Moderator
Cavalier Intake Swap How To:
Still need to add more threads/posts regarding this but heres a general idea, more to come
If you PM them questions and they reply, PLEASE Post you questions here and their reply OR have them copy and paste YOUR question and member reply their answer HERE, send with a link DO NOT REPEAT QUESTIONS IF ITS ALREADY ANSWERED ANOTHER LINK FOR CAVALIER INTAKE SWAP http://www.s10forum.com/forum/f143/k...s-2-2l-243456/ Member's post/pics minimee99- 99 s10, 3"bd, tubular a-arms, 20's, stock throttle body. Everything mounted fine. Need to extend four wires and get a new throttle cable. Got the 36" lokar cable from summit. I cut it down, played with the overall length but everything works great! As for the air filter sensor, I stuck a resistor in it and taped it off, no check engine light. ![]() jherrell ![]() Milky4204 ![]() ![]() Last edited by What? : 05-28-2008 at 08:43 PM. |
Re: Cavalier Intake Swap How To:
So would the Venom intake manifold fit? Thats the only aftermarket manifold I know of that offers one for the Cavalier. Id rather do this mod for performance. But then again its $700+ for it....so more like no.
so does the cav intake mani add any power? or is it just to have the filter up top for guys wanting to keep there stock hood i tryed to read the thread but it was just full of hi bye talk.. i just got my s10 and im already hating the 2.2l power
94 s10 in progress
lol^ so does this intake mani work on 94-97 2.2L also? if it did that means we could run a bigger tb also along with the intake manifold...or is it not worth the swap for the gains you get?
Location: Houston/Baton Rouge....SicRides User is: OffLine |
ummk ,, that looks really werid and cool at the same time..
any gains or losses in power or tq?
Trackside Support Vehicle
no hp gains, just hood clearance for a body drop i believe...plus you can show off that valve cover.
Moderator
its for 98+ 2.2L
It DOES NOT increase power. its good to use for turbo, supercharging application or JUST LOOK different, but it does clear more room under the hood as well, it would be a plus for intake being AWAY from header for more cooling compare to stock location |
air ride equipped
that looks pretty sweet. id like to that mod just to be different in my area. is there any clearance issues w/ the manifold and upper control arm? ive been thinking of ordering sd control arms and running 20s up front.
Moderator
you can ask in that thread or other thread in baggin it section, there are several of this detailed info regarding the aftermarket control arms for bags and 20s with cava intake
Xtreme Measures
the 2.2L has no mass airflow sensor, The computer cannot automatically adjust fuel flow to be proportionate to added air volume. So without having the computer reprogrammed its not going to add hp. Like was said just for looks and hood clearance.
Dialed!
Where do the fuel injectors go?
joining 2.2l boosted club
lol the injectors dont go in the intake....they go in the engine...witht the fuel rail....and its probably the same setup just a little bit diffrernt in location for the air intake as the pic shows...
SLASH - S.I.C. St. Louis
Pac is a hackin!
so just a question: would the late 90's cavilers intake fit us 94-97 s-10 guys?
Dialed!
Moderator
Dialed!
anyone do this with stock a/c?
Moderator
I don't recall, I had it on temporairly but a/c lines were already plugged, I think it'll still have clearance somewhat
Dialed!
it's not any lines that get in the way, it's the blower box. the heater only blower box doesn't have a radiator in the blower box for the cooling, its just the heater core inside.
with a/c, the blower box is bigger...and it sucks for be because the throttle body won't fit. the intake manifold fits just barely, but if i wanted to put the throttle body on it, theres no way. the throttle body's vacuum ports stick into towards the blower box, and theres no clearance as it is. |
FooldU
minimee99 says he used a resistor for the intake sensor...what kind of resistor? how many ohms, etc?
#24 |
Registered Abuser
So just for clarification, Does this swap fit with my ac? if not, is there any mod i can do so that it does fit?
#25 |
Location: Indianapolis (castleton), Indiana User is: OffLine |
Is there really no way this would work on a 97? I keep just seeing 98+
#26 |
Dialed!
I had about 1/4 inch of clearance between the manifold and the a/c blower box as it was without the throttle body...if you rev the motor, i'm pretty sure the motor/intake manifold is going to get pushed into the a/c blower box. So then you'll have more problems than you started with. Also it's impossible to make a throttle body fit since the way it bolts to the intake. The vacuum lines poke towards the blower box, so it's impossible to bolt on. Last edited by tg900 : 06-10-2009 at 11:04 AM. |
#27 |
Dialed!
#28 |
Moderator
Won't fit due to flow port are different position than 98+ as well as the design.
#29 |
<Severed TIES>
I have heard you can use a 4.3 blazer throttle cable can anyone confirm this
#30 |
Dialed!
#31 |
The Deftones
Do I have to use the cavi fuel rail with the cavi manifold or can I use my stock fuel rail
#32 |
one of a kind
you can use your stock one, but Im actually having a hard time getting the injectors in, does me having 42lb injectors have anything to do with it?
#33 |
let the cutting begin!!
