Any problems with the 2.2L S10? - S-10 Forum
post #1 of 23 Old 01-19-2005, 10:01 AM Thread Starter
ChopperCharles's Avatar
User is: ChopperCharles is offline
I just bought a 1995 S10 - 2.2L 4-cylinder with 5-speed transmission. Paid $1500 for it (only has 105,000 miles). Anyways, I'm wondering if there are any problems with this particular make and model that I should be aware of. I know the head gasket leak is a problem, but it's usually a leak to the outside of the engine, right? (Better than a leak into a cylinder). I've also heard something about a wiper motor recall and problems with the fuel sending unit, but I couldn't find much information as to whether those were isolated cases or it's something that the trucks are known for.
The truck I bought is immaculate. It's silver, and except for one small dent and a broken bug deflector, the truck looks brand new. Came with a bedliner and towing package too. Which brings me to another question.... where can I find a replacement bug deflector? Idiot that hooked the car up to the U-haul trailer sat on the bug deflector and broke it.
Anyhow, thanks and advance, and nice to be here!
Charles.
1995 S10 2.2L Regular cab 5 speed
1998 S10
2.2L Extended cab 5 speed
1984 Honda V65 Magna
1978 Honda CB550
1987 Yamaha TW200
http://www.choppercharles.com
post #2 of 23 Old 01-19-2005, 10:08 AM
User is: guestuser is offline
Re: Any problems with the 2.2L S10?
they are slow.......
post #3 of 23 Old 01-19-2005, 10:16 AM
User is: Cutlass1984 is offline
I got my '95 extended cab 2.2/a4 for 200 bucks.
It seems i have experienced all the typical problems with this truck.. nothing major really.
Leaking head gasket/cracked cylinder head. Not sure which i have.. I know im getting a small amount of coolant in the #3 cylinder. That plug fouls after a while but other than that it isnt really harming anything.
Timing chain and tensioner seem to go after about 100k miles.
2 of my injectors started leaking pretty bad.. Fixed it with some used ones.
Did the starter, but that happens on all cars.
All in all a nice truck, begging for a small block.
Sorry, your signature image was too large. Please click here to view the specifications before adding another picture.
'84 Olds Cutlass - Olds 350/th350 - B&M shift kit - Flowtech headers - 2.5'' exhaust, magnaflow mufflers - Performer RPM intake - Comp Cams XE256H cam & Lifters - Moroso Adj. Vacuum Advance - 3.08 Gears
'85 Olds 442 - Not driving..
'95 Chevy S-10 - 2.2 - 4.10 gears - PVC pipe intake
|t|o|r|q|u|e|
my anti-honda
post #4 of 23 Old 01-19-2005, 10:48 AM Thread Starter
I know it's slow. That's not what I asked. 30mpg is more important to me than speed in a truck. I've got motorcycles for speed.
Starter has already been replaced, so I'm good on that.
Charles.
1998 S10
1978 Honda CB550
1987 Yamaha TW200
post #5 of 23 Old 01-19-2005, 11:29 AM
Pushrod for life!
pare_john's Avatar
User is: pare_john is offline
Send a message via AIM to pare_john Send a message via MSN to pare_john
The only problem with the 2.2L is the 2.2L
1992 Chevy S10, 3.1L V6 5 speed. Bored .40 over, 272 crane cam, heads ported,polished,plained. Decked block. Port matched intake.
Valve job. High compression pistons. Roller rockers. AFPR. Compression 9.5/1. 3.43 rearend. 2/2 drop. Taurus E-Fan
www.s-series.org
post #6 of 23 Old 01-19-2005, 12:19 PM
gutlesswonder's Avatar
User is: gutlesswonder is offline
you guys are being absolutely worthless to this guy. he is being serious and you are just f in around . i have a 01 so i couldnt tell you about any problems that occur on a 94-97 sorry
post #7 of 23 Old 01-19-2005, 02:29 PM
Forum Dictator
What?'s Avatar
User is: What? is offline
my buddy has 96 dime over 96k still runnin strong all stock, no replacement except fluid changes and a filter instead of air box, as long u baby em, it'll be ok, but we have common problem, egr valve, water pump, parts will eventually wear out. when it does we can help u out how to receive, replace them :thumbup: congrat on gittin the 2.2
R.I.P. Grant ('82-'02), BagNDragS10 ('80-'06), Loenuff ('66-'07), Terryl ('57-'09) Gearstix ('93-'10), Gimp ('84-'16)
If you have any problem, issue, thread/post change, request. Feel free to PM me.
What? is offline
post #8 of 23 Old 01-19-2005, 06:42 PM
User is: zaathur151 is offline
Send a message via AIM to zaathur151
I have a 94 auto first year they came out with the 2.2L s-10 and it has 100,000 and i love it no problems runs like new tight. Seams to have planty of power i can run 85 easy down the highway. And gets ok gas milege takes about 23 bucks to fill.
02 s-10 xtreme 2 door step side 4.3L v6 auto
post #9 of 23 Old 01-19-2005, 08:23 PM
User is: Milwaukee Don is offline
WTF... Where are you getting your gasoline at??? My truck's got a 19 gallon tank and gas in Milwaukee is $1.90 per gallon right now... You do the math
post #10 of 23 Old 01-19-2005, 08:31 PM
Broke N Fixin It
jdttd's Avatar
User is: jdttd is offline
Send a message via AIM to jdttd Send a message via Yahoo to jdttd
I got a 2.2 and it made it a whopping 160k before I started haveing problems. It will Last as long as you treat it right it will treat you right. Goodluck and congrats on the new truck Welocme!!!!!
95 S-10 Extended cab ~UNDER CONSTRUCTION~
~Clear corners~white face Gauges~Gauge Bezel~Rear Pan~
3D Euro's~Third brake light
jdttd is offline
post #11 of 23 Old 01-19-2005, 08:34 PM
I'm madly in anger with u
St. Anger's Avatar
User is: St. Anger is offline
Send a message via AIM to St. Anger
$1.90 X 19 gallons = $36.10. so $23 sounds right.
Anyways, like everyone says just keep the fluids changed and filled and dont try and race anyone, not worth even trying, it will treat you good.
I have had mine for 2 yrs now and no major problems so far, runs strong very dependable.
Good luck! :thumbup:
Anger
I never knew you
But then who really did
If you were at all like me
You managed to keep yourself hid. - Warren Haynes "Patchwork Quilt".
St. Anger
post #12 of 23 Old 01-19-2005, 09:32 PM
slowly fast
Stinky's Avatar
User is: Stinky is offline
The timing chain+tensioner is generally the main problem with the head coming in second.Congrates on the new ride!I would treat her to a can of Seafoam via a vaccum tube and a good set of plug wires and you'll be good to go!
Trucky truck pics
Lurker at large...
Stinky is offline
post #13 of 23 Old 01-19-2005, 11:00 PM
meyers2211's Avatar
User is: meyers2211 is offline
Send a message via AIM to meyers2211
i had 156k when the motor went ran it low on oil, it would drip and leak but only things u got coming are the timing chain, **Cat converter**, and jus overall maitience grease the front end, and always change ur oil
post #14 of 23 Old 01-19-2005, 11:28 PM
User is: Krzysiek is offline
http://www.lukclutch.com/support/bul...l?number=LB135
1995 S-10 ext. cab 2.2L 5-speed(T-5) 4/5 drop 150,000miles
Krzysiek is offline
post #15 of 23 Old 01-20-2005, 09:26 AM Thread Starter
What, exactly, goes wrong with the timing chain? What signs should I look for, and what's going to happen? At least it's not a damn timing belt... hate those things...
Also, "grease the front end"... grease what in the front end?
Charles.
1998 S10
1978 Honda CB550
1987 Yamaha TW200
post #16 of 23 Old 01-20-2005, 09:32 AM
slowly fast
Stinky's Avatar
Charles.
The tensioner for the chain is a cheap platic peice o' crap.It goes back and causes the timing chain to"slap" because there is not enough tension one it.Eventually it will jump timing.Its a very audible noise.Sound like a cross between a rod knock and a ticking valve.It generally will quiet down after warm up.There should be grease"zerks" in the front suspension.Ball joints,control arm...just top em off and check them for rips and tears.
Trucky truck pics
Lurker at large...
Stinky is offline
post #17 of 23 Old 01-20-2005, 01:06 PM
Forum Dictator
What?'s Avatar
and also keep greasin up yer suspension too, check for bushing, ball joints, any wornd part on suspension so u can git it fixd, aligned if necessary then rotate tires n cruiiiiiiiise as long as u can
What? is offline
post #18 of 23 Old 01-20-2005, 03:09 PM
Chillin, Dang.
klurejr's Avatar
User is: klurejr is offline
95 and 96 have a recall for the wiper motor, I know cause I did some research, my 98 has the same wiper motor issue, just no recall offered from the factory.
I personally would remove the bug deflector, that is the one thing on a car that makes me gag more than donut size tires on a 69 impala.
klurejr is offline
post #19 of 23 Old 01-20-2005, 03:12 PM
CHANGE YOUR EMAIL ADDRESS
Slow2.2S10's Avatar
User is: Slow2.2S10 is offline
engine is fine, it's all the other crap. idler arm, loose door hinges, rattling interior oh the list can go on and on and on.
post #20 of 23 Old 01-20-2005, 03:23 PM
User is: marcusm88 is offline
The exhaust flex pipe... They break loose from the bracket and cause a nasty sounding exhaust leak... Not hard to fix, but the pipe isn't cheap.
post #21 of 23 Old 01-20-2005, 03:43 PM
Actually a Camaro person
72 Z27's Avatar
User is: 72 Z27 is offline
Mine does the same, but doesn't quite down after it warms up, people say that some 2.2's have piston slap.
72 Z27 is offline
post #22 of 23 Old 01-20-2005, 05:47 PM
Campin In Style
zibzer's Avatar
User is: zibzer is offline
-water pump goes easy
-not sure what years the wiper recall is... best bet is to call local gm dealer
-engine will last Loooong time if properly maintaned
-after about 160,000 the valve cover gasket may need replacing (no big deal)
- some ppl get amazing gas milage.. others get HORRIBLE gas milage... not too sure why thaT is.. noone seems to know
-dont let it overheat.. the head gasket will leak easy
-some people have had probs with sideview mirrors coming off on small bumps
-it can tow its far share.. but not a racer.. dont even bother making it a racer
sorry i cant be of much more help :/ i got a 98 which is a bit different than the 1997 and under models.
1998 Sonoma Sl 2200 sfi - Auto Tranny
*Taurus Fan * 56mm TB * Custom (Homemade) Air Intake * Camper Style Truck Cap
zibzer is offline
post #23 of 23 Old 01-20-2005, 05:49 PM
Chillin, Dang.
klurejr's Avatar
I forgot to mention that one.
Had mine go out last year.
2007 Chevy Colorado 60k miles
2000 s-10 4.3L Blazer, 214K miles
2004 Subaru wrx STI, 102K miles (currently disabled)
klurejr is offline
