ecm reset - S-10 Forum
post #1 of 8 Old 11-12-2004, 02:17 AM Thread Starter
therealdeal770's Avatar
User is: therealdeal770 is offline
ecm reset
i removed the ecm1 fuse ,the eng1 fuse and the ecm b fuse on my 00 2.2 s10. this should reset the computer to factory settings right . trying to get my mileage up. currently getting 21mpg with a new tuneup. i hear of people getting 30+ mpg.
post #2 of 8 Old 11-12-2004, 02:24 AM
scott750's Avatar
User is: scott750 is offline
Send a message via AIM to scott750
Re: ecm reset
The only thing that resetting the ecm does is clear all the trouble codes out of memory and reset the "learned" fuel tables back to stock. After a few startups, the computer will actually remember and adjust itself to the way you drive. What did you do for your tuneup? It should involve plugs, wires, new fuel filter, air filter, fuel injection service or cleaner added to tank, etc. I don't think the 2.2 engines have a cap a distributor, right. It's that coil pack or something. Also tire pressure can contribute largely to fuel economy. As well as your driving habits. Lead foot drivers won't get good MPG.
2001 S-10 - Dark Cherry Red, V6, auto, ext. cab, ZQ8 +2/3, rollin' on stock zq8s now
My New Gallery
Been to Nats '03, '04, '05 & '06..........Where were you?
scott750 is offline
post #3 of 8 Old 11-12-2004, 09:47 AM Thread Starter
Re: ecm reset
tune up was new acdelco platnum plugs ,bosch wires. 195 degree thermo, and cleaned the k and n .tire pressure is good. doesnt really matter how i drive it it gets about the same mileage. i had a 93 s10 4.3 that got the same mileage as my2.2. it was an auto with 3.42 gears and i drove the crap out of it
post #4 of 8 Old 11-12-2004, 01:07 PM
Zeeke98's Avatar
User is: Zeeke98 is offline
Re: ecm reset
Some 2.2's just DO NOT get good mileage. I had a 98 S10 2.2 5 speed that the best I ever got out of it was 24mpg on the highway. Most of the time it was around 20-21mpg. I do drive hard but even highway it wouldn't get decent mileage. It got totalled and I got a 98 Sonoma 2.2 5 speed and it gets better mileage and I drive it the same as the old one. I get 24mpg pretty regularly. 26 is the best it's ever gotten. I did tune ups on both and had new cats on both and still the mileage sucked on the S10. The S10 only had about 44,000 when it got totalled. The Sonoma had 78,000 when I bought it. So it has nothing to do with the age of the engine.
Wade
03 Chevy S10 Blazer 2 door 2wd Cherry Red Metallic, 3/3 Belltech drop, 18" Ridler 695 18x8 wheels with Pirelli 235/50/18 tires, SS mirrors, Bravada front clip, 6000K low/4300K high HIDs, smokey red tails, Spectre cold air intake, Hypertech programmer, Cherry Bomb turbo w/turndown, Envoy door panels and handles
02 Camaro SS SLP 345HP Black 6 speed T tops
85 Camaro IROC Z28 Silver 305 TPI Auto T tops
Zeeke98 is offline
post #5 of 8 Old 11-12-2004, 02:51 PM
slowly fast
Stinky's Avatar
User is: Stinky is offline
Re: ecm reset
Remove the negative battery cable and hold down the brake pedal for 30 seconds.Then just hook the neg. cable back up good to go.You will know it was done right if you pre sets or clock on your radio has to be reset.
Trucky truck pics
Lurker at large...
Stinky is offline
post #6 of 8 Old 11-13-2004, 05:18 AM
scott750's Avatar
Re: ecm reset
Wouldn't the presets on the radio disappear when the negative cable is pulled anyway? Even if its just pulled for a second off the battery? And what does pressing the brake pedal do? I've never heard of that method for resetting the ecm. I thought you just had to pull the battery cable for 10-15 minutes?
My New Gallery
scott750 is offline
post #7 of 8 Old 11-13-2004, 08:38 AM
slowly fast
Stinky's Avatar
Re: ecm reset
Not always.Especially if you have alot of stereo equipment and bass caps.Amps,head units,ECU's,electronics in general have capasitors that store energy for a short period.I can disconnect the neg cable in my truck and my interior light will still come on for a minute or so.Pressing on the brake pedal bleeds off any capasitance in the electrical system.Thats why they tell you to wait 10-15 min.Its easier and faster to just hold the brake pedal down and bleed it off.
Trucky truck pics
Lurker at large...
Stinky is offline
post #8 of 8 Old 11-14-2004, 11:08 PM
User is: Wesley is offline
Re: ecm reset
I dove alot of traveling for work and I average about 400 miles per tank on the highway. The most I have gotten out of one tank was 416 miles from luling,louisiana to tallahassee, florida. I have a 2.2 also
Wesley is offline
