2.2 camshaft position sensor replacement problem? - S-10 Forum
post #1 of 9 Old 12-20-2009, 06:14 PM Thread Starter
User is: s10guy71 is offline
Now I need to replace the camshaft position sensor on my 98 s10 2.2, i removed the wiring harness, then the 8mm bolt, i remeved it slowly and the sensor split in 2 pieces? Now what to do? I appreciate any help. Thanks!!!
s10guy71 is offline
post #2 of 9 Old 12-20-2009, 07:15 PM
User is: Bobthebiker is offline
Re: 2.2 camshaft position sensor replacement problem?
figure out how to get the rest of it out! how is up to you?
post #3 of 9 Old 12-21-2009, 01:19 AM Thread Starter
Well yes I understand that, I had posted nicely asking for some advice on what to do. I am sure someone had run into this before on their truck. Do i remove the wheel well, remove the sensor, drill a small hole in the second part and pull it out with a auto body dent hammer? Does the engine have to be hot, warm or cold? What kind of metal is the second half made of? copper, steel pot metal etc? I just moved away from my home 1650 miles to be exact, now i have a issue with this and am no where close to home or my shop, where my tools and everything is at. If it was at my shop I wouldnt be posting. Thanks!
s10guy71 is offline
post #4 of 9 Old 12-21-2009, 03:02 AM
Fronk-en-Steen
mostizzle's Avatar
User is: mostizzle is offline
the other half is plastic with a magnet in the middle,my buddy here says he got his out with the engine cold,lots of penetrating oil and a pair of curved needle nose pliers. i imagine you could try screwin a long self tapping screw into it and try pullin it out that way. whatever you do you kinda gotta be careful not to push the other half all the way into the block, good luck
TelAmeriCorp
post #5 of 9 Old 12-21-2009, 01:37 PM
I'd pull the wheelwell, giving you as much room to work as possible without pulling the engine. the other thing I'd do is just use pliers carefully. that plastic got brittle with age, and as a result, broke. screws are just going to make that much worse I'd think. pulling carefully will get it out.
post #6 of 9 Old 12-21-2009, 07:45 PM
4 wheels aren't as fun
serpentracer's Avatar
User is: serpentracer is offline
I wonder if a shop vac has enough vacuum to suck it out?
02 sonoma 4.3L auto
97 sonoma 2.2L manual
post #7 of 9 Old 12-21-2009, 10:32 PM
Fronk-en-Steen
mostizzle's Avatar
if it sucks like ur mom it'll pull the sensor and all the oil out of the crankcase with it i'm jokin bro don't get pissed , maybe if it was a badass vacuum but i doubt it. it's worth a try tho i suppose
TelAmeriCorp
post #8 of 9 Old 12-22-2009, 07:40 AM
she could suck the cam out of that hole.
02 sonoma 4.3L auto
post #9 of 9 Old 12-22-2009, 08:39 PM
Fronk-en-Steen
mostizzle's Avatar
pics? aww who am i foolin,i don't care what she looks like
TelAmeriCorp
