ABS code # 265 Electronic Brake Control Module Motor relay Circuit? - S-10 Forum
post #1 of 61 Old 03-19-2011, 08:47 PM Thread Starter
code_red63366's Avatar
User is: code_red63366 is offline
Ok so I took the time to search for this issue on the forums, with not much luck. This is the code Im getting from the ABS scanner. The truck is a 2001 2.2 flex fuel, manual transmission, disk brakes up front and drum on the rear.. My ABS light along with my brake light pops on and off at wierd times. Driving , stopping,etc... It gives me the 265 code "Electronic Brake Control Module Motor Relay Circuit". I was wondering if anyone else has had this issue and what you did to go about fixing it. Most of the post's I have seen have been about the sensors in the front of the wheels for the ABS. I have not seen anything for this particular code, that is unless i overlooked it. Any help will be gratefully appreciated. Thanks
post #2 of 61 Old 03-21-2011, 07:13 AM Thread Starter
Re: ABS code # 265 Electronic Brake Control Module Motor relay Circuit?
Is there a link that supports ABS codes somewhere on the internet? Been doing alot of searching and not much luck.
post #3 of 61 Old 03-21-2011, 08:28 AM
always something new
S10dude's Avatar
User is: S10dude is offline
means the ABS control module under hood has an issue with circut...i.e. sensor loosing connection..................mine does same thing
All truck pics
S10dude is offline
post #4 of 61 Old 03-21-2011, 09:01 PM Thread Starter
Thanks S10dude. I will check out all the connections and mae sure there plugged in all the way.
post #5 of 61 Old 04-02-2011, 09:11 PM Thread Starter
Hmmn,, well I took the time to remove both wheels today and clean/test both ABS sensors on my truck. They both checked out OK and cleaned (and NO I did not use brake cleaner on the sensors, but instead just cleaned them the old fashion way, with a rag, a tooth brushand and water.), I cleared the code and GUESS WHAT???? Still have the ABS problem, SOOOOOO its was not the sensors. NOTED*
Mike...... 2001 S10 2.2, Flex fuel, 5 speed, base model, all stock
2nd vehicle.......2003 Ford Excursion, 5.4, gas, 4 wheel drive, all stock
post #6 of 61 Old 04-02-2011, 09:21 PM
2Low2Tow
GmcNoma95's Avatar
User is: GmcNoma95 is offline
Exclamation Re: ABS code # 265 Electronic Brake Control Module Motor relay Circuit?
Make sure your Sensor Connector Harness(es) (should be a 3way harness) aren't torn and/or binding...there could be a short in the actual harnesses themselves, which would require installing new ones(splicing/soldering which is the best way to do electrical work then use the shrink tubing/conduit)! Next time use CRC Electrical parts cleaner non-flammable avail at any autoparts store! Good luck!
PROJECT NOMA ~UNDER DE-CONSTRUCTION!~
1) 2/3 DrOp Kit
2) Rebuilt 4L60E Trans. W/ Performance Parts.
3) Rebuilding a 2.2L into a Stroker motor
Re: Driveshaft vibration when pulling out???? Quote: Originally Posted by s10xtremist Stop pulling out.
Originally Posted by rimara View Post
People are willing to help you...they just don't want to burp and diaper you.
post #7 of 61 Old 04-02-2011, 09:27 PM Thread Starter
Thanks GMCNoma, I did take the time to trace the wires up to the frame and check for that, all was good. I replaced these sensors when I 1st bought the truck, thinking that it was the fix yet abs light was still on. that's why I posted the exact code number and all, thinking I had a problem elsewhere besides the sensors ( I cannot see them going out after only 2 years). Next step will be the actual abs module on the drivers side fender.
post #8 of 61 Old 04-03-2011, 08:41 PM
2Low2Tow
GmcNoma95's Avatar
That could be the problem, ABS Module could be malfunctioning!
1) 2/3 DrOp Kit
post #9 of 61 Old 04-03-2011, 09:12 PM
Registered Hoosier
Hoosier Rick's Avatar
The code is for the ABS relay. The bad news; the relay is in the ABS module. Probably gonna need a module replacement.
2002 rcsb, 2.2 at, 267,000 miles
1967 C10
post #10 of 61 Old 04-04-2011, 10:53 AM
2Low2Tow
GmcNoma95's Avatar
Yeah, knowning your luck it is the relay, but since your in there anyways theres no point in doing it half ass. You just might as well just replace the entire ABS Module (box), cause you dont know when that module could go or something else happen to it. Have your vin # ready Call you local Dealerships parts dept. and grab the part number for the ABS Module Assembley. Compare prices with OEHQ.COM , They do free shipping on orders over $75, and use Coupon/discount code OEHQ2011 (no spaces) at check out. Just stick with GM/AC-DELCO parts, just do more diagnostics to be sure it is the relay and inspect the ABS module assem. to make sure you arent gonna need anything else before installing a new one! Good Luck!
1) 2/3 DrOp Kit
post #11 of 61 Old 04-04-2011, 09:25 PM Thread Starter
Thanks for the responses here everyone.It was a huge help!!!
post #12 of 61 Old 04-04-2011, 09:45 PM Thread Starter
Oh, I figured I would add this link for people who search for this thread code/issue. This link tells it all and can simply end up being a cheap fix ( I will see if it works out for me and reply, anyways here is the link:
http://www.automotivehelper.com/topic503743.htm
post #13 of 61 Old 05-02-2012, 03:03 PM
User is: Alan D Moore is offline
Common relays have solenoids in them so I would say your code could be the same as mine. I hope you do check it out and see if you can fix yours the same way I fixed mine.
post #14 of 61 Old 05-02-2012, 04:04 PM Thread Starter
Alan. i looked up the modulemaster website , yet didnt have much luck finding info on a repair manual for taking apart the ABS, Im guessing you may have talked to a tech? Or did I overlook it?
post #15 of 61 Old 05-03-2012, 12:26 AM
On the modulemaster you click as if you were going to send it to them where they show you how to remove it. Pretty much you just unplug the electric stuff, remove the 4 star screws, and pull the module off the hydraulic valve block. You should still be able to drive your truck without the module on it. That site also shows you which module unit you have to see if it is repairable. I hope you have the same one I have but I assume if you have an unrepairable one then you would have to buy a new one.
http://www.modulemaster.com/en/abs/kh325_310_30.php
post #16 of 61 Old 05-03-2012, 06:42 AM
http://www.modulemaster.com/en/Chevy/index.php
post #17 of 61 Old 05-03-2012, 02:25 PM Thread Starter
Thanks Alan!
post #18 of 61 Old 05-03-2012, 03:30 PM
Registered Un-dependent
Mechnix's Avatar
User is: Mechnix is offline
I had that code on my son's truck and got 1 from the S10 Warehouse for $30 shipped and it only had 11K miles on it, but that was about 3 years ago...Still works great
Mechnix is offline
post #19 of 61 Old 05-03-2012, 10:35 PM Thread Starter
30 bucks!! Darn,,, how do i miss things like that? Im gonna try alan's fix for 0 bucks... but will give them a look if it doesnt work,, thanks Mechnix
post #20 of 61 Old 05-05-2012, 09:41 AM Thread Starter
Ok, so last night I decided to tackle this fix and see if I could pull it off. I removed the abs brain from the truck and then proceeded to take the silver cover off the top of the brain. This was the hardest part for me as it was a real mother to take off but I managed to get it off without destroying the pc board inside. Once opened up, i examined the solder joints and couldnt really tell if there was any bad solder's . I went off Alan's post on this fix about re soldering the 4 main power feeds to the board along with what ever else i though wasnt looking right (2 more solder joints, not sure which ones) and resoldered them, then put the box back together without sealer to test it and see what I got. I now have a steady abs light on at all times on my dash as before it just flickered on and off, so im guessing it did have solder joint issues and that i was able to fix them. Just to bad that it didnt fix the entire ABS issue but by doing Alan's fix, im sure I saved myself alot of money. Im thinking now all I have to buy is the pump motor in it. The code is still P0265 and a new pump for it used is 150 bucks up to about 375 bucks (^%$#) wished there was a way to be able to rebuild those? Im sure there is , just that it is beyond my ability. Im posting pictures of the job . Once again Thanks Alan, im sure you saved me a ton of money!
ID:	125032   Click image for larger version
ID:	125033   Click image for larger version
ID:	125034   Click image for larger version
post #21 of 61 Old 05-05-2012, 09:45 AM Thread Starter
Picture number 1 shows where the abs pc board is located, yes inside that shiny metal box where it says abs ecm
Pic Number 2: To get this connection off you have to use a screw driver and pry out on it and down away from the unit at the same time(The pink clip looking thingy), then once it release's you can push in on the retention plastic prongs and it comes off.
Pic Number 3: I know it is hard to see but where I drew the red circles on this box, those are the six screws I removed (4 outside of the pump piston box and 2 inside the pump piston box.)
Pic Number 4: What I have circled in red here is where I did the repairs with some flux and solder.
Notes: It is a real pain in the arse to get this cover off of the brain box. How I did it was use a razor knife and carefully cut around all the corners of the edge just enough to penitrate but not to deep as to destroy the PC board inside. It took me about an hour to get this cover off( Hey I was being carefull!!!) Once it starts to become lose you will know but it fights ya all the way till the end. Also I highly recomend a magnifying glass (I used my magnifier app on my phone for it was hard for me to see that small) Um as for sealer to seal the unit back up , I used Permatex Ultra Black RTV High heat silicone gasket maker(yes the very same kind i used on my timing chain cover,oil pan,etc..). It has to be able to take heat and still remain sealed. Also the tools need to get the unit off of the pump body was(4 screws) : T20 star bit torque socket (mine were on pretty tight and a little rusted) and to get the 6 screws out of my unit in order to pry the silver cover off to expose the PC board: T8 star torque driver ( looks like a screw driver but very small.) I know these pictures arent the greatest but it was later at night working on this.Anyone more question, feel free to ask, Im working all day today so I will do my best to get back.
ID:	125036   Click image for larger version
ID:	125037   Click image for larger version
ID:	125038   Click image for larger version
post #22 of 61 Old 05-05-2012, 11:12 AM
I'm going to have to add to my thread to better prepare people on what the are getting into. I was angry and fed up with 6 months of that light being unpredictable so I used a #2 flathead screwdriver and a hammer to get the metal cover off but I was gentle of course.
After you attempted to fix it did you clear the codes? Did you look for any darker brown or black burns in the unit and on the connections/connectors?
Also is your brake fluid old or really dirty? I read it's common for air to get trapped in the abs so I would think if the motor is spinning in air bubbles it could read that it isn't working properly (Just a random idea)
The pump is an electric motor so you can test it...
As codes are just to point a macanic in the right direction...electric motors rarely fail and this one is sealed and the abs is only active in hard braking so this motor is rarely used.
Your code says "Electronic Brake Control Module Motor Relay Circuit" I didn't look at mine that close but can you see the relay? It should be a black or blue box on the board. You should be able to test that relay while it is on the board and see if it works properly I would assume it is a sealed relay so you can't break it open so see it working. I would say the unit already throws codes so don't be afraid to poke at it (with caution of course).
Sorry my solution didn't work out for you but I still believe you can fix it with a little more troubleshooting.
post #23 of 61 Old 05-05-2012, 12:16 PM
I really think we can figure this out or at least find out if your code is one that other should attempt to fix themselves. I am going to pull off my abs module again and see if I can find the pump motor relay and test it. I'll let you know what I find.
post #24 of 61 Old 05-05-2012, 04:58 PM
So I have disassembled and desoldered my ABS unit I will have pictures and a full description of how you will be able to test that relay by the morning. The relay is fairly simple it looks like a 16v 10amp spst relay and I found it for $1.72 + $2.80 shipping (that's a matching part number relay) so lets hope your relay is what is causing your problem. My camera battery died but I should have it all posted in the morning.
post #25 of 61 Old 05-06-2012, 12:10 AM Thread Starter
Sounds good Alan,,, Yes I did attempt to clear the code but it wouldnt let me. No noticable burns on the unit or connectors however I didnt look hard enough at them umm my brake fluid is normal looking, just change the rear brakes out last weekend. As for air being trapped in the unit itself? I have no idea how to figure that out or how to even go about testing it/ I just have a steady non stop abs and brake light on now compared to before when it flickered on and off. I dont know where the motor relay is on it, i thought it may have been on the outside of the brain box? And look foward to your instructions on disassemble on checking the relay. Yes it would be nice to get it fixed, after all I have been driving with it like that now for 3 years.
post #26 of 61 Old 05-06-2012, 08:07 AM
Ok I really hope it is your relay.
Getting the unit repaired by a qualified technician will cost anywhere from $95 to $200 and buying a used unit costs around $150 and up. (Those numbers reflect what I have found but I’m sure others have found better deals)
I find it rare for electrical parts to go bad without some type of abusive heat where the relay is mechanical meaning it has moving parts and of course the contacts in the relay can get dirty, pitted, or just not get good contact. So lets test it.
Note: I am no professional nor am I trained for this. I'm just a 24 year old guy who likes to tear things apart and rebuild them to test and improve my skills but I find my research skills allow me to make any qualifying piece of paper unnecessary.
2nd Note: if your ABS looks to be the same as mine then you can skip down to the relay testing part and skip the disassembly. You really only need to disassemble the unit if the relay tests bad but I had to disassemble it to get the part number off the relay to lookup the datasheet.
It took me about 45min to desolder and take apart the ABS unit. It is difficult and in the pictures you can see why.
So here are the tools I used. I had a 40watt soldering iron and I strongly recommend a smaller tip than the one I used also I used a bulb vacuum desoldering tool (that red thing) to suck the solder off the board. This bulb had a large tip which made it hard to get into the small spaces. I would recommend a different one with a smaller tip to get into the tight spaces.
Taking off the board is a challenge. You have to take off all the extra solder on all the spots where one of the connectors connects to the board and where the solenoids connect to the board. I had to unsolder the solenoids because the were blocked off.
The case was blocking them.
Then you apply a little upward pressure, I used a screw driver, then you just move around heating up the connections one by one slowly allowing the board to separate from the plastic case. Sounds hard but fairly easy with patience (it's a slow process).
This was the hardest spot.
So I got a little rough and had a small mishap but all is good I just glued it back down and when I reassemble it will be just fine. So take you time.
This is everything separated.
So here is what we were looking for, the relay.
So I typed "JSM1-12v-5-H38 datasheet" into google and found the datasheet.
This is an automotive 12v high capacity 15A relay with a 6.3 volt pick-up meaning you need at least 6.3 volts to actuate it. (I used a 9 volt battery)
This is what the datasheet revealed.
I don't know how familiar you are with relays but from the datasheet you should be able to figure out how to test it. Just test for continuity from the com to the no voltage side and then apply 9v to the coils and test for continuity from the com to the voltage side. This picture is me testing the no voltage side with my multimeter. I didn't have enough jumpers to take a pic of me testing the power side with voltage applied but mine tested good.
post #27 of 61 Old 05-06-2012, 09:39 AM
Their is always the possibility that the relay tests good but, when in use, it sometimes works and other times it doesn't or their is an unlikely electrical issue we can't test ourselves. The options are really up to you. It has been broken for 3 years so to spend $5 for a new relay to maybe have it fixed or $150 for a used unit? I would opt for the $5 test and if it doesn't work you lose $5 +the cost of new tools and a few hours of your free time but if you fix it with a new relay the feeling of accomplishment will outweigh all the frustration in the troubleshooting process. Plus you will learn alot. You will definitely know next time something like this happens you will troubleshoot it yourself or pay someone to do it.
post #28 of 61 Old 05-06-2012, 10:21 AM
Also, I don't know exactly what those two blue capacitors go to but capacitors do wear out so if you do decide to replace the relay also replace the capacitors too. One might be to power the motor during startup and restart where the motor is requiring more amps. If the motor isn't getting enough power on startup and restart it will heat up everything which may be why my solder connections cracked?
post #29 of 61 Old 05-06-2012, 11:27 AM Thread Starter
Wow! well done Alan,, sure I dont mind giving it a shot but gotta get a better soldering iron 1st along with a few other things. I use to build PC boards for a company called haywrap in my teens. My biggest prob I had was when it came to repairig a board, it was hard not to burn the board in some form or another,, of course a smaller soldering gun and some good magnifying glasses would cure that and I didnt have that. If there was a bad circuit run, we simply just used a wire and jumped between it then soldered it on. I didnt get into the parts detailed as much as my boss was. But there is a 1st time for everything. Most folks are at a loss when it comes to messing with wiring due to the danger issues that can result as fire and this is what keeps most of us at bay.I have learned a few things about starting electrical fires, safety is always important. So with that being said, yeah your right , if you dont feel comfortable with doing this fix than leave it to a pro and spend the 150 bucks or so .. as for me? Im gonna go for it when I get some free time, plus i plan on having a back up 1st since the truck is my daily driver just incase I screw it up, hek what would it hurt to learn something new. Wiring has always been my down fall when it comes to cars/trucks and it's time to change that. When I take it on I will get ahold of ya,, check your friends request on here.. peace brother!
post #30 of 61 Old 05-06-2012, 11:38 AM
I am really looking forward to hearing about your result. I would like to add this information to my sticky thread to help others. I don't think you need a backup module I would wait for the results, I drove my truck around yesterday and this morning without the module on it (probably around 30 miles). The ABS light is on but the truck stops with no problems and that modulemaster site says it's ok to drive without a module.
post #31 of 61 Old 05-06-2012, 01:19 PM Thread Starter
Your right about being able to run the truck with the module off it as long as the pump box is protected with some sort of covering,, even the GM expert tech's say the same thing... I was reading up on another site on this and there is a diagnose's i did not perform that Im thinking would be a good idea since it is easy to do. They told me to check the fuse and main fat red wire feed to the unit, which I did (even though they insisted it wont always throw a abs light) both looked fine. However another thing they suggested performing was adding voltage to the actual pump itself,, (yeah Im sure you mentioned this somewhere in one of your comments, duh!) but I have yet to have done it. If I hook up power to it and it runs the abs, then the GM expert tech says it is definitely inside my module (aka: brain)which is probably what you have been trying to explain to me all along here. Figure i will do this test just to be sure 1st and then go your route and tear into it again, after aquiring the proper tools, minus the abs unit back up, hek worse comes to worse i will scramble some money up for a rebuilt one... maybe sometime this week or next wekend (I work 2 jobs so I am contantly busy and rarely have time to work on the truck unless i play hooky).
post #32 of 61 Old 05-06-2012, 07:41 PM Thread Starter
Alan, was able to sneak in some time this afternoon and test that motor on the abs box. Im hoping I did it right. I hooked on to the postitive side of fuse box under the hood, unplugged the motor connector (2 wire,black and red) and put some power into the red side of that connector. tried it without the ign on and with ign on. It did nothing. no noise, no vibration or moment. So with that being said, im guessing that the motor itself is no good? Im pretty sure I done it right( done a few test like this in the past before)??
post #33 of 61 Old 05-07-2012, 04:09 AM
So you only put 12v to the red? The black needs to be hooked up to a ground. Just touch the black wire to any exposed metal or bolt. The motor isn't self grounded. The ignition being on will make no difference being that the power wire to the fuse box will always have 12v.
post #34 of 61 Old 05-07-2012, 09:15 AM Thread Starter
I thought about that and went back out and tried that,,,,,still nothing.
Even used a test light to make sure I had power..... I did.
post #35 of 61 Old 05-07-2012, 02:17 PM
If you hooked up power to the motor and it didn't do anything then you have your problem. I wish it was a cheaper fix, I wonder if you can just replace the motor itself? Changing out the entire pump valve block is a pain with all the bleeding you would have to do. I still have my module off so I'm going to go test my pump motor later today or tomorrow and see what it does.
post #36 of 61 Old 05-07-2012, 07:48 PM Thread Starter
Alan,, I brain farted here, I didnt have a good ground like i thought I did. I just went outside and took a test light with me to make sure all my connections were good and they were, then I added power and ground to the motor and it worked. Apparently I did not have a good ground from the other day. So the pump motor does work. I took the liberty of taking the unit off the truck also and I covered the connector wires and unit itself from the elements. Next.... go back into the box..
post #37 of 61 Old 05-07-2012, 11:55 PM
All my suspicions on the DIY fix so far have been correct, I like that. Knowing what we know so far, I'm fairly sure it is your relay on the board. I am definitely looking forward to you switching it out.
I don't know if your relay will be the same as mine so make sure before you order one that you check the one on your board. It was easy to find mine online and the relay price in post #24 is accurate.
post #38 of 61 Old 05-08-2012, 07:10 AM Thread Starter
Hopefully I will get some free time here soon to pull that apart and replace it.Im sure there is a way to test those but why bother when the replacement part isnt all that much, I just hope it works.
post #39 of 61 Old 05-08-2012, 05:47 PM
I think this place has it in stock and ships to residential addresses. USPS shipping is the cheapest.
http://search.digikey.com/scripts/Dk...rds=JSM1-12V-5
post #40 of 61 Old 05-12-2012, 11:58 AM Thread Starter
I was told last night by the dudes at radio shack that the way you tell is they are bad other than testing the capacitors is by a visual. the top part of them (silver part) will be swelled up along with possibly the side. Mine were fine , not sure on the relay as I have yet to figure out how to test the volatge side. Working on getting a used module now since the old module board is toast, thanks in part to me. Posting pictures.
post #41 of 61 Old 05-12-2012, 12:08 PM Thread Starter
The mistake and.....
The evidence... Im sure there is a proper way of doing this, im just not aware of it?
post #42 of 61 Old 05-13-2012, 10:07 AM
I had one of the rings do the same thing but I noticed it and got it off. It's in one of the pics I posted. Do you think you will be able to put a small jumper wire to fix those?
post #43 of 61 Old 05-13-2012, 12:09 PM Thread Starter
Doubt it,, Im in the process of getting a used module right now... once I get it, i will do the test like you described... I know there has to be a trick to getting those 6 prongs out all at once ... something the pro's have to use or know, that I dont know about.
post #44 of 61 Old 05-13-2012, 12:12 PM Thread Starter
I could take it to this place and have them fix it, but then it defeats the purpose of me doing it myself. It will be a little while before I can get a used box, unless I find one for a steal somewhere, but when I get one, I will check back in with you....Alan.. this isnt your fault by all means, its a live and learn lesson and I knew what I was getting myself into when i took this on,,, so with that said,, I really appreciate all your help with this. A year or so ago i posted this and wasnt able to get an exact fix other than shelling out the cash for a used or new model.... You my friend Have been a huge help! Where gonna get this thing figured out one way or the other.
post #45 of 61 Old 05-13-2012, 02:41 PM
Mechnix's Avatar
When you multiple soldered connections like that you have to heat them all at the same time, hard to do with 1 soldering iron-gun
Mechnix is offline
post #46 of 61 Old 05-13-2012, 07:26 PM Thread Starter
Tell me about it,, Hopefully a wiring pro see's this post and shares some tips and secrets on doing it. When you send it off to a place to have it rebuilt, they gotta do it, so it can be done, just how?
post #47 of 61 Old 05-14-2012, 10:48 AM
Mechnix's Avatar
you heat them all at the same time, you could rig a multiple tip desoldring rig or get more hands and irons working @ the same time....it's just solder
I'd be reluctant to try an open flame but with a pinpoint flame and even heating you could probably heat them all at once.
The best thing to use is un-soldering wick or a suction device to get all the excess, then there won't be as much resistance
Slowly working-rocking it up with only slight force...
But It only takes a few extra seconds of heat to de-laminate the copper rings and traces -not good
Mechnix is offline
post #48 of 61 Old 05-14-2012, 08:24 PM Thread Starter
I use both of these. I just lefted the soldering iron on too long.
post #49 of 61 Old 05-16-2012, 06:52 PM
Getting back to Boosting
badaSS98's Avatar
User is: badaSS98 is offline
All you have to do is wick the solder up once you heat it to liquid. Do that for each one at a time. Easy breezy. Nice troubleshooting. Once your abs light stayed soild was it like that as soon as you started the truck, or did it stay soild once you started to roll like 5mph
badaSS98 is offline
post #50 of 61 Old 05-16-2012, 10:01 PM Thread Starter
As soon as I started the truck and then on it stayed solid up until about day 2 and then it went off and then back on again along with the E brake light.
