1997 chevy s10 cranks but no start - S-10 Forum
post #1 of 6 Old 06-21-2009, 06:11 AM Thread Starter
User is: redeye45135 is offline
just replaced the timing chain and all that good stuff inside there. now the old chain did snap. i double checked the timing marks. cranks fine but its not starting. checked the plugs and there all getting fire. it backfires out the throttle body. now when i hold the gas pedal down to the floor, and start it, it backfires alot like if it wants to start. well heres a video of its cranking over and you can smell gas like its flooded. has 145,xxx miles thanks
http://s121.photobucket.com/albums/o...t=100_1172.flv
post #2 of 6 Old 06-21-2009, 09:04 AM
1 slo S
95fleet's Avatar
User is: 95fleet is offline
Re: 1997 chevy s10 cranks but no start
Did you check your compression? You probably bent some valves.
95fleet is offline
post #3 of 6 Old 06-22-2009, 04:51 PM Thread Starter
no i didnt check it. im about to take the head off anyways. now when it broke, i was sitting at a red light. the chain is in 2 pieces and bent the tension.
post #4 of 6 Old 06-22-2009, 10:55 PM
Dr. Mike
CRX304's Avatar
User is: CRX304 is offline
sounds like you're 180* off in timing (it is possible)... I watched the video.
97 turd
http://www.s10forum.com/forum/signaturepics/sigpic124065_1.gif
CRX304 is offline
post #5 of 6 Old 06-23-2009, 12:04 AM
User is: budd2049 is offline
I watched the video, and I can almost guarantee you that you've got numerous bent valves. With the way the engine is just freely rotating like that without even trying to fire, you don't have much compression going on at all. Do a compression check; I'm betting most, if not all, of the cylinders will read zero.
budd2049 is offline
post #6 of 6 Old 06-23-2009, 02:53 AM
User is: Danny R is offline
My 97 stripped the gear teeth and I ended up bending every single intake valve in the head. The valves are easy to get from advance auto and are actually fairly cheap from what I remember. They only got slightly bent, but just enough to not allow compression to build up. I can almost guarantee thats what happened. Make sure you replace both intake AND exhaust valves. Pushrods should be fine, and if you replace the lifters, make sure they are pumped up in oil and installed in the right direction (bad experience with my rebuild....expensive mistake!)
Danny R is offline
