2000 S-10 2.2....What other engine works? Getting mixed answers! - S-10 Forum
post #1 of 3 Old 10-09-2010, 10:40 PM Thread Starter
User is: ohios10extcab is offline
Question 2000 S-10 2.2....What other engine works? Getting mixed answers!
Figured you guru's would know the answer to this? I bought a 2000 s10 2wd ext cab last week and found out the motor is locked up! So I've been looking for a used motor and the prices are out of this world! Best deal I found so far was $650 for one with 203k!
Anyway...I have been told two things and dont know who to believe...
#1. ONLY a model year 2000 engine from and s10 will fit
#2. An 01 or 02 sunfire or cavalier motor will work (same block) but you gotta swap out a bunch of parts.
Please send expertise!
post #2 of 3 Old 10-10-2010, 07:53 AM
New Old Timer
MadJack's Avatar
User is: MadJack is offline
Re: 2000 S-10 2.2....What other engine works? Getting mixed answers!
All the 2000 and later (2k+) motors were the same on the inside, it is the externals that would change.
#1. Any 2k+ truck motor will work. I'm not sure if the Flexfuel motor is a drop in replacement, but it would convert easily, mostly just swapping sensors and/or other external parts.
#2 This is an option on 2k+ motors. You would have to swap the intake manifold (unless that is the intake you want to run), the exhaust manifold, the water manifold, water neck and one of the head freeze plugs. You will probably need to swap-out most of the sensors also and possibly the Ignition Control Module.
You could use a '98 or '99 motor, but the EGR and water manifolds would have to be swapped. A J-Body motor can also be used, but all the externals would have to be swapped over. The '97 and older motors were a different design (heads, cam, pistons, etc...) and would not swap easily.
Either way, you should only need to take the needed parts from you motor and put them on the new motor.
I'm okay, TILL YOU P!$$ ME OFF!
I've had two other S-10s, previously.
Had my '85 project, till I got hit head on...
A '92 extended cab, I got for my now Ex. She traded it when we had the kid.
On my third, a '93, that's mechanically sound, it's in okay shape. It's slowly getting better, though.
Always working on the 2.2L OHV LN2s and the 60 Degree V6s. If not mine, then someone else's!
MadJack is offline
post #3 of 3 Old 10-10-2010, 08:49 AM
i saw what you did there!
fast68chevy's Avatar
98 and up was new design but the yards will only sell you a 2000 to 2003 s10 engine
anything else requires a lot of swapping parts etc.
we just got done swapping a 2002 s10 2.2L out that died
we could only find two good lower miles junkyard s10 2.2 engines and they wanted 850 for each
it took forever to find them too.
we have a low miles 2.2 from a 98 cavalier i cut up earlier this year but we opted not to use it
way too much swapping work and time involved
the truck was a customers and we wanted to do the job as close to correctly and perfectly as possible and also quickly
without any risk
too much gamble on whether the engine would accept all the truck accessories and brackets
the 2.2L did have alot of running changes and redesigns over the years,, more than you can ever imagine.
