98+ water outlet problems
Old 11-04-2009, 08:37 PM   #1
Resident A-10 Crewcheif
ablues10's Avatar
I cannot find one in stock anywhere! I cant remember who makes it but I checked today and its no one has it on the net either. Every junk yard here doesnt have it. My problem is, the heater core line that plugs into it is leaking. its pissing me off.
Old 11-05-2009, 05:23 AM   #2
not low enuf
slowrider1983's Avatar
Re: 98+ water outlet problems
The one that goes from the front of the motor to the firewall? I have one for sale. Email me at slowrider1983@yahoo.com I have all the motor and trans stuff I am trying to get rid of off my 2000 noma
Old 11-05-2009, 02:28 PM   #3
ablues10's Avatar
Thats what I need
Old 11-05-2009, 02:37 PM   #4
not low enuf
That's what I have. It oe I blew the motor in my truck so I am putting a 400 sbc so I don't need it. Make me an offer
Old 11-05-2009, 06:40 PM   #5
I'm Back!!
beandip's Avatar
Quote: Originally Posted by ablues10
Thats what I need
is it leaking by the t-stat housing? if it is cant you just solder that?
Old 11-05-2009, 10:45 PM   #6
ablues10's Avatar
its leaking from where the black steel tube goes into the aluminum housing.
Old 11-06-2009, 01:50 AM   #7
Not to dissuade a sale, can you remove the tube and clean up the hole, then tap the hole and screw in a pipe with a bayonet fitting on it? I always look for a way to DIY.
Old 11-06-2009, 06:35 PM   #8
ablues10's Avatar
Gotta have the tube cause the sensor plugs into it.
Old 11-06-2009, 07:43 PM   #9
Hey just thought id say i had the same problem, couldn't find the part. I fixed it with a good high temp 2 part epoxy, pulled the copper hose out of the aluminum water neck clean it and glued pressed back together. 20,000 miles later still holds like a dream
Page generated in 0.56896 seconds with 31 queries
[Output: 66.19 Kb. compressed to 62.09 Kb. by saving 4.11 Kb. (6.20%)]
