Easy Tachometer Installation!!
LinkBack (2) Thread Tools
Old 07-02-2003, 04:28 PM   2 links from elsewhere to this Post. Click to view. #1
MtDewS10Zq8's Avatar
Alright! I bought a RActive Tach (10,000 RPM) and It had four wires Black(ground), red(battery+), yellow (battery ignition), and green (tachometer signal source). For you aftermarket stereo people this should be pretty simple - if you have extra wire behind your stereo - pull out your head unit and splice the 3 power cables into the power cables from the head unit (black to black red to red and yellow to yellow). Now! the hard part right? NO! easy part! don't you dare drill through the fire wall if you have a '98+ truck!!! I have a 1998 S10 5spd no tach in guages. The wires going to the guages HAVE A TACH SIGNAL IN THEM!
you will see a blue clip and a grey clip holding in the wires. On the Grey clip side it is the 2nd wire from the left (white-ish wire) cut that wire and hook it up to the tach signal for your new after-market tach! Reply if you have any questions!
Old 07-07-2003, 07:03 PM   #2
yamahaoftroy112
Posts: n/a
User is:
will this work for older models? like my 95? because my tach i have has been sitting in the room for like 6 months, i spent an entire weekend of headaches trying to hoook it up
Old 07-22-2003, 03:35 PM   #3
Im smart, My IDQ is 135.4
Slmd98s10's Avatar
nice, I got it all up using that tip and its great cept its reading to low, its idling at 500, how do i calibrate this?
Old 07-28-2003, 11:17 PM   #4
Dime Dragger
NiTe's Avatar
yea i have a 94 i need help lol i got it to work but kills the battery
Old 12-15-2003, 10:40 PM   #5
Got Stones????
yeah where did you get your tach and also where did you mount it??? and last where are the little blue and gray clips?? behind the instrument panel???
Old 12-16-2003, 12:29 AM   #6
FuelJunkie.com
STXS10's Avatar
Sorry about the size of the tach pic
I got my tach off a friend of mine off another board. Its a 3.75in 8000RPM Autometer SportComp. I didnt get any bolts though to mount it correctly.
Heres the "dash" off. Once you get that, remove the 4 bolts that are securing the gauge cluster.
Once you get that off and unplug the harness from the cluster and you get....
the infamous white wire. (Yes its on the grey clip side, dont ask me why i took the pic with the blue clip facing the camera )
Splicing into the white wire WILL NOT WORK!! Do as Mt. Dew said and cut the wire. Then use either your wire strippers if they can handle that wire guage that small or do what i did and CAREFULLY remove the sheath with a razor blade. Continue run wires from your tach signal wire to the green wire of your tach. Dont forget about the other wires. I spliced the +12V power and ground wires from my aftermarket radio harness, and ran a wire to the ORANGE dimmer wire to the white wire on my tach. It dims with the cluster lights
Heres a night shot of the lights minus the flash...
And another night shot with the flash showing where it is "mounted." I still have to bolt it down.
i have to upload the vids on my yahoo briefcase now, feel free to AIM me @ Blue72VeeDub and I will send u the link
-Zeke
Old 04-23-2004, 03:39 AM   #7
Re: Easy Tachometer Installation!!
I have a 94 and I bought a tach and its been rolling in my truck. I took off the four screws and took the whole cluster out and there are no wires. There is a green film on the back of the guage cluster, Help I don't know what to do and thanks for the pics. I am a more visual learner then verbal thanks
Old 04-23-2004, 03:40 AM   #8
oh and i have a 4.3L does that make a diffence?
Old 04-23-2004, 05:17 AM   #9
rollin' on 15's
1badsdime's Avatar
i think it only works for the 98 and up. could be wrong though.
Old 04-23-2004, 09:42 AM   #10
It actually only works on 98 -99... 2000 + run a digital signal and the tach will dance everywere I hooked a tach up in my 98 a long time ago I mounted mine on the a pillar if you have any questions feel free to ask...
I have HEARD on 94 there is a green wire coming off the coil packs and that what you splice into.....
BTW I spliced my white wire did not cut it just in case it might mess with something... also very good write up with pics I didnt have a digi cam at the time to get mine uploaded...
Jay
Old 04-24-2004, 02:21 PM   #11
FuelJunkie.com
STXS10's Avatar
Jay
mines a 2001
Old 06-30-2004, 11:04 PM   #12
So how would this be done in the 94-97 trucks. Maybe if we include the 94-97 trucks then it would be a huge tach install FAQ.
With my tach I got everything hooked up except for the tach signal line. I had lights and all but, I can't find the wire to tie into and the repair book wiring diagrams aren't any help.
Old 07-01-2004, 06:15 PM   #13
slowly fast
Stinky's Avatar
Works on 94-97.That wire is for the tach signal if you had a factory tach.
Old 07-01-2004, 10:23 PM   #14
I don't have a factory tach.
How does the factory cluster know when to turn the up-shift light on? Would that have a useable tach signal? and where the heck is that wire?
Also I tried pullin my cluster out to look behind it. Is there a trick to gettin it out? Cause I couldn't get it out. It always got struck on the top steering column cover and I couldn't get that top steering wheel cover off. So yea...
Old 07-04-2004, 03:17 AM   #15
Ok, I worked on it some more today. I found a wire that gave me a tach signal, but it was really f-ed up. It idled at 3k rpm and when I reved it, it eventually pegged at 8k rpm, which is impossible if it were correct (which it obviously isn't). It moved smoothly tho.
I was lookin in the repair book I have at the wiring diagrams and it says one of the connectors to the coil has wires goin specifically to the gauge cluster with a tach wire that branches off but it didn't name any specific color. Do any of you know what that wire color is?
Old 07-04-2004, 10:05 AM   #16
slowly fast
Stinky's Avatar
Its the white wire.You might need a MSD tach signal adapter.
Old 07-05-2004, 05:07 PM   #17
I fooled around a bit more after doin some more research. Found out which white wire comming out of the ECM is the white tach wire. I spliced into it and I got a kinda nice singal, still wrong, but definatly alot closer. It idled at 500 rpm( too low) and when I drove off i shifted from first at around what I would estimate to be 4000-4500rpm, but it never went above 2k, so yea. Do I actually have to connect the wire with a 3 way or can I just splice and use the signal adaptor and it'll give me a good signal.
Where's a good place to get that MSD signal adaptor. I might try that out.
Old 07-06-2004, 05:10 PM   #18
sounds like that tach is for a v8 not a 4 banger see if there is a switch on the back of the tach and change it see if that helps if not then you either have the wrong wire or a tach for a v8 that need to be recalibrated for a 4 banger
Jay
Old 07-06-2004, 07:52 PM   #19
There's no switch to change from engine type to engine type. Would the MSD adaptor change the signal to the right one of it happened to be a V-8 tach? If not is there any adaptor of the sort?
Old 07-08-2004, 09:31 AM   #20
well if there is a adapter that would change the pules to 4 banger i would not really trust it... I dont think the MSD adapter would change the pluses that much if at all... I would call the manufactuer and ask them about how to calibrate the tach and see if it will work on a 4 banger
Jay
Old 07-15-2004, 04:39 PM   #21
BiggJ
biggjohnson2k's Avatar
the orange dimmer wire on my 2000 s-10 kept the lights on the whole time so i just wired the white dimmer wire to the remote turn on on the stereo
Old 07-25-2004, 05:42 PM   #22
Is it the same position and color on a 1999?
Old 07-25-2004, 05:50 PM   #23
JMew03's Avatar
on the 99 the "white" wire he is talking about is tan... it is in the grey slot and it is the second wire, its in the #3 pin. and connecting the light wire from the tach to the yellow wire on the radio keeps the light on all the time. hopefully it wont kill my battery cuz i am to lazy to fix it right now
Old 07-27-2004, 12:07 AM   #24
FuelJunkie.com
STXS10's Avatar
red wire on aftermarket harnesses is the wire u need to hook it up to. Red = Ignition Yellow = Constant
Old 07-27-2004, 06:48 AM   #25
Where is the ECM on a 4 banger? Is it in the engine bay or in the cab of the truck? And what wire is it?
Old 11-25-2004, 11:33 PM   #26
Actually a Camaro person
72 Z27's Avatar
Exclamation Re: Easy Tachometer Installation!!
Does this work for a 96 b/c i took my dash apart and cannot find the blue/gray connector you are talking about. My gauge cluster plugs directly into a connector that a part of the dash. It does not look anything like you pics.
Old 11-27-2004, 11:15 AM   #27
slowly fast
Stinky's Avatar
The blue/gray connector is the ECM one.If you pull out your gauge cluster and look very carefully at the plug and the plastic circut board connection on the cluster you will notice(if you don't have a factory tach) that in the plug there is a white wire that has no counter part on the circutboard connection for the cluster.That is the tach signal output.
Old 11-27-2004, 08:56 PM   #28
great work on the tach wiring guys, but somebody told me if my truck didnt come with a tach , i could get another gauge cluster with a tach and put it in and it would work , is this true?
Old 11-27-2004, 11:39 PM   #29
slowly fast
Stinky's Avatar
Sounds like it would work,just your milage would not reflect true anymore! Could be a problem when you sell or re-title the vehicle.
Old 11-29-2004, 11:08 PM   #30
AoParasite's Avatar
ok I was asking this question just a few days ago. I was curious if I could take the display from an s-10 that had a tach and hook it into my tach-less wiring harness to see if it would work. If said hold true and the tach signal is there, then it should work right?
Old 11-30-2004, 12:47 PM   #31
yes but take note get the exact same year and engine size that you have now... somewere in mid 99 or 2k they changed signal on the cluster from anallog old style to a new digitial siginal and the clusters are not compatible and will get some really screwy readings
Old 01-20-2005, 09:44 PM   #32
Hey Ya'll, i am new to the s-10 world, i just bought a 99 2.2L and its tachless. I bought a sunpro tachII and did as the instructions said, i switched the tach to the 4 banger position and it still gave a low reading. The instructions said i need a tach adapter. Now if i go to the wire behind the dash, will it give me a better tach signal or is it just the sunpro tach that needs the $58 adaptor!!!
Thanks
Jeremy
Old 01-20-2005, 09:46 PM   #33
i spliced into the white wire off of the ignition module (sorry forgot to mention that) it said the splice into a white or orange
Old 03-08-2005, 09:06 PM   #34
97 sunpro 2 tach.
Hooked to white wire behind dash. idles at 1000. Matchs RMP really really well.
Old 03-18-2005, 11:14 PM   #35
Ap0lio
ap0lio's Avatar
WOW you guys rock this helped me out so much.... i spent an hour under the hood trying to find that damn white n orange wire... so i went behind the cluster gauge and tapped into the white wire... and i tapped into my stereo for the power wires... im getting a good reading i idle at 1 grand and im guessing around 4500 is my red line hehehehe ill get some pics on my homepage shortly
Old 03-19-2005, 05:05 PM   #36
Ap0lio
ap0lio's Avatar
shit now WTF my tach worked last night perfectly now it doesnt!!!! did you say the white wire behind the dash that you gotta splice into it or CUT the wire COMPLETELY and run from that wire to my tach????? yo yo yo get back to me asap
Old 03-19-2005, 09:26 PM   #37
Ap0lio
ap0lio's Avatar
ok had a lose wire that i clamped onto with those thingies.....gotta love watching rpm's
Old 03-20-2005, 01:33 AM   #38
I have a Auto meter sport-comp silver tach which is about 2". I installed it with my buddy threw the coil in my 98 2.2 S-10. Its been running on 500 RPM at idle and to the most goes up to 2grand when shifting gears. I was wondering if I do the back dash mod on this thread, will my tach work properly? Thanks
Old 03-25-2005, 04:04 PM   #39
heres apicture of the plug that goes into the gage cluster on a 2000 s10. hopefully it works
the wire it appears everyone is talking about is the 3rd down onthe grey (left) side of the plug
Old 03-29-2005, 12:13 PM   #40
does anyone know where i could get the pillar where i could stick a tach in? and what other little read outs could i put in there. Really the only guage i need is a tach and i dont really like the look of the giant tach on the dash or what not. an would wiring it up be the same?
Old 04-18-2005, 05:04 PM   #41
Certified Underage Drunk
bww3588's Avatar
or you can save yourself the hassel of splicing into wires and just go to the boneyard and find an instrument cluster from the same type truck with same mileage and make the simple swap. and its clean. no big honkin tach to place on the dash where it is in your way.
Old 04-20-2005, 08:40 PM   #42
Weeee
xSmokYx's Avatar
Dont be so negative, and youll never find a truck with the same miles so you might as well forget that shit. I just bought the sunpro II that i noticed a couple of you said you were hooking up, im gonna try here in about an hour to hook it up, ill get back to you if it worked out right or not... im getting confused thought because some people are saying they spliced the wires, some are saying they cut them. I have a 97 so im just going to splice it off and try that out!
Old 04-23-2005, 12:18 AM   #43
bww3588's Avatar
i did. im my case i told em i needed a 98 s-10 cluster with tach with about 90k miles and thats exactly what i go. a tach cluster with 89765 miles. my truck had 90243 on it so i got the benefit of the doubt for 20 dollars and it works. but thats just me. it took me 20 minutes to do this and it was a simple swap so i think this is looking positive trying to simplify things. but do what you guys want. its your truck.
Old 04-27-2005, 02:34 PM   #44
Draggin Moderator
98layinframe's Avatar
so your saying you went out and picked up a cluster assembly with tach out of the same year truck, and swapped it in to your truck with out any modifications at all... and it works fine?
now i just gota find another cluster with a tach!
Old 04-27-2005, 05:10 PM   #45
bww3588's Avatar
no problem just disconnect your battery cable and pull the airbag fuse cause of working around the steering coulmn. easy easy easy.!
Old 04-27-2005, 07:17 PM   #46
Ap0lio
ap0lio's Avatar
thats decent man.... take a look at my homepage....thats where i installed my tach.... not professional but it works
Old 04-27-2005, 07:36 PM   #47
bww3588's Avatar
thats pretty kickin'. looks good. and as long as it works. sweet.
Old 05-03-2005, 02:26 AM   #48
FuelJunkie.com
STXS10's Avatar
damn its been a while since ive posted on these forums......
Old 05-03-2005, 04:11 PM   #49
newbie
Seancass's Avatar
im thinking ill do this too, i just dont want to put some huge thing on there that looks stupid. only two more days and ill be driving my new truck.
Old 05-03-2005, 04:16 PM   #50
The other "body" man
BobOnAir's Avatar
No,, I'm going to drill my firewall anyways!
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f105/easy-tachometer-installation-50487/
Posted By For Type Date
Installing a Tach - Automotive Forums .com Car Chat This thread Refback 01-20-2008 09:45 PM
Installing a Tach - Automotive Forums .com Car Chat This thread Refback 11-14-2007 08:08 AM
Page generated in 0.64665 seconds with 32 queries
[Output: 217.53 Kb. compressed to 198.87 Kb. by saving 18.66 Kb. (8.58%)]
