98+ 56mm Quad 4 Throttle Body Install
Old 11-01-2009, 05:10 PM   #1
Dropped'01's Avatar
Just got my 56mm quad 4 throttle body off ebay for $20. It came off of a 95 Buick skylark 2.3L.
Throttle Body Cleaning
First thing I started doing is cleaning the throttle body. Mine and many others I have seen are extremely dirty. Items I used for this was Carb Cleaner, Wire brush, and a small wire wheel that connects into a drill.
I also unscrewed the two bolts that hold in the Idle Air Control Valve pulled it out of the throttle body. Once you pull it out there is a small O-Ring which needs to be cleaned along with the Valve and the port due a lot of debris inside.
Tool Needed (Torx Bit Socket T-20).
On the back side of the throttle body is the stock gasket which needs to be scraped off. After I finished scraping off the gasket, I took some light sand paper and went over the area where the gasket was which takes off any left over gasket and makes the surface smooth.
Replacement Parts
Autozone part #‘s
IACVAC138
TPS TPS142 (Throttle Positioning Sensor-Left side of TB)
After that I taped off the TB and painted it with Rust-oleum Aluminum.
Installation-Parts-& Tools
1. Ratchet, extension & 10mm socket.
2. Vacu-Tite! Part #’s 47359 & 47431 (T-ing off Vacuum Line)
3. 10mm X 1” bolt
4. 3 small washers
5. Mini hack-saw
I starting this assuming that you already have your intake off. First remove the 4 Vacuum hoses and unclip the IACV and the TPS. Hoses 1 and 2 will reconnect in same positions on new TB. Hoses 3 and 4 will be connected using a vacuum elbow and T Adapter.
Next remove the 4 bolts that hold on the stock TB. Keep the bolts because you will reuse 2 of them. Also will need to unhook the throttle cable from the TB.
After that the Stock throttle body will come off. Here is the two throttle bodies side by side.
Next reinstall the new TB using two of the original bolts. The new TB will bolt to the intake manifold using the top left and bottom right holes. The third hole is where you will use your 10mm bolt to help hold the throttle cable bracket. My throttle cable bracket didnt mate up perfectly so i used one small washer in between the throttle cable bracket and the TB on on the top right side. I also used two washer in between the throttle cable bracket and the TB for the top left side.
Next reattach hoses 1 & 2 to original positions. Then get the vacuum elbow and plastic T adapter to connect hoses 3 & 4. Also reconnect IACV and TPS.
Last I'm showing how i hooked up my Throttle cable. This TB was off a 95 buick so this part might be custom depending on what car you get the TB off of. Basically the S10 throttle cable was not long enough to hook into the stock position but there was a square hole in the plastic that the ball from the throttle cable would fit in. I took a mini hack saw and cut a small section of the plastic so that the cable could slide through. Also once this is done make sure the butterfly opens/closes all the way with out interference.
Then reinstall intake and start it up.
My truck started up and within 15-20 sec, it was at the usually 950-1000 idle rpm.
Old 11-01-2009, 05:15 PM   #2
Dropped'01's Avatar
Re: 98+ 56mm Quad 4 Throttle Body Install
Hope this helps for the people planning on doing this in the future.
Also here the vehicles from a previous thread.
1988-1995 Buick Skylark
1988-1989 - 2.3L Quad 4 DOHC (LD2) 150HP Model: Custom, Limited
1990 - 2.3L Quad 4 DOHC (LD2) 160HP Model: Custom, Gran Sport
1991 - 2.3L Quad 4 DOHC (LD2) 160HP Model: Custom, Gran Sport, Luxury Edition
1992 - 2.3L Quad 4 OHC (L40) 120HP Model: Base
1993-1994 - 2.3L Quad 4 OHC (L40) 115HP Model: Custom, Limited
1995 - 2.3L Quad 4 DOHC (LD2) 150HP Model: Custom, Limited
1990-1994 Chevrolet Beretta
1990-1992 - 2.3L Quad 4 DOHC (LGO) 180hp Model: GTZ
1993 - 2.3L Quad 4 DOHC (LGO) 175hp Model: GTZ
1994 - 2.3L Quad 4 DOHC (LGO) 170HP Model: Z26
1995 Chevrolet Cavalier
1995 - 2.3L Quad 4 DOHC (LD2) 150HP Model: Z24
1992-1995 Oldsmobile Achieva
1992 - 2.3L Quad 4 OHC (L40) 120HP Model: S
1992 - 2.3L Quad 4 DOHC (LD2) 160HP Model: S, SL
1992 - 2.3L Quad 4 DOHC (LGO) 180HP Model: S
1992 - 2.3L Quad 4 DOHC (W41) 190HP Model: SCX
1993 - 2.3L Quad 4 DOHC (LD2) 155HP Model: S, SL
1993 - 2.3L Quad 4 DOHC (LGO) 175HP Model: S
1993 - 2.3L Quad 4 DOHC (W41) 185HP Model: SCX
1993-1994 - 2.3L Quad 4 OHC (L40) 115HP Model: S
1994 - 2.3L Quad 4 DOHC (LD2) 155HP Model: S, SC
1994 - 2.3L Quad 4 DOHC (LGO) 175HP Model: SC
1995 - 2.3L Quad 4 DOHC (LD2) 150HP Model: S SERIES I & II
1988-1991 Oldsmobile Calais
1988-1989 - 2.3L Quad 4 DOHC (LD2) 150HP Model: International, SL
1990-1991 - 2.3L Quad 4 DOHC (LD2) 160HP Model: International, S, SL
1990-1991 - 2.3L Quad 4 DOHC (LGO) 180hp Model: International, S, 442
1991 - 2.3L Quad 4 DOHC (W41) 190hp Model: 442 W41
1990-1991 Oldsmobile Cutlass Supreme
1990 - 2.3L Quad 4 DOHC (LGO) 180HP Model: International
1990 - 2.3L Quad 4 DOHC (LD2) 160HP Model: Base
1991 - 2.3L Quad 4 DOHC (LD2) 160HP Model: Base
1988-1995 Pontiac Grand AM
1988-1989 - 2.3L Quad 4 DOHC (LD2) 150HP Model: SE, LE
1990 - 2.3L Quad 4 DOHC (LD2) 160HP Model: SE, LE
1990 - 2.3L Quad 4 DOHC (LGO) 180HP Model: SE
1991 - 2.3L Quad 4 DOHC (LD2) 160HP Model: LE
1991 - 2.3L Quad 4 DOHC (LGO) 180HP Model: SE, LE
1992 - 2.3L Quad 4 DOHC (LGO) 180HP Model: GT
1992 - 2.3L Quad 4 OHC (L40) 120HP Model: SE
1992 - 2.3L Quad 4 DOHC (LD2) 160HP Model: SE, GT
1993 - 2.3L Quad 4 DOHC (LGO) 175HP Model: GT
1993 - 2.3L Quad 4 DOHC (LD2) 155HP Model: SE, GT
1993-1994 - 2.3L Quad 4 OHC (L40) 115HP Model: SE
1994 - 2.3L Quad 4 DOHC (LGO) 175HP Model: GT
1994 - 2.3L Quad 4 DOHC (LD2) 150HP Model: GT
1995 - 2.3L Quad 4 DOHC (LD2) 150HP [Model: SE, GT
1990-1991 Pontiac Grand Prix
1990 - 2.3L Quad 4 DOHC (LD2) 160HP Model: LE
1991 - 2.3L Quad 4 DOHC (LD2) 160HP Model: LE, SE
1995 Pontiac Sunfire
Old 11-02-2009, 02:12 AM   #3
I'm Back!!
beandip's Avatar
Sweet writeup man i need to add this to my to-do list
Old 11-02-2009, 02:24 AM   #4
Mr. Token Black
chvys10's Avatar
I got mine off a 1995 Pontiac Sunfire
1995 - 2.3L Quad 4 DOHC (LD2) 150HP Mode .... it was only a 56mm and my buddy took it to his shop, cleaned it out, and bored it out to a 58mm. I got it from my local junk yard for 30 bux and a e fan off of a firebird 25 bux. After that I drove 225 highway miles w/ no a/c and it used less than 7gal of gas!!!
sorry to jack
Old 11-02-2009, 02:42 AM   #5
Dropped'01's Avatar
Thanks man i would definitely say this was as good of mod as my STS pulleys. Its a must have
Old 11-02-2009, 02:45 AM   #6
Dropped'01's Avatar
sorry to jack
No problem man good imput. Im going to see if my mpg gets any better this week but i can already feel the difference in throttle response and power
Old 11-02-2009, 09:46 AM   #7
I've got what may be a stupid question about boring, please forgive me, but does the butterfly need to be replaced if you do bore it out or will it still close...
Old 11-02-2009, 12:29 PM   #8
theGINGERBREADMAN's Avatar
Awesome write-up!! Now that you have done this I will be installing mine thanks to your help.
Old 11-02-2009, 12:43 PM   #9
Dropped'01's Avatar
I think you would need a new butterfly because when its closed it there is a less then paper thin gap in between the butterfly and the inside of the tb. With out replacing the butterfly i dont think the truck will idle correctly because too much air is passing through when its closed.
Old 11-02-2009, 04:00 PM   #10
Dropped'01's Avatar
Hey if your throttle cable hooks up differently then mine or anything else goes differently with your install then post up some pics so we can see.
Old 11-03-2009, 04:12 PM   #11
hondacr125's Avatar
where did you notice improvements in power? and does anyone know how muhc hp this adds? im deff looking into doing this but i cant find one for sale anywhere
Old 11-03-2009, 07:02 PM   #12
Moderator
What?'s Avatar
Look in junkyards with all the vehicle listed above but you need one from certain motor to fit as listed above.
I notice power in all range, my mpg didn't improve but definitely better power adder, not bad at all for the cost.
As far as I know, no one dyno 56mmTb from stock.
Look through eBay, craigslist, backpage, classified or have someone buy it for you and ship it.
Old 11-03-2009, 09:07 PM   #13
Dropped'01's Avatar
As what? said you notice it through the rpm range. My trucks exhaust seems louder and my truck seems to make it up the hills around here better then before the mod. If your doing intake/exhaust then you should definitely do this along with it.
Old 11-04-2009, 04:52 AM   #14
Mr. Token Black
chvys10's Avatar
When I was driving 70-75 on the highway b4 the TB and e-fan mod my RPM's were up to 3K.... w/ the TB MOD and e-fan doing 70-75 w/ 235/40/20 my RPM's were at 2500-2700.
Old 11-04-2009, 05:45 PM   #15
So your saying the 56mm TB mod changed your gear ratio's?
Old 11-04-2009, 07:08 PM   #16
Mr. Token Black
chvys10's Avatar
I was talking to my buddy today, he said between the MODS and going from 18's to 20's did it
Old 11-04-2009, 08:13 PM   #17
yeah going from 18's to 20's will change the overall gear ratio if the tire diameter is bigger...
Old 11-06-2009, 02:01 AM   #18
seems like the cable will hook up the same way as you've got yours. Whats the part number for a replacement gasket that I will need?
Old 11-06-2009, 02:29 AM   #19
Dropped'01's Avatar
You dont need a replacement gasket because the S10 intake manafold has a press rubber gasket. Just use the one that's connected to the intake manifold and you will be fine.
Old 11-06-2009, 10:43 PM   #20
Moderator
What?'s Avatar
TB gasket isn't needed, you also don't need gasket maker for it either.
Old 11-07-2009, 03:38 PM   #21
Moderator
What?'s Avatar
Correct, trans gear, ring/pinion and tire fize affect rpm/mph.
Smaller tire = higher rpm, mileage roll faster
Taller tire = lower rpm, mileage roll slower.
Old 11-07-2009, 08:24 PM   #22
IsuzuTurbo's Avatar
Nice Thtead man
Old 11-07-2009, 08:53 PM   #23
Dropped'01's Avatar
Thanks Man
Old 11-09-2009, 02:51 AM   #24
DMP
DMP's Avatar
Nice write-up. As long as it seals good and the throttle cable doesnt break, I think ill do this mod.
Old 11-10-2009, 12:53 PM   #25
Awesome write-up! I literally just got finished doing this and it's amazing! For the money and time spent, no comparison! I only have one problem, maybe someone can help me with. I have Cruise Control and it mounted up just fine, however, the cable is too short and holds throttle at about 1/4 when bolted up. The plastic bracket that mount to TB looks like it might be adjustable, but I'm kinda heavy handed and have already broken a small piece of the cable pulley. If anyone knows a solution, short of just not having CC hooked up (as it is now) let me know... thanks again for a great how-to!
Old 11-10-2009, 07:57 PM   #26
Moderator
What?'s Avatar
Look at other 56mmTB thread about it, scubadog explained about CC cable part.
I'll have to copy and paste it here.
Old 11-12-2009, 11:41 PM   #27
Mr. Fix-it Perfectionist
my_nightmare's Avatar
Awesome info and write-up here!!! I'm curious. I wonder what yur gas mileage is after the exchange? Keep up the good work there !!
Old 11-14-2009, 02:28 PM   #28
I just installed mine and was wondering if I was supposed to keep the top sensor that was in the new tb in it because I put mine in instead. I also noticed it sometimes sits at a higher idle when I first stop
Old 11-14-2009, 10:00 PM   #29
Dropped'01's Avatar
I guessing your talking about the Idle Air Control Valve (First Pic?). I used the one that came with the 56mm tb . Mine will usually sit at 1100 or so but then once you come to a complete stop it will usually drop down to 950+ within like 3 seconds or so.
Old 11-15-2009, 03:52 AM   #30
k what ill do is switch it back tomorrow and see how that works, thanks again for ur help
Page generated in 0.61605 seconds with 31 queries
[Output: 147.35 Kb. compressed to 135.74 Kb. by saving 11.60 Kb. (7.87%)]
