curiousity; might kill the dime
Old 07-02-2008, 03:33 PM   #1
SJAS95s10 is on a distinguished road
i have a 95 with the 2.2l 4 cyl its my understanding that they need a lot of back pressure. now i bought the truck with a hollowed out cat and the truck runs rough and my buddy put his computer to it and it shows that the timing is flucuating at idle and it is rough. can this all be due to the cat convert or am i looking at getting a ECM. Any help is appreciated.
Old 07-02-2008, 03:35 PM   #2
Chivalay Mane
bmxatv10's Avatar
bmxatv10
Re: curiousity; might kill the dime
i seriously doubt its the cat, it shouldn't effect your timing fluctuating at idle... what kinda program did your buddy use to see this timing fluctuation at idle? just curious...
Old 07-02-2008, 03:40 PM   #3
he has a scanner and u can read the outputs as the car runs
Old 07-03-2008, 06:47 PM   #4
quadrace13 is on a distinguished road
a 95 would not register a gutted cat, it only has one o2 sensor, before the cat.... the timing could be because of anything, any bad sensor or injector, or plug or wire... the timing is changing as a result to the crappy running, trying to level itself out.... MOST LIKELY but there is always a possibility that the cps is shot, doubt it tho
Old 07-04-2008, 06:50 PM   #5
the village idiot
smirnoffmx's Avatar
smirnoffmx is on a distinguished road
your truck doesnt need backpressure, that doesnt mean run it open but it doesnt need 4 turbo mufflers and the problem is def not the cat especially on a 95
Old 07-05-2008, 10:53 PM   #6
Deaf Mod
What?'s Avatar
What? is on a distinguished road
do complete tuneup 1st
Old 07-05-2008, 11:17 PM   #7
mechanicix's Avatar
mechanicix is on a distinguished road
X2, I dought the ECM is bad either. Probably a sensor, Keep in mind the timing is controlled by vacuum if it has a distributer, so check for a vacuum leak or sensor, a tune up might even fix your problem.
Old 07-06-2008, 10:18 AM   #8
eljefino is on a distinguished road
You need back pressure for the EGR stuff to work right but EGR isn't called for at idle. (but it might be stuck OPEN, a crappy lopey idle is a pretty good indicator especially if it cruises okay.)
I agree with the tune up stuff and of course maybe a vacuum leak.
Old 07-10-2008, 07:14 PM   #9
Van Dimed is on a distinguished road
back pressure on 2.2's seems to keep torque high but,
keeps hp will increase if you open up the exhaust.
Old 07-10-2008, 07:54 PM   #10
hp will increase if you open up the exhaust...
Page generated in 0.09728 seconds with 11 queries
