ABS light comes on at high speed! - S-10 Forum
post #1 of 5 Old 04-24-2004, 12:08 AM Thread Starter
KC10Chief's Avatar
User is: KC10Chief is offline
I have a 96 S-10 with a 2.2L and 5 speed. I know some of hte S-10's had wheel speed sensors on all four wheels, and some only on the back. Anyways, when I get on the highway, my ABS light always comes on. It doesn't do it in town. Only when I get up around 55 or 60mph. I stays on after that until I start the truck again. My guess would be a wheel speed sensor. Any ideas? How can I troubleshoot this? Thanks! Matt
Matt F.
1996 Chevy S-10. 2.2L 5 Speed.
260,000 miles as of October 2015
http://i74.photobucket.com/albums/i2...s/DSC02117.jpg
Oklahoma to Alaska in a 96 S-10!
http://www.s10forum.com/forum/f42/dr...e-pics-471322/
2002 Chevy S-10. 2.2L automatic (my son's truck)
143,000 miles as of October 2015
post #2 of 5 Old 04-24-2004, 12:13 AM
User is: poconojoe is offline
Re: ABS light comes on at high speed!
your S10 only has wheel speed sensors in the front, not the back. It uses the speedo signal to determin the rear wheel speed. Check for loss or bad wheel bearings in the front or get the codes to see which srnsor is giving the false signal
post #3 of 5 Old 04-24-2004, 12:18 AM
Pressurized 2.2 Member
GoofyGuy's Avatar
User is: GoofyGuy is offline
Send a message via Yahoo to GoofyGuy
the sensor for wheel speed is in the trans to tell the truck how fast your going your wheel sensors take that signal and compare it to how fast your going and tell the abs system to jump into action if something is not right. there is a sensor on both front and one singal for the back wheels. You have a sensor failing or it may just be off center and is wobbling at those speeds. Check the codes and I bet its a sensor.
GoofyGuy is offline
post #4 of 5 Old 04-24-2004, 07:33 AM
2000 s-10zq8's Avatar
User is: 2000 s-10zq8 is offline
Send a message via AIM to 2000 s-10zq8
my dads 2000 s just had same problem. they hooked it up to a scanner at the dealer and it said it was the rear speed sensor(not the vehicle speed sensor,the abs sensor). it was reading a small difference. they ended up running a couple of tests on it,and determined it to be the pcm. his truck was out of warranty, but because it is emission related item, it was covered still. just something to check
post #5 of 5 Old 04-24-2004, 08:00 AM
It was the speed sensor for the speedometer. They have no seperate one for the ABS in S10's. The ECM sends the a signal to the ABS control to tell it how fast the rear wheels are turning. Look under you truck, there are not wires going to the rear end or driveshaft. There is a sensor is located in the side of the transmission, this is the one that the ECM uses on S10's to determine, the speed. By knowing the tire diameter and rear end ratio, it calculates, the rotational speed of the wheel and sends that signal to the ABS. If you had rear wheel speed sensors, your ABS light wouldn't come on, when you change rear end gear ratios, only your speedomter, would be off. It does come on. The only rear wheel drive vehicles, that have rear wheel speed sensors are ones that have traction control or true 4 channel ABS and those vehicles have seperate line lines to each side of the rear axle. S10's never had either of these options
