2.2L Turbo Engine Build
Old 06-25-2008, 12:14 AM   #451
boosted 2.2L
cs xtreme's Avatar
cs xtreme is on a distinguished road
Re: 2.2L Turbo Engine Build
I'll try
Old 06-25-2008, 11:55 PM   #452
boosted 2.2L
cs xtreme's Avatar
results:
run 1.
good traction, turbo lag off the line.
hit rev limit or bogged shifting fist to second and second to third
2.194 60' 14.481 @97.97 mph
thats same as last year with a slower 60' and a faster mph
run 2
about the same. did a re-tune was running rich (same as last time)
still bogged on shifting. tried to launch on boost and lost traction.
3.078 60' 15.867 @98.49 mph
run 3
another tune still bogging on shifts
lag on launch
2.239 60' 14.567 @97.20
run 4
more of the same. another tune
2.309 60' 14.549 @98.70
run 5 still bogging
2.268 60' 14.604 @97.41
run six. 2400-2500 rpm launch (small lag)
another tune, might of popped once on a shift.
2.195 60' 14.164 @99.66
started to rain a bit and the lines were getting really long in the staging lanes so i decided to call it a day after run 6
Old 06-26-2008, 12:01 AM   #453
2.2L turbo
idriz's Avatar
idriz is on a distinguished road
very nice what psi u running
Old 06-26-2008, 12:23 AM   #454
i need a paint job
s106banger's Avatar
s106banger is on a distinguished road
well it looks like some more tunning is in order...your 60 foots arent amazing, i did better with my open 3.08.
you are the fastest 2.2 s-10 now though...
keep up the good work!
Old 06-26-2008, 01:42 AM   #455
Trackside Support Vehicle
S-10Driver's Avatar
S-10Driver is on a distinguished road
cant wait for the times with the tires.
w/ some more tuning and tires i'd say you'd be pushing high 12's.
my stock 2.2 has about the same 60' times. lol
Old 06-26-2008, 01:53 PM   #456
boosted 2.2L
cs xtreme's Avatar
still 11
Old 06-26-2008, 01:54 PM   #457
boosted 2.2L
cs xtreme's Avatar
I've done better 60's but if i launched on boost this year it would (did) break loose.
Old 06-30-2008, 01:03 AM   #458
squeekin sleeper 2.2 turb
turbo4xtreme's Avatar
turbo4xtreme is on a distinguished road
just wondering on a stock bottom end , wat boost would u recomend running...ive been pussyfooting mine until i felt comfortable with it, i havnt been over 8
Old 06-30-2008, 09:18 AM   #459
boosted 2.2L
cs xtreme's Avatar
lots rerally depends on tune
if you have a good tune i'd say 10 is safe.
but too much timing or not enough fuel at that level will cause a problem
Old 07-02-2008, 11:34 AM   #460
gutlesswonder's Avatar
gutlesswonder is on a distinguished road
That trap is good for a 13 all day if you can get your launch right. I think a good set of tires ie: slicks and a good traction bar set up and you should be in the 1.9 60' range and easily break 13's. 12's are still a little far off but a mid 13 is definately possible!!
Old 07-03-2008, 01:25 PM   #461
boosted 2.2L
cs xtreme's Avatar
got my slicks and put the drive shaft loop on last weekend.
so now we'll see what happens with traction off the line
Old 07-03-2008, 04:47 PM   #462
and chips
beandip's Avatar
beandip will become famous soon enough
I cant wait to see the new numbers!
Old 07-03-2008, 06:46 PM   #463
Headknocker
99street10's Avatar
99street10 is on a distinguished road
x2
Old 07-05-2008, 10:21 PM   #464
Deaf Mod
What?'s Avatar
What? is on a distinguished road
what's the track/air temp difference from this run and your last year's run
keep it up, work out all the kinks and tune
Old 07-05-2008, 10:28 PM   #465
paint color? ... Mud =D
83blazer28's Avatar
83blazer28 is on a distinguished road
baddd assss
but 14.16 @ 99.6 is still slow compared to almost anything else with a turbo
Old 07-05-2008, 10:35 PM   #466
boosted 2.2L
cs xtreme's Avatar
I wish i knew exacts
seems they dont post air temp on the slips when its only a test and tune.
Old 07-05-2008, 10:39 PM   #467
boosted 2.2L
cs xtreme's Avatar
Quote: Originally Posted by 83blazer28
baddd assss
not at this altitude
stock dsm's do 15-16's
srt 4's are lucky to get a 14 anything
not to mention both run more boost that I currently do
the wrx (not stI) does 14.8-15.2 at this altitude
also consider my weight 3305 lbs with driver
not sure what the new turbo cobalt ss does but I know it runs more boost and makes less power
Old 07-06-2008, 10:16 PM   #468
live.. die.. nN get drunk
dart_06's Avatar
dart_06 is on a distinguished road
stock cobo's are slower than srt's.. and i cant wait for #'s either!!! lol
Old 07-12-2008, 05:58 PM   #469
boosted 2.2L
cs xtreme's Avatar
7-12
pueblo motor sports park
temp was about 100
R/T .162
60' 2.003
330 5.659
1/8 8.815
mph 76.95
1000 11.553
1/4 13.869
95.41 mph
1-2 and 2-3 it missfired like it did the first night
traction was good but i launched at 2300.
I didnt adjust my rear brakes enough to keep it from trying to spin on the line.
trans brake and line lock would be really nice right about now.
it has more in it but that was not a night to set records.
after that pass i had heat soak. then I was battling a head wind
Old 07-12-2008, 07:53 PM   #470
dart_06's Avatar
sounds promising!!! i bet u can get quite alot outta her.
Old 07-12-2008, 09:49 PM   #471
speed127 is on a distinguished road
hey cs.. I have a brand new line lock sitting in my garage that I was going to use on my Spirit R/T but never did.... I'll donate it to your cause if you want to pay shipping... say like $9 ??? If you can use it pm me your address ....
Old 07-13-2008, 01:43 PM   #472
meyers2211's Avatar
meyers2211 is on a distinguished road
he will be 13's i don't see 12's happening without a good amount of work.
edit jus saw the 13 second slip.
Get ur 60ft down to 1.8's or better
cs extreme i would concentrate on weigh reduction.
Roll pan or step shavers. Move the battery to the rear. remove spare everthing. Take out everything possible. Drivers manual, the 1lb of extra change, spare jack and tire, extra brackets under the hood on the tutu.
It took me over an hour but i removed the big steel bumpstops in the rear they weighed i think 6lbs each.
It want 12's u should be trapping over 105
Old 07-13-2008, 02:23 PM   #473
Deaf Mod
What?'s Avatar
i can forsee 12s, dont forget people, this is at milehigh drag track and still have lots to do to near perfection
cs, do you still have that DOT hose on front brake line? if so, you can replace it with dot stainless steel lines of same length, that'll help you out a bit
also, when does your track will close for the winter time?
Old 07-14-2008, 09:16 AM   #474
boosted 2.2L
cs xtreme's Avatar
I think october.
Old 07-14-2008, 09:19 AM   #475
boosted 2.2L
cs xtreme's Avatar
12's will happen with not much work.
I'm still on low boost with my small turbo, no weight reduction has been done except for ac removal. I still have my system in it (2 10's amp and box)
I wanted to get to 13's in that form.
now the weight reduction begins
Old 07-14-2008, 11:06 AM   #476
83blazer28's Avatar
13.89 niceee
but how to you get 14.1 at 99.6 and 13.89 at 95.41??
Old 07-14-2008, 01:17 PM   #477
boosted 2.2L
cs xtreme's Avatar
13.89 niceee
little better 60'
2.0 vs 2.1
missfired on each shift slowing acceleration
it would of trapped higher with a lower et if it didn't mess up.
it was also 15-20 degrees hotter effecting intercooler temp and timing
i.e. power output
also a different track
Old 07-14-2008, 04:43 PM   #478
83blazer28's Avatar
ah ok better acceleration but your top speed was a little slower
Old 07-14-2008, 07:02 PM   #479
2.2L turbo
idriz's Avatar
[quote=cs xtreme;5408570]7-12
temp was about 100
R/T .162
60' 2.003
330 5.659
1/8 8.815
mph 76.95
1000 11.553
1/4 13.869
95.41 mph
ahh sweet numbers ,,hope fully ill get mine down
Old 07-15-2008, 06:11 PM   #480
Its definately a solid 13 sec truck. But it will take some work to shave off another second. Like Meyers said above it will take a 105 trap to hit 12's. It doesnt seem like a lot but it is. With a better turbo, better tuning, and the suspension properly set up it is possible. Cant forget about the line lock either.
Old 07-26-2008, 09:32 AM   #481
Acme Co. FTW!
Dozer600's Avatar
Dozer600 will become famous soon enough
Back to page one. Updates?
Old 07-26-2008, 06:08 PM   #482
boosted 2.2L
cs xtreme's Avatar
nothing yet.
only been to the track once since last time and nothing record breaking
Old 07-27-2008, 04:24 AM   #483
