Estimate on a repair? - S-10 Forum
post #1 of 16 Old 01-12-2010, 06:58 PM Thread Starter
User is: djroofus is offline
Hey guys i got a 98 s10 2.2 5spd and the slave cylinder is shot. Its way to cold for me to do it on the ground so i was gonna have someone do it with a lift and whatnot. Whats the estimated time to do this job? what would you charge to do the job? thanks guys
djroofus is offline
post #2 of 16 Old 01-12-2010, 08:13 PM
F.ound O.n R.oad D.ead
PussyLiquor's Avatar
User is: PussyLiquor is offline
Re: Estimate on a repair?
i have a new slave cylinder laying around..
but the slave itself is 50-70 and as far as labor goes idk..
but its fairly easy to install
1 hose
2 bolts
and unhook the slave
post #3 of 16 Old 01-12-2010, 08:43 PM
Chevy ridin' HIGH
PopWrestler32's Avatar
User is: PopWrestler32 is offline
i would buy a new one... go to a buddies house and use his garage, if you had an awesome buddy thats dad owns a tow business you'd be set..
2001 zr2 s10! - SOLD =D
2009 cbr600rr - Wheelie Addicted
2005 2500HD 6.0 Gas on 40s. Tricked Out.
post #4 of 16 Old 01-12-2010, 08:45 PM
always something new
S10dude's Avatar
User is: S10dude is offline
isn't it inside the bell housing ?...on 98+
All truck pics
S10dude is offline
post #5 of 16 Old 01-12-2010, 08:56 PM
Tech Mod
beandip's Avatar
User is: beandip is offline
yup. 94-97 were just bolted on the outside.
my guess is maybe 2-400 to do the job
depends on the shop rate too.
-Jonathan
2009 Harley Nightrain
beandip is offline
post #6 of 16 Old 01-12-2010, 09:26 PM Thread Starter
Damn i almost got excited with everyone sayin just unbolt it lol. DAMN YOU BEARER OF BAD NEWS lol jk. ok sounds good. ill have to find someone
djroofus is offline
post #7 of 16 Old 01-12-2010, 11:31 PM
Tech Mod
beandip's Avatar
also it might be in your best intrerest if you get the clutch done while your at it so you wont have to go back in there again just to change it out if you can spare the cash. depends on how many miles you have on the clutch though...
-Jonathan
beandip is offline
post #8 of 16 Old 01-13-2010, 05:37 PM Thread Starter
the truck has 66k
djroofus is offline
post #9 of 16 Old 01-13-2010, 06:05 PM
Works too much!
laydout97's Avatar
User is: laydout97 is offline
The slave cylinder is on the inside of a 96+. I think in 96, they went to the nv1500. As cheap as these trucks are made nowadays, it wouldn't hurt to replace it.
92 4.3/700r4 315k- ole red
2011 altima- daily ride
post #10 of 16 Old 01-13-2010, 08:06 PM
User is: SNRusnak is offline
my 97 has an internal slave. It is expensive because of the labor, many shops nowadays charge upwards of $75 an hr and expect it to take at least 4 hours maybe 6 or so, alot of people say its a tough job, and it is, but it isn't really all that bad. I took mine apart last weekend it took me two days (noon to 6), but it was about 25 degrees out, I broke a tool, and I know if i did it again I could do it in about 2-4 hours. I will be putting everything back in this weekend, should take less than a day. btw you should replace/resurface(recommend replace) the flywheel, get the clutch kit, and the slave at the same time. If you do just the clutch the slave will come back to bite you in the ars. I bought the slave for $70, clutch kit for $150, and flywheel for $60, all perfection brand, and comes with everything you need. I also am replacing the master and line ($150 from gm) and changing the gearbox fluid ($18 a quart x 2 quarts)...is this worth it for a 97...lol...I did it in the freezing cold you can too!!! haha. good luck either way.
SNRusnak is offline
post #11 of 16 Old 01-13-2010, 09:43 PM
Chevy ridin' HIGH
yeah man its not hard.... it just takes patience. and the hardest part, is either getting the 2 bolts out the top or moving the trans by yo self
post #12 of 16 Old 01-15-2010, 07:20 AM Thread Starter
well i got the truck goin and onto flat ground. bled it..now i have a clutch. im going to use a vacuum bleeder and replace the fluid because its black and nasty. Then ill just save up for a clutch, flywheel and slave.
djroofus is offline
post #13 of 16 Old 01-15-2010, 12:06 PM
NOT AN S10
tg900's Avatar
User is: tg900 is offline
Send a message via AIM to tg900
I think I'm confusing myself. Which cylinder is the one that is in back of the clutch pedal?
Originally Posted by hedgehog View Post
..... I know the truck better than my wife and have also found it to be more dependable than my wife.
ELTC NEPA
tg900 is offline
post #14 of 16 Old 01-15-2010, 07:56 PM
GOT LN2
t-scene's Avatar
User is: t-scene is offline
GM service manual calls for 4.5 hours labor
: 98 LS 2.2L AUTO : K&N INTAKE : DYNOMAX SUPER TURBO MUFFLER : MAGNAFLOW CONVERTER : 8.5MM MSD SUPER CONDUCTORS : MSD BLASTER COILS : ASP UNDERDRIVE PULLEYS :
: 95 LS 2.2L 5SPD : NEW STYLE ZQ8 WHEELS : MAGNAFLOW CONVERTER : MAGNAFLOW MUFFLER :
t-scene is offline
post #15 of 16 Old 01-16-2010, 12:16 AM
the master cylinder is the one behind the clutch pedal on the firewall, then there's the line that runs to the slave either internal or external. I think you can find cheaper clutches on ebay and what not. I chose to just stick with one brand all from the same store(my dad split the cost).
SNRusnak is offline
post #16 of 16 Old 01-22-2011, 04:02 AM
User is: clarkperez2334 is offline
i purchase mine on the south. If you do just the clutch the slave will come back to bite you in the ars. Auto Repair Estimates can help you manage your budget for repairs.
