Won't Start In Cold Weather - S-10 Forum
post #1 of 26 Old 01-30-2010, 11:15 AM Thread Starter
User is: sotte01 is offline
Question Won't Start In Cold Weather
Well here goes, I have a 86, 2.5L, S-10 long box 4x4 that I have had trouble starting in the winter time. When the temp. is above say 40 deg. it will sart no problem but when it's below that is when I start to have trouble. I put a inline kats heater on it and that will help a little but does not solve the problem. I have good fuel pressure, I have replaced the hall effect switch, dis cap & wire, plugs, manifold & gasket, all the sensors, tried a different ECM, but not the chip, a different coil (used), I have not replaced the power modual although I have one which I can use but usually when they go bad it's all at once. Just wondering if anyone out there has had this problem before and what you might of done to fix it. I'm open to ANY and ALL ideas that might help. Thanks for your time!
sotte01 is offline
post #2 of 26 Old 01-30-2010, 03:21 PM
Wire Splicin Fool :-)
lesterl's Avatar
User is: lesterl is offline
Re: Won't Start In Cold Weather
Check the CTS in the water neck and also the IAT in the intake behind the alternator (both of your ECM's temperature sensors.) Pull a plug after a starting attempt to see what its condition.... Wet/ Black/ Clean/ ETC.
lesterl is offline
post #3 of 26 Old 01-30-2010, 03:56 PM Thread Starter
I have replaced the CTS in the water neck but what do you mean by the IAT? Is that the same as the Idle Air Control Valve up next to the firewall? I don't see any wires or plugs in that area behind the alt.. My alt. is on the front of the motor up next to the fan.
sotte01 is offline
post #4 of 26 Old 01-30-2010, 04:22 PM
bagged 87's Avatar
User is: bagged 87 is offline
its the inlet air temperature sensor. It is in the 1st cylinder runner on the intake right behing the alternator.
Country Folks Livin Loud
post #5 of 26 Old 01-30-2010, 05:50 PM Thread Starter
I have checked my intake manifold and there is no sensors or wires on Any of the intake runs.
sotte01 is offline
post #6 of 26 Old 01-30-2010, 07:14 PM Thread Starter
I also checked the 86 S-10 GM service manual and I don't see any refrence to a "IAT sensor" what so ever. Maybe I'm looking in the wrong section, if there is such a thing do you know what page or section it is in?
sotte01 is offline
post #7 of 26 Old 01-30-2010, 08:30 PM
bagged 87's Avatar
well thats weird. I looked it up here http://www.autozone.com/autozone/cat...&parentId=59-0 for my 87, but it dosent list one for an 86. I guess they made some changes in between years.
post #8 of 26 Old 02-01-2010, 08:57 AM Thread Starter
Any More Ideas???
sotte01 is offline
post #9 of 26 Old 02-05-2010, 10:29 PM
lesterl's Avatar
My bad, no iat on 86 man.....
lesterl is offline
post #10 of 26 Old 02-06-2010, 11:41 AM
Cool, Tight, & STRONG....
Steady Eddie's Avatar
User is: Steady Eddie is offline
Exclamation Re: Won't Start In Cold Weather
WOW--
Learned something new today!!
Wonder how GM controlled spark retard in these year models without the Intake Air Temperature (IAT) sensor?? It must have been based on coolant temperature only...??
That also means that the 86 chip is different, too.
To the original poster: Without an IAT sensor, that means the the reading of the coolant temperature sensor in the t-stat neck becomes that much more critical for a proper fueling at cold start. You can check it with a meter.
Goes to show that GM was changing the specs right along.---
Steady Eddie
1989 S-10
Short Wide
Tech 4 2.5 L.
5-spd Manual
My "tune"--
http://www.s10forum.com/forum/f104/i...2/#post7492162
post #11 of 26 Old 02-09-2010, 11:10 PM
lesterl's Avatar
Yeah, I forgot on my 85 it had no IAT, there ya go!!!!
lesterl is offline
post #12 of 26 Old 02-10-2010, 11:29 AM
User is: jackmp32010 is offline
I had the same problem. I checked everything then I realized it was the IAT
post #13 of 26 Old 02-10-2010, 09:47 PM
lesterl's Avatar
Check posts 7, 9, 11 man....
lesterl is offline
post #14 of 26 Old 02-10-2010, 09:48 PM
lesterl's Avatar
Will it fire up with a shot of carb cleaner?
lesterl is offline
post #15 of 26 Old 02-11-2010, 12:16 AM Thread Starter
I checked the coolant sensor this P.M., with the ingnition on and the wires unpluged with the test leads on the black and yellow it read 5.2V, then I pluged it into the sensor and probed the black and yellow leads with one lead to the wire and one grounded to the frame. The yellow showed 4.27 V and when I probed the black it showed .02V. Should the black show the same as the yellow if the sensor is OK? Hope this makes sense. Also is there a way that you can test if the sensor is OK or not? I have looked, in the manual but it's a little fuzzy on that.
sotte01 is offline
post #16 of 26 Old 02-12-2010, 06:35 PM
lesterl's Avatar
To test the CTS, unplug it, hook your meter across the 2 terminals on the sensor (in OHMS scale.) Compare the reading to the link in signature.
lesterl is offline
post #17 of 26 Old 02-12-2010, 08:35 PM Thread Starter
OK if I understand you right let's say it's 32 Deg. the reading should read somewhere around 9420, is that right? Thanks
sotte01 is offline
post #18 of 26 Old 02-12-2010, 10:15 PM
lesterl's Avatar
Yeppers.... These sensors are known to both read too cold when they fail as often or more often than opening up....
lesterl is offline
post #19 of 26 Old 02-12-2010, 11:54 PM
bagged 87's Avatar
When your trying to start it, does it seem like the starter is having a hard time turning it over?
post #20 of 26 Old 02-12-2010, 11:55 PM
bagged 87's Avatar
I know thats a relatively stupid and obvious question ^^^^^^ but I couldnt help myself.
post #21 of 26 Old 02-13-2010, 07:05 AM Thread Starter
No problem with the starter.
sotte01 is offline
post #22 of 26 Old 03-05-2010, 03:35 PM
User is: tectron1 is offline
It didn't take long to find my posible answer, my 87 is doing the exact same thing
87 S15 Extended Cab (Whats left of it)
2.5L
4 Spd
3.73
tectron1 is offline
post #23 of 26 Old 03-07-2010, 04:40 AM Thread Starter
tectron1, your posible answer IS???
sotte01 is offline
post #24 of 26 Old 03-20-2010, 10:41 AM Thread Starter
Just a note to let everyone know I think I might of found the problem of my s-10 not wanting to start in cold weather. Over the last two yrs. or so I have used the starter quite a lot trying to start it in cold weather and in the process it finally took a dump about a week ago. I replaced it with a new NAPA rebuilt and from then on it has started within the first five sec. or so each time. This morning it was 18 deg. out so I tried it and walla about 3-4 sec and she fired right off. The old starter seemed to work OK but it must of been getting tired or worn out. bagged 87 sorry to of told you it wasn't the starter but I thought it was working ok and shortly after that it died. I have had it at the local shop and they had tried everything they could think of and still didn't help, just lighten my wallet. Thanks for all the help and ideas now I'll start on my wiper!!
sotte01 is offline
post #25 of 26 Old 03-21-2010, 12:49 AM
lesterl's Avatar
Yeah, they get worn out and dont turn as easy (and draw more current when cranking usually as they age.)
lesterl is offline
post #26 of 26 Old 10-12-2010, 05:26 PM Thread Starter
Well I hope this the finall post on this subject. As soon as it started to cool down this fall I started to have problems with the starting when it was cool in the morning. I finally changed the ignition module useing a new GM one that I had gotten on Ebay and that did the trick. The old one was a after market one and was starting to go bad. I have had this problem when I used to run a citiation 2.5 on the mail route. I have tried it when it was 32 deg. out this fall and it starts right off no problem what so ever. Just thought I would relay the information if it might help someone else out.
sotte01 is offline
