Any ways to quiet down a noisy lifter?? - S-10 Forum
Old 03-05-2010, 08:57 PM   #1
Qaiphyx's Avatar
Any at all?
Old 03-06-2010, 09:18 AM   #2
It's "Neanderthal"
SH-60B's Avatar
Re: Any ways to quiet down a noisy lifter??
If it's sticking, some guys use ATF in the motor oil to free it up, then change the oil. (Use at your own risk)
I would pull the valve cover first to see if it wasn't a loose rocker, and just to see how dirty the top end is. If it's real dirty, any kind of cleaner can release oil passage clogging sludge. Just my .02 cents
Old 03-09-2010, 08:47 PM   #3
YAMAHA
chevy644's Avatar
atf will work i kno plp that ran it in oil for a half hour and it stopped or id send the pistons strait through the hood then u gota build a bigger n better one
Old 03-10-2010, 01:14 AM   #4
If you only add a 1/2 qt to the engine and don't get crazy with it you will not have any problems. Just add the ATF and drive very gently with it. Then do the oil change. It is not rocket science.
Old 03-10-2010, 10:34 AM   #5
I've got an old 91 Jeep. The lifters rattled like hell when I got it. The 4.0L is famous for that. By replacing 1 of the 6 qts of oil with MMO that racket is gone. (Marvel Mystery Oil) Gramps says they used it in evrything in the army back in the day, and it works like a charm.
My 2.2 doesn't make any noise, but if it did I wouldn't think twice about adding it to the crankcase.
Good Luck!
Old 03-10-2010, 10:48 AM   #6
Lifts are for 4wds!
andysutt's Avatar
I don't see why adding ATF would blow up a motor...
MMO is good stuff however.
Old 03-10-2010, 07:59 PM   #7
Your right it won't, unless there was a problem to begin with. It is a very good detergent and cleans great.
Old 03-10-2010, 08:03 PM   #8
^ a lot of people use a qt of atf instead of oil when they first get a vehicle without knowing the oil change history. It has better detergents in it than oil, a bit harsher so it cleans very well. I would not recommend doing it more than once or twice in your vehicles life, because it is harsher but just once will clean it good and no harm done.
Old 03-10-2010, 09:29 PM   #9
A CLEANMACHINE's Avatar
if not mistaken,use seafoam for sticky lifters and rings when added to crankcase will clean dirty parts too.1 1/2 oz. per quart of oil.
Old 03-10-2010, 09:59 PM   #10
2001 S-Dime
01LilRed's Avatar
u can also try Slick 50....i used that in my 305 i had in my old silverado....lifter was too far gone but it did quiet it up for a period of time....seafoam works.....good luck tho
Old 04-13-2010, 02:26 AM   #11
Ted
Yes, the magic elixi's are good, I use mavel mystery oil. But I have had several of these vehicles that ticked, on the duke I took apart the roller lifters and cleaned them internally one by one, they sure had gunk in them. On another, I found the previous owner had pushrods the wrong length by aprox. 3/16" and was "adjusting" the lifters by leaving the stop bolts on the rockers loose! Iknow this is late, but may help in the future?
Old 04-13-2010, 03:48 PM   #12
Better post-em.
comics22's Avatar
Good Luck!
hmm did the jeeps ever quiet down before you put the MMO in it?
my truck before its warmed up and the oil thin their all chattering making a heck of a noise till the engines warmed up then its quiet as can be. would MMO help this? its got 156K miles on it and would like to see it last as long as possible (at least another 2 years min lol)
i have run seafoam thru the crankcase about once a year or so for the last 3 years and it doesnt seem to help anything. i think once we put a bottle of valvemedic in the crankcase as its supposed to clean out lifters and quiet chattering and it helped for about a week then right back to its chattering.
thursday ill pull the valve cover off and make sure there arent any loose rockers and see whats going on up there.
