2002 2.2 Timing Chain Replacement - S-10 Forum
post #1 of 11 Old 11-25-2012, 05:56 PM Thread Starter
pingdaddy_1999's Avatar
User is: pingdaddy_1999 is offline
I have a friend that has an 2002 S10, 2.2L.... His timing chain is noisey loud and due to be replaced... He wants me to do it for him, but I haven't put one in before... Can someone walk me through the process? I have read the posts about aftermarket and factory GM replacements and from the sounds of things, one should go with the factory parts...
post #2 of 11 Old 11-25-2012, 06:05 PM Thread Starter
Re: 2002 2.2 Timing Chain Replacement
Also, doe anyone have a good "cheap" source for OEM parts other than the dealer?
post #3 of 11 Old 11-26-2012, 02:55 PM
MEP1's Avatar
User is: MEP1 is offline
In this case you're better off with a name-brand part from an auto parts store than OEM. They'll usually outlast OEM and will still be cheaper.
MEP1 is offline
post #4 of 11 Old 11-26-2012, 04:20 PM
Registered Un-dependent
Mechnix's Avatar
User is: Mechnix is offline
I think you'll find that the OEM will outlast aftermarket by a long ways, most stock chains last well over 100k
Tons of threads on this site of people that used after market and didn't even get 20k out of them.
GM parts direct or sites like them give decent discounts
Mechnix is offline
post #5 of 11 Old 11-26-2012, 05:29 PM
It's "Neanderthal"
SH-60B's Avatar
User is: SH-60B is offline
^ This
BTW, "GM" is a pretty good name brand.
Teamsters Local 1150
SH-60B is offline
post #6 of 11 Old 11-26-2012, 07:11 PM
2.2 Extremist
GMC Motorsports's Avatar
User is: GMC Motorsports is offline
don't cheap out when it comes to timing components. EVER.
I'd only use dealer timing chain assemblies.
2000 GMC Sonoma SLS
ECSB 2.2L Flex Fuel L43 bored 0.40, 0.20 head shave, 5-Speed, 4.10 gears, Space Blue Metallic, Graphite Int, OBX Header, straight pipe cat delete, Thrush Welded, urethane motor mounts, ZQ8 sway bars, Hurst Short Throw Shifter, ClutchMasters 9lbs flywheel
Other Rides: 09 Canyon 5.3 ZQ8, 05 Duramax, 85 Monte Carlo SS.
post #7 of 11 Old 11-26-2012, 07:15 PM
always something new
S10dude's Avatar
User is: S10dude is offline
get your OEM Parts from gmpartsdirect.com at a good price !
All truck pics
S10dude is offline
post #8 of 11 Old 11-29-2012, 11:52 AM
User is: Ed98 is offline
See this post #3 and #5 below it for tips.
Also to remove the fan, I use a large crescent wrench on the fan (it loosens the normal direction), and hold the pulley with a large screwdriver wedged in the 4 pulley bolts.
If it has an automatic transmission, someone else can tell you how to hold the engine while breaking loose the camshaft bolt. I have a manual, and it's not a problem.
Labor Rates: $35/Hr. If you watch: $45. If you help: $55 If you tried to fix it yourself first: $95
Ed98 is offline
post #9 of 11 Old 11-29-2012, 02:59 PM
User is: Snakejumper is offline
Be prepared to use an impact wrench to remove the camshaft bolt. It'll save your knuckles & elbows.
post #10 of 11 Old 11-29-2012, 03:06 PM
I used a 13" fence pipe added to a breaker bar.
Ed98 is offline
post #11 of 11 Old 11-29-2012, 03:59 PM
Check out this post & see if it helps.
http://www.s10forum.com/forum/f105/h...-chain-368017/
