2000 Chevy S10 No start - S-10 Forum
post #1 of 8 Old 05-02-2012, 12:21 PM Thread Starter
User is: ColumbusGaTech is offline
Okay..this is going to puzzle some brains. I have a 2000 Chevy S10 2.2 that will turn over but not crank. I have replaced the coils,ign module,plugs,crank sensor. I have 45-50 psi of fuel pressure while cranking, and around 43 just turning the key on. I have 140-150 compression on all four cylinders. I am showing no codes. All my data is within specs. I have sprayed the throttle body with ether, and still will not start. There are no security issuses, and does not seem to have any computer errors. It will try to crank with WOT, but to no avail. I know that WOT will shut the injectors off. I also have a good strong injector pulse, (test with my noid light). All the components are there to make this thing run, but cant get it to. Could this be a possible timing issue, i dont believe so because of my compression is strong. Any help or ideas would be greatly appreciated. Thanks, Rusty oh yeah..i do have spark
post #2 of 8 Old 05-02-2012, 09:36 PM
code_red63366's Avatar
User is: code_red63366 is offline
Re: 2000 Chevy S10 No start
" that will turn over but not crank" ?
"45-50 psi of fuel pressure while cranking"
you lost me there. Did you mean will turn over but not start up?
Is this a motor you rebuilt and placed in the vehicle yourself? and Yeah this has me puzzled too.
Mike...... 2001 S10 2.2, Flex fuel, 5 speed, base model, all stock
2nd vehicle.......2003 Ford Excursion, 5.4, gas, 4 wheel drive, all stock
post #3 of 8 Old 05-02-2012, 11:03 PM Thread Starter
yeah..i mean it will turn over..but not start up. and yes right at about 50 at the fuel rail, while trying to start the engine
post #4 of 8 Old 05-02-2012, 11:11 PM
Registered Hoosier
Hoosier Rick's Avatar
User is: Hoosier Rick is online now
Is this a code 4, or code 5 [flex fuel] ? I think the flex has higher fuel pressure requirements.
2002 rcsb, 2.2 at, 267,000 miles
1967 C10
post #5 of 8 Old 05-02-2012, 11:12 PM
2.2X-10's Avatar
User is: 2.2X-10 is offline
Check the ''grounds'' theres a sneaky one on the back part of the frame
what else can I do?
Borrowed Ideas project
Originally Posted by scrapin_low
Rusitn aint got a lot of tools he has a lot of determination
2.2X-10 is offline
post #6 of 8 Old 05-03-2012, 10:03 PM Thread Starter
not flex fuel...and grounds are tight..
post #7 of 8 Old 05-03-2012, 10:28 PM
Press Z or R twice
Spike G's Avatar
User is: Spike G is offline
do you have spark? have you manually checked if the wire is sending power to the plugs?
1995 2.2 single cab, short bed, 2/3, ZQ8 sway bars, OBX header, Comp Cams 1.6 roller rockers
ASP underdrive pulleys, Taurus E-Fan, CAI
JL Audio for life!
2 gauge wiring 2 12w3v2's XR door speakers/crossovers 500/1 250/1 e1200 all JL. 7 inch touch screen DVD player
PROJECT THREAD!
Envoy needles for sale!
Spike G is offline
post #8 of 8 Old 02-11-2013, 11:27 PM
User is: tommygh816 is offline
I was just curious if u ever found out what was wrong with your truck, mine is doing the same thing everything checks good im thinking its the PCM(seems all it can be is timing). but I do have a dif question also if im test lighting the 4 prongs coming out the ignition module should all 4 light or just the top and bottom thanks any help will be appreciated
