Electric fan help - S-10 Forum
post #1 of 15 Old 04-19-2017, 10:23 AM Thread Starter
RGJ
RGJ's Avatar
User is: RGJ is offline
Electric fan help
hey all,
while waiting for some components for my fuel system, Im moving on with the next item on the mod list.
Im about to install a electric fan and I have a few questions. opinions welcome too
mount on the front or back of the radiator?
wire it up for push or pull?
where can I find a spot on motor to bolt my new thermostat in?
friendly regards,
Ryan
A truck is just a truck, but not mine
RGJ is offline
post #2 of 15 Old 04-19-2017, 11:38 AM
oldeerslayer's Avatar
User is: oldeerslayer is online now
Re: Electric fan help
Engine side of the radiator with a shroud is the best. What kind of thermostat are you talking about? Is it part of a controller kit?
post #3 of 15 Old 04-19-2017, 11:43 AM Thread Starter
RGJ
RGJ's Avatar
my original idea was to put them on the front wired to push, to keep more space under the hood.
yess the thermostat is part of a controller kit, switches on at 185 and off at 170.
friendly regards,
Ryan
RGJ is offline
post #4 of 15 Old 04-19-2017, 01:10 PM
jayyk31's Avatar
User is: jayyk31 is offline
I used a fixed thermostat 185 on 195 off and tee'd off the temp sender pipe. I also agree mount them engine side for pullers. There is still plenty of room. I have the dual fan dual speed Ford Contour fans and they fit like a glove and work excellent.
- '92 S10 Extended Cab 2.8 5 speed: new daily driver.
http://www.s10forum.com/forum/f135/m...d-92-a-776930/
-2000 RCSB 2.2 5 speed. Cam swap, Roller rockers, etc... previous DD
:Project '89 S10 Extended Cab 408 LSX, T56 Magnum
Build thread-
http://www.s10forum.com/forum/f213/l...56-n-a-665850/
jayyk31 is offline
post #5 of 15 Old 04-19-2017, 02:09 PM
I don't feel tardy
joedoh's Avatar
User is: joedoh is offline
the reason why the back side (a puller) is better than the front side (pusher) is because the fan is only used in low speed or stopped traffic situations, at speed the airflow through the radiator is higher than the fan could provide, and mounting it on the front side blocks airflow. lots of cars and trucks have an electric fan on the front because it is acting more on the ac condensor than the radiator, more have them pulling on the back side though.
my 41 chevy S10 swap 4.3 auto Fenixhttp://www.s10forum.com/forum/f30/19...on-s10-789361/
my embarrassing 2.2l 5 spd 1965 fullsize S10w Ride http://www.s10forum.com/forum/f30/frankendime-458726/
my 49 chevy s10 swap 4.3 auto http://www.s10forum.com/forum/f30/49.../#post10592042
joedoh is offline
post #6 of 15 Old 04-19-2017, 02:23 PM Thread Starter
RGJ
RGJ's Avatar
the reason the idea popped up to put them on the front is because last night during a drinking and smoking spree, the idea of dropping in a line 6 engine came up as I have have one or two gathering dust in the shed.
these fans are 10" universal, is hard to find American cars at the junkyard here or ordering the parts for them at the autostore not to mention the prices they charge.
wont be putting the shroud back, as I have a DIY air intake for it
tomorrow I'm receiving my new radiator, so I will be installing the lot, will post some pics here on the weekend
thnx for the input guys.
friendly regards,
Ryan
RGJ is offline
post #7 of 15 Old 04-20-2017, 08:28 AM
I'm super serial
manbearpig's Avatar
On at 185 is way too early. The thermostat doesn't even open up until 195. Fans don't need to kick in until around 210.
WANTED: 98+ radio delete panel, antenna hole plug.
Crew cab airbag switch delete panel
post #8 of 15 Old 04-20-2017, 09:10 AM
always something new
S10dude's Avatar
User is: S10dude is offline
^^^^^^^^^^ agreed ...........mine is on 210 / off 180 ...
All truck pics
S10dude is offline
post #9 of 15 Old 04-20-2017, 09:51 AM Thread Starter
RGJ
RGJ's Avatar
cheers for the thermostat info, I have just ordered a new one.
for the time being I will install the 185 one.
friendly regards,
Ryan
RGJ is offline
post #10 of 15 Old 04-20-2017, 11:56 AM
User is: nstoolman1 is offline
This is true if you have a stock thermostat. I put a 180 in mine and the fan goes on at 200, off at 190. At cruise the temp sits at 180.
post #11 of 15 Old 04-20-2017, 12:54 PM
I'm super serial
manbearpig's Avatar
There's no benefit to using a 180 thermostat. The computer is programmed for the 195 and anything less is likely to cause overcooling. It will never reach operating temperature.
post #12 of 15 Old 04-20-2017, 01:06 PM Thread Starter
RGJ
RGJ's Avatar
what do you mean with the computer is programmed? the thermostat that controls the flow to radiator?
the new one will be on at 210 and off at 190.
just another question:
how much coolant will go into the system?
friendly regards,
Ryan
RGJ is offline
post #13 of 15 Old 04-20-2017, 01:13 PM
I'm super serial
manbearpig's Avatar
Yes, but the computer controls the air/fuel ratio using the engine temperature as a variable. The sensor needs to read a certain temperature to see that the engine is at operating temperature.
post #14 of 15 Old 04-20-2017, 01:26 PM Thread Starter
RGJ
RGJ's Avatar
by the time the engine is at operating temp, the air/fuel ratio is controlled by an impco computer belonging to my lpg system
RGJ is offline
post #15 of 15 Old 04-21-2017, 11:21 AM Thread Starter
RGJ
RGJ's Avatar
here some pics of my fans
forgot to order few new rubbers that the radiator sits in, so I found alternative ^^^
RGJ is offline
