main bearing cap bolts are 37lbs ...measure crankshaft end play by thrusting the crankshaft rearward and then forward to line up the main bearing and crankshaft thrust surfaces and then tighten cap bolts to 70lbs then with the crank wedged forward measure crank shaft end play should be between (0.002-0.007 inches)
rod nuts 38lbs then loosen 1 full turn then torque to 70lbs
head bolts are long bolts 46lbs short bolts 43lbs then tighten all bolts 90 degrees more with a torque angle meter...
