5th gear pop out - S-10 Forum
post #1 of 13 Old 12-20-2008, 02:22 PM Thread Starter
keepin it freshhh
Slowlowandbangin's Avatar
User is: Slowlowandbangin is offline
5th gear pop out
every once of a while, the tranny will pop out of 5th gear. i'll be on the highway and take my foot of the gas and let it coast, and it will pop out of 5th. only happens once or twice a month if that.
it seems to happen most when i am driving above 75 mph, and take my foot off the gas.
also, the shifter sometimes vibrates or gives me a little feedback when i put it in 5th. only sometimes.
all the other gears are sweet. clutch grabs fine and is not sloppy at all.
any ideas???
Slightly static dropped: SLAB
Totaled
1st Time Around
Follow me on Instagram! @slowlowandbangin
Originally Posted by IhaveNoPantsOn View Post
You shut your whore mouth!
Originally Posted by BlazerZR5 View Post
all straight fact based on observations of your continued retardation.
post #2 of 13 Old 12-20-2008, 02:28 PM
I'm slap happy, bitches!
User is: Deeze49686 is offline
Re: 5th gear pop out
if its 2wd, the nut came lose, and you have axial end play from going to loaded/ coast. it makes the geartrain walk forward, thats why you pop it out of gear, 5 gear is in the front of the 5th reverse assembly, when you let off gas, the geartrain walks forward, making the gear teeth move away from the sliding hub which keeps it engaged. unfortunately, you have to take the unit apart to tighten this nut, and while you are there, you might as well give it a freshen up.
need trans info, parts or a complete assembly?
http://www.s10forum.com/forum/f13/de...er-0-a-364411/
I endorse only Transgoâ„¢ valvebody and hydraulic upgrades, and will offer suport on this manfacturers kits ONLY!!!!
email me at deeze49684@yahoo.com
post #3 of 13 Old 12-20-2008, 04:34 PM
got me some 20s
rockyroad217's Avatar
User is: rockyroad217 is offline
mine does the same thing..but its every time im on the interstate and let off the gas to coast..only in 5th gear too..does it hurt anything? im used to it so if it doesn't im not worrying with it
-Ryan
1996 S10 2.2 5 speed, kinda low
http://www.waylayedinc.com
Posting Nothing- Please Wait
post #4 of 13 Old 12-21-2008, 12:11 AM Thread Starter
keepin it freshhh
thank you. do you have any idea of what this would cost to have it repaired??
Totaled
1st Time Around
post #5 of 13 Old 12-21-2008, 09:28 AM
Rarely goes over 20mph
beaniebmx's Avatar
User is: beaniebmx is offline
if your having a dealership, $500 sounds easy, it costed me $250 to have some hoses behind the heater switch on the dash replaced, they whistled after being replaced though, and to have my egr replaced
another $200 to have my ignition module replaced
things i couldve done myself super easy but didnt know what the fixes to the problems were at that time
03 S10 Ext Cab-BD 3.5" bagged- 18/20s its ORANGE
1991 s10 reg cab 5spd- SOLD- biggest mistake
1985 2wd 2dr jimmy-totaled- samwhiched in a 5 car pileup
post #6 of 13 Old 12-21-2008, 09:08 PM
sds 97S10's Avatar
User is: sds 97S10 is offline
I was told this is either the shift fork is bent or the syncronizers (sp.) are going out. Mine started slowly only once in a while but has gotten worse and now third gear is hard to get it into sometimes. I am going to get mine fixed after the first of the year and I will post back what is fully costs. I think I am going to go get it quoted tomorrow if I have time.
I have been putting it off for a while. By the way mine is a 97 S10 2.2L 5spd.
post #7 of 13 Old 12-21-2008, 09:15 PM Thread Starter
keepin it freshhh
yeah sometimes 1st and 2nd are tough on my tranny but i havent had too much experience wit hdifferent manual trannys
Totaled
1st Time Around
post #8 of 13 Old 12-21-2008, 10:39 PM
Works too much!
laydout97's Avatar
User is: laydout97 is offline
I have a 97 2.2 5 speed tranny if someone needs it. It has about 120,000 miles. I have no use for it but it works like a charm. PM me if interested.
92 4.3/700r4 315k- ole red
2011 altima- daily ride
post #9 of 13 Old 12-23-2008, 12:19 AM
sds 97S10's Avatar
Alright I forgot to post back. So here is the deal I took mine to a Trans. shop today and this is what he said.
1. Could be the blocking rings. $250 -$600 out the door.
2. Could be the syncronizers (sp.). Up to $1100.
He said Manuals are hard to diagnose, so the charge $112.50 to take out the Transmission then tear it apart and the call with the problem and final price.
He also said if I bring him a transmission he will pull the old one and put in the new one for $250 out the door.
post #10 of 13 Old 12-23-2008, 05:05 PM
Works too much!
laydout97's Avatar
I still have mine if u need it.
post #11 of 13 Old 12-23-2008, 05:38 PM
ohhhh yeahhhhh
rrray88sdime's Avatar
User is: rrray88sdime is offline
i was gonna say syncros. did that on an ex of mines honda. in 5th gear it would pop out no other gear, and it was the syncrhos, over a g to get a used tranni into it. good luck with it
www.myspace.com/rrray
Pebble Pushers
99 dime- cookie cutter show truck,bagged.
80 c10-daily, slammed.flat black, white walls. red wheels. rat rod yoo
American by birth, Northern by the grace of God, and Lineman by choice.
post #12 of 13 Old 12-24-2008, 09:19 AM Thread Starter
keepin it freshhh
fock lol. i'll just drive it like this and always keep a little pedal in it in 5th. i dont beat on it (all the time lol) so hopefully she'll stay alive.
Totaled
1st Time Around
post #13 of 13 Old 12-25-2008, 01:11 AM
sds 97S10's Avatar
Mine has been doing it for a while has gotten a little worse and I will do something about it whe the money is right. Or I find a cheap local transmission.
