1999 S-10 2.2 5 speed mpg help - S-10 Forum
post #1 of 18 Old 05-28-2010, 12:45 AM Thread Starter
User is: tuff57 is offline
I just picked up this truck, reg cab it's got a 2.2 and a 5 speed. The motor is blown so I will be putting a motor in it. I have a set of e-fans out a buick century, I plan on doing the throttle body change. Do the underdrive pulleys really work? Which are the best ones for the buck? What else can I do to get the best mpgs out of this truck other than driving normal tune up etc. I searched and came up with what I have here just seeing if there's anything else out there. What kinda numbers should I expect?
tuff57 is offline
post #2 of 18 Old 05-28-2010, 01:17 AM
Forum Dictator
What?'s Avatar
User is: What? is offline
Re: 1999 S-10 2.2 5 speed mpg help
ASP pullies. I got slight mpg improvement but definitely mid-high rpm increase. You can check the sticky for further info, install and dyno.
You're already on good path for inexpensive mods to get better power and mpg out of it. It'll depend if you want to spend some more or you're satisfied as is.
R.I.P. Grant ('82-'02), BagNDragS10 ('80-'06), Loenuff ('66-'07), Terryl ('57-'09) Gearstix ('93-'10), Gimp ('84-'16)
If you have any problem, issue, thread/post change, request. Feel free to PM me.
What? is offline
post #3 of 18 Old 05-28-2010, 01:18 AM
Forum Dictator
What?'s Avatar
Welcome to S10forum.com, if you have questions or learn more of the forum's use, you can PM or ask away, .
What? is offline
post #4 of 18 Old 05-28-2010, 01:59 AM
95-s10's Avatar
User is: 95-s10 is offline
Send a message via AIM to 95-s10 Send a message via Yahoo to 95-s10
highflow cat
2.50 tubing to muffler
eletric fan
ported throttle body
plugs/wires
215-65-15 tires
intake
1995 s10 with new motor 5-speed, not driving conservative at all, 90% city stop and go. 20 mpg on fill up and i ran the a/c.
95-s10 is offline
post #5 of 18 Old 05-28-2010, 12:38 PM
Forum Dictator
What?'s Avatar
Don't forget that you have larger tire and your speedo is off which means you have 20+.
What? is offline
post #6 of 18 Old 05-28-2010, 12:48 PM Thread Starter
the tires are 205/65/15 on there now. My plans are the cold air intake, throttle body, pullies, e-fans, new 02s, tune up. And then I'll take it from there once the motor's in
tuff57 is offline
post #7 of 18 Old 05-28-2010, 03:59 PM
95-s10's Avatar
My speedo is like dead on. Tires are pretty small, and he is running factory size.
95-s10 is offline
post #8 of 18 Old 05-28-2010, 04:04 PM
95-s10's Avatar
stock 205-75-15:
sidewall - 5.6
size - 26.3
215-65-15
sidewall - 5.5
size - 26
Just for referance. Our tires are almost the same size, very close, so kinda gives you an idea, something to compare to. Hope this helps.
95-s10 is offline
post #9 of 18 Old 05-29-2010, 12:50 AM
User is: Keith1 is offline
just so i have this straight. the first number is the tread width? the second is the sidewall height? or the persentage versus the treadwidth? and of course the third is the wheel size.
set me straight if im wrong.
Keith1 is offline
post #10 of 18 Old 05-30-2010, 02:40 PM
95-s10's Avatar
1st is width
2nd is sidewall height
A.J.
95-s10 is offline
post #11 of 18 Old 05-30-2010, 05:59 PM
Forum Dictator
What?'s Avatar
Originally Posted by 95-s10 View Post
stock 205-75-15:
sidewall - 5.6
size - 26.3
215-65-15
sidewall - 5.5
size - 26
Oh, I forgot, you don't have 31s on or what's up? I havent check your thread much on www.dezertdimes.com so I'm not update on your current truck.
What? is offline
post #12 of 18 Old 05-30-2010, 11:48 PM
95-s10's Avatar
no longer part of dezertdimes
95-s10 is offline
post #13 of 18 Old 06-01-2010, 04:21 PM
Dropped'01's Avatar
User is: Dropped'01 is offline
I did almost all the mods except the e fan and I'm gettin 25 city 31 highway
'01 S10 2.2L 5 speed, 3"-4" drop, K&N FIPK, Flowmaster, 56mm TB, OBX header, STS Pulleys, Cavi Seats, envoy handles, 8k HID Headlights & Fog Lights, SS Mirrors & Gen III bumper cover, 18" 225's.
post #14 of 18 Old 06-02-2010, 01:56 AM
95-s10's Avatar
^ i can pull that, but i have LED foot and a/c on lol.
95-s10 is offline
post #15 of 18 Old 06-03-2010, 04:00 AM
The Wonky One
Helgaiden's Avatar
User is: Helgaiden is offline
in my 2000 with e-fan, pullies, headers, high flow cat, flowmaster, and 56mm TB im still getting the same mileage as before all the mods. About 20ish city or depending on driving (city/highway mix) anywhere from 260 to 300 to the tank (14 gallons at fill up). If its all highway ive surpassed 320 miles to the tank before.
post #16 of 18 Old 06-03-2010, 11:10 PM
Dropped'01's Avatar
Is your auto?
post #17 of 18 Old 07-29-2010, 07:39 PM
King Tut
JLiRD808's Avatar
User is: JLiRD808 is offline
u try 02 sensors?
[IMG]<a href=http://www.myspace.com/jasonleez target=_blank>http://i36.photobucket.com/albums/e1/Jlird808/0619001549-1-1-1-1.jpg</a>[/IMG]
JLiRD808 is offline
post #18 of 18 Old 07-29-2010, 10:12 PM
Forum Dictator
What?'s Avatar
You should be getting higher, I get 35-40 on highway. Few times I went over 40mpg on flat highway going 55-60mph.
Helgaiden, have you done any tune-up? Likely you'll need o2 sensor as above said. Just Bank 1 on the header.
What? is offline
