2.2l Motor gods, I need help - S-10 Forum
post #1 of 28 Old 06-15-2008, 08:24 PM Thread Starter
Have a nice day!
ProTouring2.2's Avatar
User is: ProTouring2.2 is offline
Ok so my radiator had a hole in it, which leaked coolant out and caused the truck to overheat. Then it failed to start after being refilled. The block is full of coolant and there is no compression in the cylinders. I was told that this meant a blown head gasket, so I tore everything off the head to replace the gasket, but it appears as if the gasket is still good? As in... it's not broken.
I don't know much about engines, I just know how to take things apart and put them back together. Can you guys shed some light on this?
Pictures for reference:
Head and valves:
Intake ports:
Gasket:
Other side of gasket:
Cylinders (pumping out nasty coolant when the crank was turned)
Am I good to just replace the gaskets, have the head decked and rebuilt, and go? Or is there some other issue I should look for?
Thanks in advance
New whip: '90 240sx hatch with SR20DET and some other stuff...
Co-founder of the Anti-Bag Coalition
"Bags are for groceries"
post #2 of 28 Old 06-15-2008, 08:34 PM
User is: SSBlazerV8 is offline
Re: 2.2l Motor gods, I need help
The cylinder on the left is the only thay is not getting water in it. I would have the cylinder head checked for a crack.
post #3 of 28 Old 06-15-2008, 08:44 PM Thread Starter
Have a nice day!
Yeah i'm gonna do all that but the main question I have is, why is the gasket still intact?
post #4 of 28 Old 06-15-2008, 09:14 PM
down to one truck..WTF?
xiffa2003's Avatar
User is: xiffa2003 is offline
Send a message via AIM to xiffa2003 Send a message via MSN to xiffa2003 Send a message via Yahoo to xiffa2003
Good question bro.. im so subscribing to see the outcome.. keep us posted.
Court
Jimmy noSTART but still my shit!
post #5 of 28 Old 06-15-2008, 09:39 PM
Powder Coat Specialist
xtrememeasures10's Avatar
User is: xtrememeasures10 is offline
Send a message via AIM to xtrememeasures10
Mine was fully intact when i pulled mine off. However most of my head bolts were really loose. coolant was seeping out b/t the head and crankcase because they were so loose. I also had a fracture in the head above the #3 spark plug. If i were you i would first off call around town and find someone who will pressure check your head for free or as cheap as possible. If the head passes you might be one of the unfortunate rare cracked crankcase. Im hoping your luck is better than that. It could also be loose bolts too.
wait did you remove the water pump?
97' w/ 03' Front end, Too many mods to list....
2.2L Build and Powder Coat Project
http://www.s10forum.com/forum/f105/2...ernals-486082/
Check out my Business Powder Coating work.
http://www.facebook.com/makpowdercoating
post #6 of 28 Old 06-15-2008, 09:54 PM Thread Starter
Have a nice day!
Ok yeah, all of my head bolts came completely out... they were really loose also. I'm gonna have the head pressure tested
post #7 of 28 Old 06-15-2008, 11:57 PM Thread Starter
Have a nice day!
No, the water pump is still on there
post #8 of 28 Old 06-16-2008, 12:18 AM
User is: Jay02XBlazer is offline
Send a message via AIM to Jay02XBlazer
i have had many head gaskets off cars a lot of subaru's and they always look like there good when you take them off... usually its a hairline crack that causes the issue
Jay
post #9 of 28 Old 06-16-2008, 12:44 AM Thread Starter
Have a nice day!
Ok good, that makes me feel better. New head bolts are in order.
How do I get the coolant out of the block... through the oil drain plug?
post #10 of 28 Old 06-16-2008, 12:54 AM
The reason theres coolant in the crankcase is cause you didnt pull the water pump. Should have read a chiltons! If you pull the water pump all the excess coolant in the jackets will drain out before you pull the head. If it were me i would go ahead and pull the water pump and change it. there only like 20 bones and since everything is all apart you can get to the mating surface to scrape it clean really well. Then drain your oil too while you put everything back together. TORQUE YOUR HEAD BOLTS IAW THE MANUAL! I think your gonna be fine dude. the reason theres coolant in there is just the simple fact you didnt pull the water pump. Its all good i did it 2 when i did the gasket the second time. thought i could beat the manual and save a step. only to find myself changing my oil and sucking coolant out of my cylinders w/ a shop vac lol.
post #11 of 28 Old 06-16-2008, 12:58 AM Thread Starter
Have a nice day!
Ok so no big deal, I'll just pull the water pump tomorrow and add that to the list of parts
Thanks for all the help, it's good to know someone on here can help me. I'm gonna pick up a chiltons manual before I put everything back together for torque specs
It looks like i'm gonna need some sort of reverse torx bolt to do a lot of the manifold studs, since they all came out when I tried getting the nuts off of them
post #12 of 28 Old 06-16-2008, 07:37 AM
Hmm thats weird yours backed out. Yeah go to advance auto they have them in a pack of 7 different sizes. I cant remember which one is the size you need. but they sell 2 different packs, a pack with 7 and a pack w/ like 4. Get the 7. And you'll want to get some anti-sieze for the studs and nuts on the exhaust side. Its also good to put on all your other exhaust nuts bolts and studs under the truck.
post #13 of 28 Old 06-16-2008, 07:10 PM
User is: jemj is offline
All these loose head and exhaust manifold bolts are worrisome to me. Two questions:
1. Could I use lock tight on them without affecting the torque?
2. Could I use a bolt-wire lock retainer from McMaster-Carr?
If these can't be used I'm thinking of drilling the bolt heads and safety wirirg to each other or a stationary point--the way we've done it for years on aircraft. My radiator may have had problems but 4 loose head bolts could have contributed to the current problem...
jemj is offline
post #14 of 28 Old 06-16-2008, 07:40 PM
AcrophobiA
layinlow88's Avatar
User is: layinlow88 is offline
i recommend using silicon for head bolts.....
also....dont get cheap when you buy a water pump....this thing kinda keeps your engine alive ya know....also....your gonna need O2 sensors....antifreeze kills them instantly
Get With it,
Brandt
post #15 of 28 Old 06-16-2008, 08:22 PM Thread Starter
Have a nice day!
Ok good to know. If theres anything else I should look for let me know
post #16 of 28 Old 06-16-2008, 08:37 PM
Do not lock tight the bolts in place. that would not be good. You want to use anti-seize. Layinlow says rtv, he knows his shit use rtv if you want but i was told anti-seize.
I too thought about saftey wiring mine with some .032 wire. But then i figured ya know i got about 150k out of it. If i get another 150k and i have to change it again whatever. by that time the bottom end will be due anyways. So Yeah it would look sexy and defiantly hold just fine. but the only thing i was worried about was under the valve cover. what if the saftey wire snapped and worked its way down into the engine.
BTW what kind of A/c have you worked on. My experience is w/ 757, 737BBJ, emb 145, crj 700, global express, challengers, hawkers, falcons, citations, Leer Jets and gulfstreams.
post #17 of 28 Old 06-16-2008, 09:19 PM
boosted 2.2L
cs xtreme's Avatar
User is: cs xtreme is offline
Send a message via AIM to cs xtreme
dont use anything on the bolts!!!
most bolts will come with something on them anyway or instructions on what to use.
what you put on the threads effects torque.
I've seen early model year 2.0 and 2.2 pull the threads out of the block.
I honestly think someone at gm forgot to do final torque spec on some engines or something
I did a 2000 alero where the rear head was soo loose it burned the gasket out.
most of the head bolts could be removed by hand.
if tightened to proper spec your bolts shouldn't come out
post #18 of 28 Old 06-16-2008, 09:23 PM
AcrophobiA
layinlow88's Avatar
i do agree about the torque deal....but for some applications the bolts run into or around water/oil jackets....i've seen oil leaks that originate from the bolt...oil actually walks its way up the threads...hence the rtv...you still apply the torque ratings to the bolt...the rtv will help hold the bolt in place as well as seal it
Get With it,
Brandt
post #19 of 28 Old 06-16-2008, 09:38 PM
Zq-8_dawg's Avatar
User is: Zq-8_dawg is offline
Does ARP have head studs available for the 2.2L OHV engine?
post #20 of 28 Old 06-16-2008, 09:39 PM Thread Starter
Have a nice day!
yeah and I plan on getting some
post #21 of 28 Old 06-17-2008, 09:04 PM
xtrememeasures10—roger, no lock tight. I was only going to safety wire the exposed head bolts, those were the only ones loose on mine. I’m having to do this at 67K, that sucks.
Worked only Mil Acft; A37B, A10A, KC10A and KC135R, no civilian stuff except of course the KC10 is a converted DC10.
cs xtreme—yea I was afraid I might be getting into a “wet” vs “dry” torque situation. I’ll get the correct bolts and follow all instructions.
Well, last night I took the right wheel off, lowered the truck level as low as my jack stands would go--I'm in a wheelchair. Studied the intake bolts and the nut at the rear of the fuel rail. Thought all day whether or not to take that fuel line loose from the fuel rail or have my brother spend a day taking off those back intake bolts, and we ended up...http://www.s10forum.com/forum/f105/9...stions-356764/
jemj is offline
post #22 of 28 Old 05-13-2009, 07:51 PM
[DCM]Dime's Avatar
User is: [DCM]Dime is offline
question if i have a bad water pump is there some way it could get in the cylinders? cause i had the same problem mine never overheated bad max heat 212? i replaced the radiator added coolant ran fine for about an hour i pulled over to check fluids cause it was running hotter than it should for a brand new radiator about 200 degrees so i stopped topped it off when i started it the engine was running rough sounded like a subaru wrx...was pedleing it than 30 seconds later back to normal drove another 30 minutes was running fine than when i reached my house it started doing it again when i was driving slow i tried to keep it running yet again got to my house and died now it wont start so i pulled the plugs they looked terrible carbon build up and 1 out of four looked like it had coolant/water on it cranked it with plugs out and shot out coolant/water whats my problem guys i need HELP PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!
dumbass clean mobers
post #23 of 28 Old 05-13-2009, 11:22 PM
sounds like a head gasket man.
post #24 of 28 Old 05-13-2009, 11:55 PM
the village idiot
smirnoffmx's Avatar
User is: smirnoffmx is offline
cracked head or a blown head gasket
96 scsb body drop project
98 scsb bagged daily
ELTC nepa
post #25 of 28 Old 05-14-2009, 02:34 AM
User is: highaltitude is offline
either when you first overheated or when you refilled you did not get out air bubbles and overheated head. On aluminum head engines the alumnum heats and expands more than the iron block and can cause the head bolts to lose tension or movement on head gasket. This usually ends badly. If you are lucky you did not crack the head.
Why did it happen after restart? Head cooled back to original dimension and bolts lost tension or gasket was no longer able to seal at all and water leaked into cylinders. Have also seen head cracks that barely leak when hot but dump when head cools as crack opens up.
post #26 of 28 Old 05-14-2009, 01:49 PM
[DCM]Dime's Avatar
well after i restarted it did that than back to normal than when i was pulling in the driveway it did it too idk man just hopein its not a cracked head how much are gaskets and heads anybody know?
post #27 of 28 Old 05-15-2009, 03:14 AM
Forum Dictator
What?'s Avatar
User is: What? is offline
You got blown gasket, you can pick up fairly decent cost of new head gasket kit(I would get ARP bolts as well which you can get thru summit, howellautomotive, other links in performance sticky).
You may not need head but needs to be check, if it turns out ok, do PnP on it for improved flow and power as well since cost of getting rebuild head is the same. Good idea to put 1.6 roller rockers also.
R.I.P. Grant ('82-'02), BagNDragS10 ('80-'06), Loenuff ('66-'07), Terryl ('57-'09) Gearstix ('93-'10), Gimp ('84-'16)
If you have any problem, issue, thread/post change, request. Feel free to PM me.
What? is offline
post #28 of 28 Old 05-16-2009, 01:37 AM Thread Starter
Have a nice day!
Yeah man your head gasket is toast. It's not hard to replace, it's just a pain in the ass and takes a while the first time.
