1998 s10 keeps throwing P0420 Catalyst System Efficiency Below Threshold - S-10 Forum
post #1 of 20 Old 09-20-2007, 08:59 AM Thread Starter
User is: nicks10 is offline
I was getting P0141 (O2 Heater Circuit Malfunction (Bank 1 Sensor 2)). So I replaced the O2 sensor about a year ago. That cleared the code immediatly. Now I keep getting P0420 codes.
I see that P0420 is Catalyst System Efficiency Below Threshold and "A code P0420 may mean that one or more of the following has happened":
  • Leaded fuel was used where unleaded was called for (doubtful)
  • An oxygen sensor is not reading (functioning) properly (possibly bad sensor again? - i'd expect the P0141 code again)
  • The engine coolant temperature sensor is not working properly (this looked good)
  • Damaged exhaust manifold / catalytic converter / exhaust pipe (cat is not clogged?)
  • Retarded spark timing (i have no idea)
What should I look at next? The cat was not clogged and could see right though it. I've replaced both pre/post cat O2 sensors ~ a year ago.
Inspection is coming due in a few months..... It's a pain b/c it takes ~200 miles for the code to come back!
any help??!!! thanks!
nicks10 is offline
post #2 of 20 Old 09-20-2007, 07:00 PM
tu-tu guru
Chris0nllyn's Avatar
User is: Chris0nllyn is offline
Send a message via AIM to Chris0nllyn
Re: 1998 s10 keeps throwing P0420 Catalyst System Efficiency Below Threshold
sounds like o2 sensor...again
Everything you need to know about the 2.2L- http://www.s10forum.com/forum/f105/2...-pains-321784/
post #3 of 20 Old 09-20-2007, 07:39 PM
User is: lampug is offline
that code means your cat has failed. do u have a scantool or know anyone with a scantool that can read sensor data? if you see the post cat o2 sensor fluctuating like the pre-cat o2 sensor then you know your cat has failed. try this . run your engine until its at optimum temp. unplug the post o2 sensor and probe the signal wire with a multimeter(multimeter only and it has to be set to ac current). you should see a steady voltage if the cat is good. if the cat has failed the voltage will fluctuate from rich to ean or 0v-1v
lampug is offline
post #4 of 20 Old 09-20-2007, 08:28 PM Thread Starter
I have a Actron CP9135, I'm not sure if it can read that data however.
I believe the sensor is 3 wires, what do I probe? Unplug from the truck and probe the sensor?
nicks10 is offline
post #5 of 20 Old 09-20-2007, 08:29 PM Thread Starter
Oh and 1 more thing, can the cat be bad even if it's not plugged up?
thanks for the replies!
nicks10 is offline
post #6 of 20 Old 09-20-2007, 08:56 PM
tu-tu guru
theres a catalyst inside, when all that burns up , yes it can go "bad"
post #7 of 20 Old 09-20-2007, 10:10 PM
yes, they can still go bad even though there not plugged up. unplug the connector and probe the odd color wire. ex: grey, tan, brown. if there are 3 wires then you should see a black, white, and odd color wire. look under and tell me what colors you have.
lampug is offline
post #8 of 20 Old 09-21-2007, 07:10 AM Thread Starter
Sorry, I thought it had 3, it actually has 4 wires.
From the vehicle, it has black, purple/white, brown, and brown/white
On the sensor it self it has white, white, black, and grey
nicks10 is offline
post #9 of 20 Old 09-21-2007, 12:29 PM
Ford guy stuck w/ chebby
n8rsk8r's Avatar
User is: n8rsk8r is offline
+1
n8rsk8r is offline
post #10 of 20 Old 09-21-2007, 05:43 PM
goin broke but n style
S15vortecpwr's Avatar
you need a cat
01 GMC Noma 2.2L auto - SOLD
99 blazer 4dr 2wd - SOLD
GOIN BROKE BUT N STYLE
post #11 of 20 Old 09-21-2007, 05:49 PM
adam46738's Avatar
User is: adam46738 is offline
Send a message via MSN to adam46738 Send a message via Yahoo to adam46738
mine also keeps throwing that code both my o2 sensors are new. i gutted the cat is that why my light keeps coming on?
1999 S-10 Xtreme, 2.2, lowered 2/3
post #12 of 20 Old 09-23-2007, 06:56 PM
User is: britson2003 is offline
I gutted my cat also, my state doesnt require emissions, I need to know what to do to correct this code, would a simulator be the answer? any answers suggestions would be helpful
post #13 of 20 Old 09-23-2007, 06:57 PM
mine is a 2003 sonoma 4.3L
post #14 of 20 Old 09-23-2007, 09:07 PM
94 dime 3/3 drop
seskers's Avatar
User is: seskers is offline
You most likely need a cat but also remember to use only a bosh direct fit or a factory 02 sensor. The univversal 02 are junk.
seskers is offline
post #15 of 20 Old 09-24-2007, 12:52 AM
tu-tu guru
good luck findin an o2 sim...caspers stopped making them
post #16 of 20 Old 09-24-2007, 08:13 AM Thread Starter
I'm going to try the sensors again before going with the cat. Replaced the rear (post) O2 sensor. Now just have to wait 200+ miles.....
nicks10 is offline
post #17 of 20 Old 09-24-2007, 04:10 PM
My 01 cat is gutted and the CEL has not come on for that yet. It is on because I broke the wires on the pre-cat O2. I ran it yesterday and it said only pre-cat faults.
post #18 of 20 Old 10-01-2007, 08:58 PM Thread Starter
Well it's not the sensors, I replaced them under Advance Auto's 1year warranty.
The cat was an aftermarket one, replaced it about 5 years ago. I've ordered a new cat ($130). I'm guessing that's it.
nicks10 is offline
post #19 of 20 Old 10-06-2014, 12:22 PM
User is: shepperd is offline
Riddle me this "Batman". 3 years ago I installed a new 2.2 (not reman) engine in my 2000 S10 (I know a guy at the Chevy dealer who owed me a favor) along with new injectors and fuel pressure regulator (Sorenson).o2 sensors )AC Delco).Fuel pump (Carter). And new cat (Walker, 49 state). 10 months later a p0420 code appeared. No vacuum or exhaust leaks found and no other codes. The truck runs like new (it should with a new engine).Walker replaced the cat at no charge. Last week the p0420 reappeared. Same conditions. I ran a live data test and the post o2 sensor reading were all over the map (between .11--.95 volts). I replaced the cat again and ran another test. The post 02 now reads between .73--.78 volts at highway speeds and .44--.48 volts at idle and the code is gone. My GM tech friends say I need a factory cat ($1000--$2000). My auto tech instructor (the 1 who taught me 30 years ago and is still teaching) and independents say that's nuts and that a Walker or any cat should be fine. Any ideas? Thanx. Shep in Florida.
shepperd is offline
post #20 of 20 Old 10-10-2014, 10:09 PM
Platinum370Z's Avatar
User is: Platinum370Z is offline
Yup, had that issue with my 2.2 5spd and I returned everything I bought from Autozone & Advance and went to chevy and bought the OEM factory o2 sensors, EGR, everything. Expensive but well worth it
