95 S10, missing, running rough, no power - please help! - S-10 Forum
post #1 of 11 Old 03-14-2012, 09:01 PM Thread Starter
User is: Gideon is offline
Hi everyone. I've tried everything and hoping that you folks have heard of this issue.
1995 Chevy s10, 2.2 engine with about 100K miles.
This is my dad's tru8ck and he was driving and it suddenly started to run rough. He got home and I looked it over, and it seemed to be fine, but still running rough.
I changed the spark plug wires, and plugs - and it ran a little better but still rough at idle and would not rev over about 2K. when I press the gas, I can hear it trying, but it acts like a governor - it'll rev up a little then the power just drops out and it starts to fluxuate up and down sort of like it's not getting fuel. under load it runs smooth and does not miss - but only to about a quarter throttle then it's it - it starts to idle up and down and I have to back off.
I've checked - so far...
Coils - replaced them both. Got a third and swapped them just to be sure.
Wires/plugs as well. (new plugs quickly carboned up)
Fuel pressure is in range and solid.
Cat converter is clear and no backpressure issues.
Fuel regulator clear, clean and dry.
No codes. Not even a missfire code (using a paperclip)
Replaced the MAP sensor just for the help of it.
Cylinder pressure test - a-ok.
My mechanic says that all PCM numbers come out okay, and that the PCM is communicating correctly. No codes, all sensors read within tolerances, and he says it's not misfiring - just running rough and weak as a wet noodle.
I've not checked the mechanical timing because of the whole cover off thing - I'll save that chore for last thing, I think.
I did notice that there are two sensors on the passenger side in front of the coil, one high and one lower and slightly further back (that one is not plugged in, not sure what it is and can't find a plug to fit it)
Any ideas?
Thanks in advance.
Mechanic couldn't check the mechanical timing.
. I also had to replace one of the coils, and that helped as well, and now it runs great on all cylinders - but still
Gideon is offline
post #2 of 11 Old 03-14-2012, 10:00 PM
I Prefer Payne
payne4life's Avatar
User is: payne4life is offline
Re: 95 S10, missing, running rough, no power - please help!
try a fuel pressure test. could be a bad FPR causing your to run lean.
2000 SAAB 9-3 2.0t hatchback 5-speed. 145k miles - CURRENTLY ON JACK STANDS
2000 s10 LS X-cab 2.2 flex fuel auto. 170k miles
MODS: 56mm TB, Ebay CAI with K&N filter, E-fan, ZQ8 sway bars, GC steering box, steering shaft u-joint
http://www.cardomain.com/id/brandomonium12
post #3 of 11 Old 03-14-2012, 10:39 PM Thread Starter
THanks, already did that. Honestly I thought it was the problem, but the pressure is in range and solid.
Also, it seems to be running rich, not lean. Soot on the plugs.
Gideon is offline
post #4 of 11 Old 03-14-2012, 10:53 PM
Forum Dictator
What?'s Avatar
User is: What? is offline
Do you smell fuel? Possible fuel injector leaking.
R.I.P. Grant ('82-'02), BagNDragS10 ('80-'06), Loenuff ('66-'07), Terryl ('57-'09) Gearstix ('93-'10), Gimp ('84-'16)
If you have any problem, issue, thread/post change, request. Feel free to PM me.
What? is offline
post #5 of 11 Old 03-14-2012, 10:57 PM Thread Starter
Thought of that as well, nope.
I'm shaking my head, I've got to be overlooking something. Can the timing jump one tooth and it still run?
Gideon is offline
post #6 of 11 Old 03-14-2012, 11:10 PM
I Prefer Payne
payne4life's Avatar
Throttle position sensor?
plugged air filter? or something restricting air?
are all the plugs black or just one?
post #7 of 11 Old 03-15-2012, 04:31 AM
Powder Coat Specialist
xtrememeasures10's Avatar
User is: xtrememeasures10 is offline
Send a message via AIM to xtrememeasures10
Yes it can, it will run like shit tho, very little power. i would check it.
97' w/ 03' Front end, Too many mods to list....
2.2L Build and Powder Coat Project
http://www.s10forum.com/forum/f105/2...ernals-486082/
Check out my Business Powder Coating work.
http://www.facebook.com/makpowdercoating
post #8 of 11 Old 03-15-2012, 06:45 AM Thread Starter
TPS working great, no air restrictions, and all of the plugs are black.
Gideon is offline
post #9 of 11 Old 03-15-2012, 07:35 PM Thread Starter
New info!
I checked the sensors and the Crank Position Sensor was unplugged - but I can't find the plug! It's missing. I have MFI, and should have a plug for the sensor!
Or does it?
Gideon is offline
post #10 of 11 Old 05-22-2012, 04:11 PM
User is: EduardoMk is offline
My truck is a s10 2.2 98, it was running really bad, it seems like governed, gas smell, hard starting, and sudenly stoped and i can't turn it on again... coil spark GOOD, 45 psi Fuel pump GOOD, inyector signal GOOD, Pressure in the cylinder ZERO psi... yes... timming chain. It was broken and that's why my truck started to go in that way, first the chain skip a tooth of the gear, that affect in hard starting, gasoline smelling and governed speed, when the chaing got broken the valves didin't work and the presure went to zero, me advice in this case... check te cylinder presure and the timming
post #11 of 11 Old 06-04-2013, 10:23 PM
User is: Pat01 is offline
i seem to be having the same problem.. i have a 98 s-10 and i have no take off power. when i reach 40 then it runs find. till i hit 70 and it starts bogging down.
Pat01 is offline
