Chrome intakes install
Old 03-10-2008, 05:40 PM   #1
In a few weeks im going to install my chrome intakes intake on my 98 2.2
Before I go ahead is there any pointers or things I should look out for before I do it?
I remember reading the other topics(from searching) and some of you guys were saying stuff about damaging the intake pipe because it got to hot. I don't know but any tips that would help me out is appreciated.
Old 03-10-2008, 05:55 PM   #2
5.3 coming soon!!!
Petterle's Avatar
Re: Chrome intakes install
its pretty straight foreward, it took me like 20 minutes
Old 03-10-2008, 06:26 PM   #3
I read here that you guy's had some fun with the intake sensor and the grommet, right?
Old 03-10-2008, 07:32 PM   #4
Sik-98
chevyDime98's Avatar
chromeintakes is usually pretty good about the sensor grommet, the only thing you may have to look out for is that if you have ac the chome intake comes very close to the ac comp. u may have to space it
Old 03-11-2008, 01:04 PM   #5
Thats what I ment lol. I couldn't put my finger on it.
Where do you put the bracket on that is provided
Old 03-11-2008, 01:06 PM   #6
Sik-98
i didnt really use it cause it was flimsy and looked like crap went bent, they include a little "L" bracket thing when i had mine, i bolted it to the top left bolt on the ac comp, this gave me the proper spacing for the intake and ac pulley. it will make more sense when u go to install your intake
Old 03-11-2008, 01:23 PM   #7
bellcranks no more
greencactus3's Avatar
throw away that flimsy 'bracket'
just go buy some stock aluminum and bend it and drill it to how you want
Old 03-11-2008, 01:34 PM   #8
ChiefRoberts's Avatar
make sure after you install it that the actual pipe itself isnt touching anything that will damage it..or it will vibrate a hole in the pipe
Old 03-11-2008, 01:35 PM   #9
Mattie L.'s Avatar
if you position your tube right, and tighten it enough it will be fine and wont move...i have ac and the only thing i had problems with once was the dame cone falling off!!
Old 03-11-2008, 01:45 PM   #10
tu-tu guru
Chris0nllyn's Avatar
ive also heard that the pipe is a lil long and the filter hits the bottom
Old 03-11-2008, 01:54 PM   #11
Sik-98
i had to trim mine at the TB cause it was too long and ran right into the ac lol
Old 03-11-2008, 06:03 PM   #12
Useless posting member
Wrkn prgs's Avatar
I have my bracket mounted to my fan shroud. My g/f turned my a/c on before I put the bracket on and chewed up the side a little.
Als, the o2 sensor grommet works alright, it just sucks trying to get the sensor inside of the grommet without pushing the grommet through the intake tube.
Old 03-11-2008, 09:30 PM   #13
tu-tu guru
its an intake air temp. sensor
Old 03-12-2008, 01:25 AM   #14
cokehead
Dr. Pepper's Avatar
yea, mines got a real nice groove in the side of mine. i really cant believe it hasnt gone thru it. i have it spaced now, but didnt realize it til it already did its damage.
Old 03-12-2008, 08:15 AM   #15
tu-tu guru
lol...on an other note, you comin to the meet in april? check out the MD thread
Old 03-13-2008, 02:20 AM   #16
Moderator
What?'s Avatar
on side note, ever heard of pm?
Old 06-22-2008, 04:51 AM   #17
KreativeS10's Avatar
Angry Re: Chrome intakes install
Got mine installed perfectly on my 99 no ac...just ran the bracket the the fan shroud...just havin hella problems with the intake temp sensor poppin codes and suggestions??
Old 06-22-2008, 06:37 AM   #18
Anyone tried the air intake from these folks:
http://www.dts2.net/turbos-10/
Old 06-22-2008, 09:56 AM   #19
I'm Back!!
beandip's Avatar
nope, but instead of paying $80 for that, get this http://www.s10forum.com/forum/f105/e...6/#post5242235
Old 06-22-2008, 08:29 PM   #20
Just turned 18
i think this intake looks a lot better than the chrome intakes intake...and also looks a lot sturdier as well
Old 06-22-2008, 10:10 PM   #21
air ride equipped
stalephotograph's Avatar
sucks that the seller doesnt have anymore of them.
Old 06-23-2008, 10:09 AM   #22
I'm Back!!
beandip's Avatar
HAHA YES THEY DO!!! i did some more searches around ebay, and found the seller! its a new seller, but the intake is the same. looks like he changed names or something. the other one was for a "GMC SONOMA" which is the same as an s10 but now the site advertises them as for s10s since most people will search for S10.
the seller name is imperialautoshop. search his name in ebay, there you will find the intake.
if your lazy search 99-04 CHEVY S10 4CYL 2.2L HEAT SHIELD AIR INTAKE 02 03
or if your really lazy here is a link
http://cgi.ebay.com/ebaymotors/_Car-...m170232174123&
dont forget to use the "rate me" if this post helps you out .
Old 06-23-2008, 06:46 PM   #23
Will this still require water protection? I drive mine everyday also...
Old 06-23-2008, 07:31 PM   #24
I'm Back!!
beandip's Avatar
ehh, yes and no. in my areas there is very deep water in some places so i didnt want to take a chance. it didnt take vary long to cut the floor mat to waterproof the intake but was worth the peace of mind.
Old 06-23-2008, 11:22 PM   #25
air ride equipped
that seller didnt stick around long. stating invalid item. when i searched his user name, it states hes no longer a valid user.
Old 06-23-2008, 11:25 PM   #26
I'm Back!!
beandip's Avatar
thats weird.
Old 06-23-2008, 11:42 PM   #27
air ride equipped
tell me about it haha. i just settled w/ one from chrome intakes for $50. itll look good w/ my polished obx header i have, so it works out ok.
Old 06-25-2008, 05:55 PM   #28
[quote=beandip;5355619]...or if your really lazy here is a link
...QUOTE]
Invalid link. Have they already shut down???
Page generated in 0.64259 seconds with 31 queries
[Output: 137.02 Kb. compressed to 126.16 Kb. by saving 10.87 Kb. (7.93%)]
