98 s10 Starting problems - S-10 Forum
post #1 of 12 Old 07-05-2010, 08:53 PM Thread Starter
User is: 98TenTruck is offline
Question 98 s10 Starting problems
I have a 98 s10, runs fine. I try to start it today and nothing happens. The lights will come on, the check engine light comes on, fuel pump does not turn on, Starter does not engage or even attempt to crank. I jumpered the starter fuse relay and also the fuel pump fuse relay and I could start it by doing that without having to turn the key or push in the clutch. I also tried jumpering the clutch neutral safety switch and that didnt do anything. I think it might be the ignition switch but I am not 100% and I really dont want to rip apart my steering column to find out. Any other Possible things that I could check? Also, my security light isnt on so I dont think that is the problem either. Thanks.
post #2 of 12 Old 07-05-2010, 10:15 PM
It's "Neanderthal"
SH-60B's Avatar
User is: SH-60B is offline
Re: 98 s10 Starting problems
Before going any further clean the battery cables at both ends, pay particular attention to the ground cable.
Teamsters Local 1150
SH-60B is offline
post #3 of 12 Old 07-05-2010, 10:47 PM Thread Starter
I cleaned both connections. Checked ground connections and they are all good. I used a code reader on it and it didnt bring up any codes either..
post #4 of 12 Old 07-06-2010, 02:43 AM
User is: Ryan66 is offline
Does it click at all? MIne did this last week. Everything would come on but wouldnt start just clicked like a dead battery. It turned out to be a loose connection on one of the wires going to the starter solenoid and it was throwin a small spark when you tried to start it
Ryan66 is offline
post #5 of 12 Old 07-06-2010, 10:15 AM
It's "Neanderthal"
SH-60B's Avatar
What's the battery voltage?
SH-60B is offline
post #6 of 12 Old 07-06-2010, 03:52 PM
User is: S10 Guru is offline
Check all your fuses too
S10 Guru is offline
post #7 of 12 Old 07-07-2010, 04:20 PM Thread Starter
I can hear the solenoid click once, I didnt check the battery voltage yet. I hooked up jumper cables to it and still nothing. I mean it starts when you jumper the starter relay and the fuel pump relay so i dont think its a battery issue. I checked all of the fuses and they all checked out to be good..
post #8 of 12 Old 07-07-2010, 05:58 PM
Sounds like what mine did. Crawl under the drivers side and get under the starter and have someone try to start it. See if you see a spark coming off solenoid
Ryan66 is offline
post #9 of 12 Old 07-08-2010, 03:39 AM Thread Starter
okay Ill take a look at it tomorrow morning.
post #10 of 12 Old 07-10-2010, 03:05 AM Thread Starter
Found the problem. There was a short in this little chip in the ignition switch harness.
post #11 of 12 Old 07-10-2010, 09:14 PM Thread Starter
Nevermind, That was still not the problem. Anyone think it might be the PCM?
post #12 of 12 Old 09-09-2010, 01:19 PM
User is: CLEWIS is offline
I Have A 2001 S10 Turn The Key I Hear The Fuel Pump But Nothing Else Sometimes It Cranks Right Up But Most Times I Have To Fool With Key Hold It Down For 15-50 Seconds Maybe More Replaced Ignition Switch Neutral Switch Still Wont Turn Over Right Away
CLEWIS is offline
