2000 s10 knock sensor replacement? - S-10 Forum
post #1 of 8 Old 12-20-2011, 10:56 PM Thread Starter
Catrell92's Avatar
User is: Catrell92 is offline
How hard is it to replace? And where exactly is it located? I'm also. Trying to replace both. O2 sensors . 2.2l motor on 2000 ext cab, thx guys. Also when I place both parts will the SES light go away or do I need to have them removed in order to clear the light. I hear slight knocking noise only when I press on the gas and listen closely, knock sensor right? Other than that motor runs great!
post #2 of 8 Old 12-21-2011, 12:33 PM
User is: johndb is offline
Re: 2000 s10 knock sensor replacement?
The knock sensor will detect a knock it doesn't make one, the knock is coming from something else.I didn't think 2.2's had knock sensors but I'm not sure on your year.You will need to get the truck scanned to see why the SES light is on.
johndb is offline
post #3 of 8 Old 12-21-2011, 01:29 PM Thread Starter
Catrell92's Avatar
But I thought it prevents the truck from knocking, hence, adjusting the fuel mixture to prevent pinging, if it's not working correctly it would prevent it right? Also I got em scanned it was an emissions code, knock sensor, and o2sensor
post #4 of 8 Old 12-21-2011, 06:49 PM
It's mostly BS
rimara's Avatar
User is: rimara is offline
It's located behind the oil filter and looks like this:
http://www.rockauto.com/catalog/moreinfo.php?pk=1113536
2001 S10 2.2 5sp ext cab
Don't hit and run...let us know how you fixed it!
rimara is offline
post #5 of 8 Old 12-21-2011, 09:00 PM Thread Starter
Catrell92's Avatar
Does replacing of the sensor require any flushing of oil or coolant or anything?
post #6 of 8 Old 12-21-2011, 09:13 PM
It's mostly BS
rimara's Avatar
No. Torque it to 14 lb-ft.
rimara is offline
post #7 of 8 Old 12-22-2011, 12:44 PM
I would call knocking and pinging two different things, if your knocking just by revving your engine I don't think the knock sensor would stop that, but I don't know for sure. After you change the sensor please post back to let me know. I may learn something new. Good luck!
johndb is offline
post #8 of 8 Old 12-22-2011, 01:00 PM Thread Starter
Catrell92's Avatar
I hear slight knocking ONLY when I accelerate, I'll try to get it changed 2mrw
