Cavalier 2.2 vs. S10 2.2 - S-10 Forum
post #1 of 9 Old 04-12-2010, 09:27 PM Thread Starter
1995 S10
Old School S-10's Avatar
User is: Old School S-10 is offline
I know this is a dumb question but just wanna double check. Is the cavalier 2.2 the same as the S10 2.2. I'm starting a turbo build and i was hoping to get my buddies cavalier motor. Will it work? Are the mounting holes different because its a front wheel drive, while the truck is rear wheel? Thanks for the help. Keep an eye out for my turbo build.
post #2 of 9 Old 04-12-2010, 09:30 PM
NOT AN S10
tg900's Avatar
User is: tg900 is offline
Send a message via AIM to tg900
Re: Cavalier 2.2 vs. S10 2.2
There may or may not be holes for the motor mounts, watch out for them.
Originally Posted by hedgehog View Post
..... I know the truck better than my wife and have also found it to be more dependable than my wife.
ELTC NEPA
tg900 is offline
post #3 of 9 Old 04-12-2010, 10:41 PM
Tech Mod
beandip's Avatar
User is: beandip is offline
It should be the same except for the head i believe. you can make it work but it cant remember what it is...has something to do with the water passageway.
but 100% the block is the same. as long as you are not going from a 97 cavi to 98+ i think.
-Jonathan
2009 Harley Nightrain
1984 CUCV - Rock crawler
beandip is offline
post #4 of 9 Old 04-12-2010, 11:23 PM Thread Starter
1995 S10
I've got a 95 s10, and the motor i think is a 99. I will be using a stage 3 head so that's not the issue. i just want to know if the bell housing for the truck will bolt up to the cav. motor.
post #5 of 9 Old 04-13-2010, 03:07 PM
NOT AN S10
tg900's Avatar
There are two versions of the 2.2 that come in our trucks, 94-97 and 98+. You may have an issue there since the design of the motor was changed.
ELTC NEPA
tg900 is offline
post #6 of 9 Old 04-13-2010, 03:13 PM
S10's-R-Us
Lowl!f3's Avatar
User is: Lowl!f3 is offline
It will work but you need to install parts from a rear wheel drive on the cavi engine. Head and block are the same.
Lowl!f3 is offline
post #7 of 9 Old 04-14-2010, 06:58 AM
300k's Avatar
User is: 300k is offline
It's a hard to find thread but it contains all the info you need.
http://www.s10forum.com/forum/f105/2...-pains-321784/
The blocks were almost identical minus the addition of the cam position sensor in 1996. There is also a difference in lifter guides from 1995 to 1999 but you will be ok as long as you use the guides that came with the engine. The big difference is the crank. You will not be able to use the '99 crank with the '95 ECU as the timing marks are advanced 0.450". The heads are also very different from '95 to '99.
1999 S10 2.2 Ex-cab 5-sp Turbo
Build Thread: http://www.s10forum.com/forum/f105/2...-build-621114/
1998 S10 2.2L Auto Turbo
Build Thread: http://www.s10forum.com/forum/f105/u...-build-402312/
2005 Yamaha R6 Raven edition
1965 MG-M resto-mod fully restored
2000 Honda S2000
300k is offline
post #8 of 9 Old 04-14-2010, 09:16 PM Thread Starter
1995 S10
Thanks for all the help guys. I'm getting the motor tomorrow. Turbo build will be soon after.
post #9 of 9 Old 04-19-2010, 09:22 PM
Powder Coat Specialist
xtrememeasures10's Avatar
User is: xtrememeasures10 is offline
Send a message via AIM to xtrememeasures10
Your right the water passageway on a cavi is on the sides. Youll notice there is a freeze plug installed right where the neck that holds the T-stat bolts to the head. You'll have to hit that in the corner with a punch to get the plug to turn then grab it w/ some plyers and she will come right out.
Thats all i know about the head cause i got a new head and it came setup for a cavi. As far as the motor swap knows see what everyone else says.
97' w/ 03' Front end, Too many mods to list....
2.2L Build and Powder Coat Project
http://www.s10forum.com/forum/f105/2...ernals-486082/
Check out my Business Powder Coating work.
http://www.facebook.com/makpowdercoating
