a/c questions ?? please help !
Old 08-18-2008, 04:40 PM   #1
knottys10's Avatar
knottys10 is on a distinguished road
i have a 1995 s10 2.2 and i cant get the ac working !!! the a/c pump will not spin when i turn on the switch inside the truck ! any ideas why ?
thanks for your help !
Old 08-18-2008, 04:50 PM   #2
got a new grille!
rockyroad217's Avatar
rockyroad217 will become famous soon enough
Re: a/c questions ?? please help !
you're more than likely out of refrigerant because of a leak..there's a pressure switch on the high pressure line that cuts the compressor off once it gets below a certain amount
Old 08-18-2008, 04:52 PM   #3
knottys10's Avatar
i went and out and bought a recharger for it and its holding pressure !
Old 08-18-2008, 04:55 PM   #4
Afterhours Admin
AVTekk's Avatar
AVTekk is on a distinguished road
you need to get it serviced, theres not much you can do if it isnt working
Old 08-18-2008, 04:58 PM   #5
knottys10's Avatar
ok thats kinda what i was thinking but had to ask anyways ! thanks for your help !
Old 08-20-2008, 06:02 AM   #6
bagged95(702) is on a distinguished road
i thought the pressure switch kills the clutch when the pressure builds... hence the cycling it makes under normal operation...anyway yea you need a r-134 machine cause those cheap kits from the auto store and like if you need a quick shot of gay. but the machines will actually suck it down and remove the moisture and anything else. and tell you if it will hold a charge with the vacuum gauge. and recharge the proper amount. or if your compressor isnt kicking in i would check the connection on the compressor. should be 2 wires coming out of the clutch on the pully. i think it should see 12v
Old 08-20-2008, 06:14 AM   #7
The How-To Guy
beandip's Avatar
beandip is a jewel in the roughbeandip is a jewel in the roughbeandip is a jewel in the rough
the A/C compressor on the 2.2 doesnt cycle but the one on the 4.3 does.
Old 08-20-2008, 09:28 AM   #8
addicted... to RC !
xdude2001's Avatar
xdude2001 will become famous soon enough
i thought neither one did?.....
Page generated in 0.21044 seconds with 11 queries
