1982 Datsun diesel into a late mod S10 - S-10 Forum
Old 08-01-2011, 04:05 PM   #1
Greeting folks,
Not too far down the road I plan on down sizing from my Dodge Cummings Diesel. One of the projects is to re plant a 4 cyl 82 Datsun diesel with its 5 speed manual transmission into a late mod S 10. I know I want an extended cab for the added interior space. To save money I will be looking for a S 10 with a bad or blown engine and or transmission. I look forward to making the change in order to throw away another computer. I have just begun to research what year S 10 I should be looking for. Can anyone help me with information on what years to STAY AWAY from? Is there any web sites that offer info on this kind of transplant? Any info would be helpful.
Have fun,
Buckshot
Old 08-01-2011, 04:42 PM   #2
2005lm7's Avatar
Re: 1982 Datsun diesel into a late mod S10
Looking up the engine you want to use has me worried. Only 3 main bearings in a 4 cyl diesel
I have toyed with the idea of slamming a mercedes 5cyl diesel into an S-10 due to the fact they are basically indestructable and will run on anything remotely flammable it seems lol, not to mention some people are boosting these old beasts to well over 400 hp
I think its a cool idea but id have to have a beefier bottom end for sure, but im no engineer lol.
*edit* SD25
The 2.5 L (2,488 cc) SD25 is the biggest version of the four-cylinder SD series, with the larger bore and stroke of 89.0 and 100.0 mm. It was fitted to Nissan 720 pickup trucks 1983 through 1986 and D21 Nissan pickups (only 1987 in Canada). It was also fitted to the Nissan Urvan and Cabstar. Featured five main bearing crankshaft & redesigned rear main seal.
[edit] this is the engine i would use... basically same but beefier bottom end
Old 08-04-2011, 04:39 AM   #3
2.2 Extremist
GMC Motorsports's Avatar
I'd get an 82-93 S10 to work with for the simple fact there will be less stuff to remove, and Welcome to the forum
Old 08-05-2011, 11:51 AM   #4
Fine Tuning...
LoRollinLS's Avatar
agree with GMC. but 98+ looks waaaay better! lol
Old 08-05-2011, 12:27 PM   #5
2.2 Extremist
^definately
Old 08-05-2011, 04:00 PM   #6
Boozebag
Mad Max's Avatar
GM made a diesel S10 in 83 to 85. They are rare as hell, but are way cool. They used the Isuzu 2.2 diesel, the same as in the LUV.
The biggest consideration you have with a diesel swap is the oil pan. If you don't have fabricating skills, you will find it difficult to do this job. Motor mounts aren't too bad, most of the other fab work isn't either. Cutting and sectioning an oil pan is generally tricky.
Old 08-05-2011, 04:19 PM   #7
Boozebag
Mad Max's Avatar
What you really want is one of these:
1984 Olds 4.3 V6 Diesel. Almost a bolt in. Too bad they are rare as hell.
Old 08-05-2011, 09:43 PM   #8
Spark Plugs Are Overrated
DieselS10's Avatar
I had one of those a few years ago, had a blown head gasket though...
Old 08-05-2011, 10:09 PM   #9
Registered Hoosier
Hoosier Rick's Avatar
If you want a second gen, I would use a 94-97. Pre-bcm. 94 doesn't have air bags.
Old 08-07-2011, 04:11 PM   #10
A CLEANMACHINE's Avatar
you also may consider if your state has emission testing as most of them require same year or newer for motor swap
