Anyone else's header glow?
Old 11-15-2004, 09:09 AM   #1
sdime 4 life
mikersdime's Avatar
The exhaust manifold never glowed. Drove for 3 minutes test driving the header and the thing looks like a lava lamp. Any ideas?
Old 11-15-2004, 07:22 PM   #2
The Blue Ferret
BigRey's Avatar
Re: Anyone else's header glow?
Are you currently having any drivability problems?
Old 11-15-2004, 07:34 PM   #3
eugenen's Avatar
sounds like my 2.5 when I overheated it, that was hot enough to melt the piston
Old 11-15-2004, 08:00 PM   #4
faster than the slowest
nug@dvstc's Avatar
a header will glow if EGT's are high, due to running lean or retarded timing, just because the header is glowing isnt always a bad thing. Stainless headers always glow ( about 600* EGT and higher ) but steel i believe takes about 800 or 900 to start to glow. You normally dont see it on a N/A motor, usually a turbo were EGT,s are high ---like 900 to 1200. We dyno our race WRX and watch the header, turbo housing and down pipe glow like a B--ch!
What are AL's headers- steel or stainless-- esp. if not coated
Old 11-15-2004, 08:19 PM   #5
sdime 4 life
mikersdime's Avatar
Well after the first test drive, I drove about three miles from my house, and popped the hood. The first thing I see is a bright red Al's Header. I adjusted the thermostat so the electric fan kicks in at a lower temp. and put the thing up on a lift. Flext pipe is torn just below the flange.
Old 11-15-2004, 08:22 PM   #6
SOLD
MX_Racer32's Avatar
got pics?
Old 11-15-2004, 11:48 PM   #7
Registered Abuser
erronisme's Avatar
sounds like you need to double check your plugwires
Old 11-16-2004, 06:09 PM   #8
slowly fast
Stinky's Avatar
Whats for dinner?Sparkplug wires smothered in brake fluid sauce.
Old 11-16-2004, 06:25 PM   #9
gutlesswonder's Avatar
you torn flex pipe is what is allowing it to get soo hot. its letting in air and oxygen and that is basicly suoer heating the header. you see this more with cat's and having a leak around the cat causing is to blow out.
Old 11-18-2004, 03:21 AM   #10
sdime 4 life
mikersdime's Avatar
Got a new flex on there, no more glowing.
Page generated in 0.57092 seconds with 31 queries
[Output: 68.16 Kb. compressed to 63.68 Kb. by saving 4.48 Kb. (6.57%)]
