Cold Air intake. Real gain or just more pleasing to my ears?
Old 08-01-2007, 09:05 PM   #1
Okay im debating weither or not to get a Cold Air intake. People tell me its not worth it for the little gain. Well I asked the people that ARE NOT s10 junkies.
So whats your take? Is it worth it? How much noise difference is there under the hood? What brand should I buy?
Old 08-01-2007, 09:16 PM   #2
bellcranks no more
greencactus3's Avatar
Re: Cold Air intake. Real gain or just more pleasing to my ears?
slight noise difference. most people will agree just buy the cheapest youcan get.
and you can get the same exact results (debatable i suppose) by just cutting the stock airbox.
Old 08-01-2007, 10:22 PM   #3
okay im down to the aem and the k*n. their not cold as advertised???!?!
Old 08-01-2007, 10:36 PM   #4
Useless posting member
Wrkn prgs's Avatar
get the chromeintakes one on ebay, and upgrade to a K&N filter.
I have that one and it does indeed sound better, and has a bit more get go in higher RPM's. I have raced two other s10's, with just a stock intake and a cone filter, and one with a CAI - both 5 spd, and a stock 2.2 auto and beat all 3. The only thing I have done is a CAI, a Dynomax muffler, and new 2.25" exhaust piping without as many bends as the stock exhaust.
Old 08-01-2007, 10:50 PM   #5
bellcranks no more
im happy with my $15 one?
its not techincally a cold air because no kits i know of actually go into the wheel well... or anywhere other than within the engine compartment
Old 08-02-2007, 12:11 AM   #6
I'm Back!!
beandip's Avatar
hmm i wonder if you run a big flexible hose from the ac to the intake?....comming from inside your truck
jk
btw, how do you keep from sucking up water with those ebay intakes? (when you hit a big puddle).
Old 08-02-2007, 12:41 AM   #7
MikeXtreme's Avatar
jk
Most actual cold air intakes have what's called a bypass valve on them (not to be confused with a blow off valve on a turbo). It stops water from entering the intake.
Old 08-02-2007, 02:51 AM   #8
P.O.S-sonoma's Avatar
and it defeats the purpose of having a "cold air intake" . it will allow air to get sucked trough it along with the air filter
Old 08-02-2007, 09:26 AM   #9
cevtv's Avatar
WTF are you talking about???????
Old 08-02-2007, 09:44 AM   #10
MikeXtreme's Avatar
It's an external diaphragm to keep water out, but keep air flowing in in case your filter gets submerged in water (big puddle or whatever). Normal intakes that have the filter in the engine bay don't really need these.
Old 08-02-2007, 10:45 AM   #11
MikeXtreme's Avatar
AEM’s patented Air Bypass Valve virtually eliminates the chance of hydro-lock in the event the filter of your AEM Cold Air induction system becomes submerged in water. On most systems, the valve installs along the upper portion of the inlet pipe and shuts down induction at the filter when it becomes submerged, rerouting air through its external diaphragm to keep water out and air flowing in. Check with your dealer or call AEM for more information on air bypass valve installation locations. The AEM Air Bypass Valve is C.A.R.B. exempt on AEM Cold Air induction systems only and is NOT for use on forced induction vehicles.
Here ya go!
Old 08-02-2007, 01:58 PM   #12
cevtv's Avatar
Here ya go!
Wow! Unbelievable what they'll try to sell....
Old 08-02-2007, 02:22 PM   #13
LOL<
Old 08-02-2007, 10:11 PM   #14
blahh
hutchS-10's Avatar
i think he works for like aem or somehting lol...I have a chromeintakes intake off ebay. get it its worth it not too mention what a conversation piece it is.... lol
Old 08-03-2007, 12:55 AM   #15
MikeXtreme's Avatar
Nah, don't work for AEM ( that would be pretty sweet) I just had a friend who had an intake, and he hit a big ass puddle, and his engine was hydrolocked. He invested in one of those little things, and it didn't happen again. My buddy still says he has a blow off valve, though, that's why I brought that up. I have no idea how it works, but I assure you, it does.
Old 08-07-2007, 01:15 AM   #16
Tweaker extrordinare
I have an AEM (non-oil type filter). The cleaning without oiling is sweet, so yeah. It was super-easy to install, took me less than an hour (might take others more if you don't have experience taking the old AF assembly off)
With an upgraded exhaust, BIG difference. Along with the exhaust noise, you get a better sound from the engine compartment itself, and a better exhaust tone. Little more power too.
Old 08-07-2007, 10:00 PM   #17
I recomemd to stay away from ebay if you live in California. My smog inspection is coming up and I know it will fail by just loking at it. I regret not buying the Volant or K&N CARB excempt air intakes.
Its funny that I kept the old intake, yet manage to loose half the parts for the inspection that right around the corner.
Old 08-08-2007, 09:07 PM   #18
A CLEANMACHINE's Avatar
you can keep your stock air box ,use a k/n drop in and go to www.siliconeintakes.com check it out and you"ll have a cold air intake .
Old 08-10-2007, 03:22 AM   #19
Ford guy stuck w/ chebby
n8rsk8r's Avatar
I dunno I like mine, I got a kit on ebay also, but found that after I drove it around, the metal was freaking HOT!! So I encased it in fiberglass about 1/4" thick. I have mine a lil different then most I would bet. You guys want to post a pic of your intakes? I will take a pic of what mine looks like this weekend and post it.
Old 08-10-2007, 07:31 AM   #20
stockchevy1983's Avatar
heres mine
Old 08-15-2007, 10:47 AM   #21
n8rsk8r's Avatar
ah shit, forgot to take a pic of mine. Where did you get yours from?
Old 08-22-2007, 02:18 AM   #22
DMP
DMP's Avatar
Ram air is the only way to go, IMHO. The problem with those aftermarket CAI are they suck in hot air from the engine bay. You would need a heat shield to keep the hot air away. The problem with ram air is the location of the tube. Ive seen setups go through the headlight and/or foglights and those work.
Heres examples:
And im sure you heard of ram air hoods. How do you think they work? Same concept.
Old 08-22-2007, 02:23 AM   #23
Have a nice day!
ProTouring2.2's Avatar
I got this short ram thing off ebay with a blue metal tube and a cone filter. the noise it makes is ridiculous. It totally changes the tone of the motor and you can hear it inside the cab. Probably no HP gains, but I don't really care cause it sounds cool as hell. Worth the $15 for the sound alone IMO
Old 08-22-2007, 02:36 AM   #24
Moderator
What?'s Avatar
couple hp gain, louder noise, just get ebay setup and k&n filter or any other good brand filter so it doesnt deterate eventually
Old 08-22-2007, 02:43 AM   #25
96blazer's Avatar
Everyone just puts the stock parts back on for the test, it's no big thing.
Old 08-22-2007, 02:54 AM   #26
Trackside Support Vehicle
S-10Driver's Avatar
cut and de-silenced stock intake here, thinkin about gettin a ebay deal though since i removed the factory fan shroud.
Old 08-22-2007, 03:03 AM   #27
Negative 10
KENNYMO's Avatar
whats so good about the chrome tubes for the intake? anything other than looks? i took off my stock airbox and attatched a cone filter straight on where the box used to. i dont notice anything different. sound or performance
Old 08-22-2007, 03:12 AM   #28
S-10Driver's Avatar
did you remove the giant silencer on the passenger side of the radiator? that made mine a lot louder.
Old 08-22-2007, 03:14 AM   #29
Negative 10
KENNYMO's Avatar
ok well i didnt even realize when i posted in here that its in the 4 banger section. but does that matter? cuz i did it on my v6. do you know if mine has this sound silencer?
Old 08-22-2007, 09:51 AM   #30
So you guys are saying install this but put a better filter on?
http://cgi.ebay.com/ebaymotors/99-04...spagenameZWDVW
Someone told me id have to do stuff with the computer cuse of emissions, i dont believe that.
Old 08-22-2007, 04:16 PM   #31
spatch137's Avatar
I've had different cai's on my truck the first one was APC which the welds fell apart on, they replaced it with a new design whose filter fell apart so i just splurged for the K&N. Very little difference at first however when combined with a slightly larger diameter exhaust (2.5") and a better flowing muffler (flowmaster), i actually noticed alot more throttle response and a way better sound. I could be wrong here but the K&N being plastic seems like a better design and more like a cold air intake because it doesnt heat up like the chrome ones.
Old 08-22-2007, 09:06 PM   #32
DMP
DMP's Avatar
Aluminum is a good conductor for heat. So plastic would be better. I agree.
Old 08-22-2007, 09:12 PM   #33
96blazer's Avatar
They both eventually heat up, but it doesn't matter anyways because it has no affect on the air. There's been tons of test about this misconception.
Old 08-23-2007, 01:28 AM   #34
DMP
DMP's Avatar
Thats true too. Even if it did have an affect on air, it would be very minimal. I already knew this.
Old 08-23-2007, 09:58 AM   #35
spatch137's Avatar
just get a cheap one then and hope it doesnt fall apart. They do help, i mean look at all the bends and tubing in the stock intake, that with all the bends in the stock exhaust. Air flow is pretty restricted. Dont expect significant gains just a little more pep.
Old 08-23-2007, 02:11 PM   #36
Quote: Originally Posted by stockchevy1983
heres mine
That would help unclutter under the hood. Where did you get yours?
Old 08-23-2007, 03:10 PM   #37
drumset5994's Avatar
Has anyone seen any real significant MPG increases? I could give two craps about HP...thats what my Silvy's for...
I'm wondering if a cold air intake for my S10 would make an MPG increase...anyone have any real numbers?
Old 08-23-2007, 10:52 PM   #38
i only increased about 3-5mpg more
Old 08-24-2007, 09:01 AM   #39
spatch137's Avatar
Thats actually alot.
Old 08-24-2007, 09:47 AM   #40
workin it !
S10dude's Avatar
that's a hella of alot....i only got 1 maybe 2 on a good day...
Old 08-24-2007, 12:23 PM   #41
really? i thought it wasnt much lol, well good for me then huh lol
Old 01-27-2008, 12:31 PM   #42
Dialed!
tg900's Avatar
you can get stuff called wrinkle paint...if you have ever seen a cold air intake, they plate the metal with a paint that wrinkles as it dries, its good insulator for heat. i was told the spray on stuff is decent, i plan on getting an aluminum one and spraying it with that stuff.
Old 01-27-2008, 03:53 PM   #43
too many s-10s? nah
jadoangel's Avatar
if your not sure about whether or not u wanna get a CAI, or what difference its gonna make, just grab some header wrap and some tin foil. put the header wrap on the intake tube and tin foil over top of it, shiny side out. Tin foil the air box too. zap straps will hold it all in place no prob. Take it out on the highway and run a tank through it, you'll notice a slight hp increase and maybe a couple mpg gain just from insulating the intake system.
Old 01-27-2008, 04:07 PM   #44
Kurrupted Kreations
Garage Customs's Avatar
i got this one from sport truck specialties
Old 01-27-2008, 06:15 PM   #45
kickflipking_04's Avatar
Cool Re: Cold Air intake. Real gain or just more pleasing to my ears?
How much was that one you have? And did it really do anyhting that you could tell? Did it make a sucking sound or whatever you want to call it....
Old 01-27-2008, 07:15 PM   #46
Just turned 18
I think just about any after market CAI will make that sucking sound at WOT.
Old 01-27-2008, 08:29 PM   #47
has no indigoblue2kdime.
indigoblue2kdime's Avatar
Hell, i plan on buying one just so i can see my damn valve cover. There's so much plastic in the engine bay of a 2.2 truck it's a little disheartening to look at.
Old 01-27-2008, 08:36 PM   #48
4x4 v6 blazer
neo71665's Avatar
Just more to paint
Page generated in 0.69859 seconds with 31 queries
[Output: 209.93 Kb. compressed to 191.81 Kb. by saving 18.12 Kb. (8.63%)]
