel pump doesn't buzz, and I don't hear a relay click over. I never touched the section that the pump was on, so I don't know how I could have messed it up. Is there any ways I can check if voltage is getting to the pump without removing the bed?
Bodydropped and Destroyed
PnZrFsT is offline
post #2 of 11 Old 03-06-2005, 06:47 PM
Hello there!
truckinjeff's Avatar
User is: truckinjeff is offline
Send a message via AIM to truckinjeff
Re: Fuel pump not buzzing
Should be a harness running from the fuel tank to the front of the truck. I forget which wire runs the pump, but i'm sure somebody can answer that.
BTW have you tried starting the engine?
Jeff - 96 Sonoma, 2.2 L, auto
Certified 18 Wheeler mechanic.
post #3 of 11 Old 03-06-2005, 08:43 PM Thread Starter
NoMoreNoma
PnZrFsT's Avatar
yea, i've tried to start it. It cranks, but no fuel is getting to the motor to turn it over. I'm gonna try and trace the wires back tomorrow
PnZrFsT is offline
post #4 of 11 Old 03-06-2005, 08:51 PM
3dme's Avatar
User is: 3dme is offline
there is a red wire on the driver side corner by the fire wall with a square white connector, run a jumper wire from the battery positive to the wire and should activate the fuel pump, if not the pump is bad if it does replace the relay in the glove box
3dme is offline
post #5 of 11 Old 03-06-2005, 10:05 PM
Zeeke98's Avatar
User is: Zeeke98 is offline
Check the ground on the drivers side rear framerail also. If that broke or is corroded it may not work. I thought mine died when I tore it apart to repaint it until I found on here about the ground on the frame. If you rewired any other grounds, check those as well.
Wade
03 Chevy S10 Blazer 2 door 2wd Cherry Red Metallic, 3/3 Belltech drop, 18" Ridler 695 18x8 wheels with Pirelli 235/50/18 tires, SS mirrors, Bravada front clip, 6000K low/4300K high HIDs, smokey red tails, Spectre cold air intake, Hypertech programmer, Cherry Bomb turbo w/turndown, Envoy door panels and handles
02 Camaro SS SLP 345HP Black 6 speed T tops
85 Camaro IROC Z28 Silver 305 TPI Auto T tops
Zeeke98 is offline
post #6 of 11 Old 03-07-2005, 03:00 PM Thread Starter
NoMoreNoma
PnZrFsT's Avatar
Thanks guys, I'll check both of those out
PnZrFsT is offline
post #7 of 11 Old 03-07-2005, 03:27 PM Thread Starter
NoMoreNoma
PnZrFsT's Avatar
Well, the ground was good, and the pump didn't buzz, I'm gonna pull the bed off
PnZrFsT is offline
post #8 of 11 Old 03-07-2005, 05:41 PM Thread Starter
NoMoreNoma
PnZrFsT's Avatar
ok, I took the bed off and put a meter on the pins of the fuel pump connector. At no time is the pump getting any voltage. When the key is turned forward where fuel pump would normally prime, no voltage is found. I traced back the section of wires that the pump is on, and found that its basically a straight shot back to the fuse box. Are there any suggestions of what to do next? Could the ECU be the problem?
PnZrFsT is offline
post #9 of 11 Old 03-08-2005, 01:38 AM
Pushrod for life!
pare_john's Avatar
User is: pare_john is offline
Send a message via AIM to pare_john Send a message via MSN to pare_john
have you checked the relay?
1992 Chevy S10, 3.1L V6 5 speed. Bored .40 over, 272 crane cam, heads ported,polished,plained. Decked block. Port matched intake.
Valve job. High compression pistons. Roller rockers. AFPR. Compression 9.5/1. 3.43 rearend. 2/2 drop. Taurus E-Fan
www.s-series.org
post #10 of 11 Old 03-08-2005, 07:56 AM Thread Starter
NoMoreNoma
PnZrFsT's Avatar
Yea, I replaced it
PnZrFsT is offline
post #11 of 11 Old 03-09-2005, 07:47 PM Thread Starter
NoMoreNoma
PnZrFsT's Avatar
The damn thing still isn't running
PnZrFsT is offline
