Best obd1 scanner/software?
It seems like obd2 has many more options as far as diagnostics but what is the best obd1 scanner? specifically for a '94 2.2l.........Most I'm finding have KOEO, KOER, timing, and cylinder balance tests but I'm looking for a little more.....so does anyone know a GOOD scanner along with software with as many options as and obd2? Thank you.
Re: Best obd1 scanner/software?
Most OBD2 readers I've seen have adapters for OBD1. The one I got at Schucks does both. It was 250 a year ago and I'm willing to bet they've fallen in price. Never know when you're gonna need both, all your buddies will be hitting you up for the scan tool lol.
Yeah, i was looking into the Innova Equus 3140, it does obd1 and 2 but doesn't do half the stuff with the obd1 as it can with 2. i guess it's the Control area network feature.
Gotta remember OBD1 is almost 30 years old now, it can't do much. KOER, KOEO, Cylinder Balance, and Timing is all that I've ever been able to see them do. When I had my B2 my OBD2 scanner was able to pick up all kinds of codes, might be extremely slow (sometimes took it 40 minutes of idling to decide what it thought) but it was more than adequate.
1 slo S
What are you wanting to accomplish? Obd1 is very limited. If you are wanting to view values on sensors any scanner that does obd2 should back convert with the correct adaptors.
1 slo S
I don't think you are going to find a scanner that will give you direct misfire counts or cylinders on obd1 I have a $5000 OTC Genysis and it wont do it on s10s the information available is based on the vehicle.
How much are you wanting to spend? |
tu-tu guru
snap-on mt2500
i use it, works great....tells me all kinds of stuff (except misfire location and knock) |
slow as shit-10
tu-tu guru
you can find em on ebay pretty cheap....brand new it was like 1800
Electrical Mod
![]() Age: 23
I didn't even know you could check those things on OBDI, here i figured it was just for check engine light, codes, and abs. very limited stuff.
tu-tu guru
i can check long term fuel trim, o2 crosscounts, clear codes, basically any engine data
as well as air bag and trans stuff |
Electrical Mod
![]() Age: 23
tu-tu guru
theres stuff out there, ive been researching
| Sponsored Links | |
Advertisement | |
