1995 S10 SS 2.2L will crank, won't start - S-10 Forum
post #1 of 9 Old 07-17-2013, 11:48 AM Thread Starter
Drewski's Avatar
User is: Drewski is offline
Hey guys
I'm brand new here at the forum and I've been scouring it for answers. I guess I should start out by saying I was given a '95 SS (2.2L) 5 speed around January. I know that it's not a 'true' S10 ss, it's rather weak, i know, but it's my first car. It's been a challenge because it was given to me with no engine in it, trans, fuel lines etc. I have been working on it since then in my high schools auto shop. I finished it up about late June, had to replace the engine (original engine dropped a rod, according to my uncle who gave it to me), clutch, mate the trans and the engine, run some fuel lines, injectors, cooling, and all that good stuff. Anyway, I finished it up around mid June, had to deal with a faulty temp sensor, but fixed it right up and test drove it. It ran pretty strong...for a while that is. After driving it around my high school campus, my dad drove it home while I followed him in our "chase car". We made it 13 miles (5 miles out from home) before it just died. He tried to do a rolling start to get it to turn over but no go. We pulled it over and started checking fuses, plugs, wiring, battery, etc. We eventually called AAA and got it towed back to our house where it's sat ever since. Used a timing light on it, noticed that none of the cylinders are getting a spark, so we went ahead and started checking out the coil packs, icm, crank sensor etc. We noticed that the coil packs were on the lower resistance side of things, so we replaced them. I took my icm to auozone, had it tested about 5 times, it passed every single time. Replaced the crank sensor, still will crank but won't turn over and run. Even checked the alternator just to make sure. I'm getting rather confused and running out of ideas here, any help would be appreciated. I'm just a noob here, don't kill meh!
Thanks in advance guys,
Drew
Drewski is offline
post #2 of 9 Old 07-17-2013, 12:04 PM Thread Starter
Drewski's Avatar
Re: 1995 S10 SS 2.2L will crank, won't start
Quick update, my left turn signal randomly came on when I just had the ignition on, checking gauges, even with the stalk in neutral. Possible short that could prevent it from turning over? Not sure
1995 S10 SS 2.2L 5 speed, summit white
Drewski is offline
post #3 of 9 Old 07-18-2013, 12:41 PM Thread Starter
Drewski's Avatar
Didn't find a short, just a broken hazard light switch. Any help would be appreciated, still don't know whats going on with it.
Drewski is offline
post #4 of 9 Old 07-19-2013, 02:54 AM
User is: 032484 is offline
check if the plugs are getting any spark. Autozone sells an ignition tester that looks like a spark plug for about $8 works great. Also check if you fuel pump turns on when you turn the ignition on.
032484 is offline
post #5 of 9 Old 07-19-2013, 08:42 AM
B4U Task Force
Rhotpursuit's Avatar
Already stated...no spark. op...check Flak7's threads (advanced search). He has a 2.2 that had a no spark issue but I don't remember what the cause was.
U.S.C.G. "So others may live"
Apple Red 96 SS
post #6 of 9 Old 07-21-2013, 04:09 PM Thread Starter
Drewski's Avatar
thanks, will do
Drewski is offline
post #7 of 9 Old 07-30-2013, 10:39 AM Thread Starter
Drewski's Avatar
I haven't been able to find that thread, can someone direct me to it? Any ideas anyone?
Drewski is offline
post #8 of 9 Old 07-30-2013, 10:50 AM
B4U Task Force
pm flak7
Apple Red 96 SS
post #9 of 9 Old 07-30-2013, 07:15 PM Thread Starter
Drewski's Avatar
Alright, I also noticed i have a really loose connection on my starter solenoid, seems like a connector is actually breaking off. Could this possibly prevent the truck from turning over?
Drewski is offline
