97 2.2 engine swap ? - S-10 Forum
post #1 of 12 Old 02-06-2010, 04:13 PM Thread Starter
User is: turbobuick2003 is offline
getting ready to do a engine swap and had a ? what i have is a 97 s10 2.2 and was told that it was a odd ball year and only a few yrs would interchange is this true ?if so which yrs will work ? thanks
post #2 of 12 Old 02-06-2010, 07:39 PM
keepin it freshhh
Slowlowandbangin's Avatar
User is: Slowlowandbangin is offline
Re: 97 2.2 engine swap ?
97 is a unique year. iirc, you need a 97 motor only.
Slightly static dropped: SLAB
Totaled
1st Time Around
Follow me on Instagram! @slowlowandbangin
Originally Posted by IhaveNoPantsOn View Post
You shut your whore mouth!
Originally Posted by BlazerZR5 View Post
all straight fact based on observations of your continued retardation.
post #3 of 12 Old 02-07-2010, 12:55 PM
deadman's Avatar
User is: deadman is offline
why? what is the difference from the 94/95/96/?
i would think that a 96 would fit and direct drop... i thought i heard that a 94/95 would work but you need to change a few sensors...? not sure really though.
deadman is offline
post #4 of 12 Old 02-07-2010, 08:45 PM Thread Starter
was wondering the same thing does anyone know what the difference would be ? thanks for any help i can gett on this swap my nephew will be driving soon and im tring to help get him going .
post #5 of 12 Old 02-08-2010, 06:52 AM
keepin it freshhh
97 has a specific cam i know that. people like putting 97 cams in 98+ engines sometims for more power, the 97 has a specific cam that is "desirable"
Totaled
1st Time Around
post #6 of 12 Old 07-06-2010, 07:52 PM
User is: southBAyprerunnin is offline
anyone have a scrap cam i could throw in my 98 s10? lol
post #7 of 12 Old 07-07-2010, 05:51 AM
New Old Timer
MadJack's Avatar
User is: MadJack is offline
The profile on this cam isn't much more in duration than the '98+ cam just to do the swap as is.
'94-97 ('96 & '97 have the required timing notch, for all '96+ motors)
____Int/Exh___
Duration @ .050": 188*/188*
Lobe lift: .288"/.288"
w/ 1.5 rockers:.432"/.432"
Int C/L: 109* ATDC
Lobe Sep: 114*
'98+
____Int/Exh___
Duration @ .050": 185*/185*
Lobe lift: .263"/.263"
w/ 1.6 rockers:.421"/.421"
Int C/L: 108* ATDC
Lobe Sep: 112*
While the '98+ has slightly less duration and lift, the tighter lobe centers build more mid range torque, while the earlier opening bumps the torque peak down slightly.
The '96-'97 cam has more lift and duration, but not really enough to justify a swap to this cam. This cam is the better choice for a regrind though. The lobe can handle more lift for hotter profiles.
The heat treating only penetrates so far into the lobes and this is what limits what can be reground onto the cam. The lobe centers can be move 1 or 2 degrees, but this is determined by how much lobe lift is ground into the cam with the new lobe profiles.
Also the stock valve springs will limit how much lift, rpm and lift rate you can use. The max lift the '97 & older can take is .480" at the valve. The '98+ can only take about .470". The stock rev limits are for the stock cam, if you use faster ramp rates this will limit the rpm more, as will more lift than stock.
MadJack
I'm okay, TILL YOU P!$$ ME OFF!
I've had two other S-10s, previously.
Had my '85 project, till I got hit head on...
A '92 extended cab, I got for my now Ex. She traded it when we had the kid.
On my third, a '93, that's mechanically sound, it's in okay shape. It's slowly getting better, though.
Always working on the 2.2L OHV LN2s and the 60 Degree V6s. If not mine, then someone else's!
MadJack is offline
post #8 of 12 Old 07-07-2010, 10:59 PM
ftccredneckguy04's Avatar
User is: ftccredneckguy04 is offline
my 94 has a 96 motor just have to change places on some sensors not to hard
post #9 of 12 Old 11-30-2010, 10:59 PM
Banned.
compakt's Avatar
User is: compakt is offline
Send a message via AIM to compakt
Im getting ready to swap a 95 2.2 in our 97' s10. we notice a few differences between the motors.... what am i up against here?
compakt is offline
post #10 of 12 Old 11-30-2010, 11:24 PM
billetproof97''s Avatar
User is: billetproof97' is offline
Crankshafts were different too
U.S ARMY MP
97' s10 single cab w/98 front end conversion w/8k's,autopage alarm,red top,shaved doors,dual 480's, 8 gallon/SD arms,slams,SD 3link,SD B&U,airlift, 4 sundown audio E8'sLSX swap, BRPLSX/T-56mount kit-parting out
88'Mustang GT 5.0-trickflow trackheat, trickflow 11R 190's, stockblock w/factory forged pistons,NX Plate kit
R.I.P. Terryl ('57 -'09) you will be missed
post #11 of 12 Old 12-01-2010, 08:09 PM
New Old Timer
MadJack's Avatar
You will be lacking a cam position sensor on a '95 motor, which means you will no longer have the sequential injection. The PCM will revert to batch fire mode, trip the CEL and not go into closed loop mode. The injector harness is different as are many of the sensors and ICM.
From http://www.enginebuildermag.com/Article/2437/rebuilding_the_chevy_22l_engine.aspx
1990-‘95: These engines all used the 1237 casting.
1996-‘97: These engines came with the 4618 casting that is virtually identical to the earlier 1237. They are both interchangeable.
1998-‘99: These engines still used the 4618 casting, but the timing notches were advanced by about 0.450", so the later crank can’t be interchanged with either of the earlier ones.
MadJack
MadJack is offline
post #12 of 12 Old 12-02-2010, 04:07 AM
forgot to specify a year. good info
U.S ARMY MP
