Wiring\Fuel Woes
I posted this in the wrong forum. Hopefully you 2.5 guys can troubleshoot it.
I have a 90 2.5, 5sp, tbi. Spun a bearing and bought a 2.5 engine from a 90, auto, tbi. Popped in the engine using the wiring harness from the auto. Everything works. Runs great when you prime the tbi, but will not start\run on its own. No fuel, or power at injector. Checked it with a noid light. Fuel pump runs when you jump the relay, or power the test wire. But it doesn't stir on its own via the ignition. Not even the 2sec burst. It does have power into the relay. Have tried 3 relays. Have swapped out ECMs and proms. Still, no dice. What activates the signal to the relay? What sends the signal to the injector? Just the ECM, or ignition module? Appreciate any help. I’m almost ready to replace the harness. Just don’t see why the auto harness wouldn’t work. I find no loose wires. I did adapt one tranny plug to work on the 5sp. Thanks, Rob |
Re: Wiring\Fuel Woes
Rob
Try a seperate ground to the fuel pump. I had similar problems and it worked for me |
Wire Splicin Fool :-)
Could put a meter across the wires at the pump and see what the voltage drop is also to make sure it is ground issue, sometimes the ground to the frame isnt so good, sometimes the pump is bad. I am sure there have been cases reported of both.
Thanks for the replies.
I'll check the ground, but the pump does run when I put 12v to the test wire. Thanks, Rob |
It may still run, but it may not develop enough pressure because of low voltage to pump, I PM'ed ya also.
I'm still neck deep in this wiring thing. lesterl and blackhawkbill have been helping. Here are a few emails:
So now it's... STAR TRUCK: THE SEARCH FOR SPARK. |
Just thought of another question. Is there any kind of inertia switch that cuts off fuel on S10's? I did get the engine from a crashed truck.
Best, Rob |
No inertia switch I know of, you say no spark? You said it runs great if you prime the TBI, is this a new symptom? Did you figure out the voltages on the injector yet?
distributor makes it all work
willie |
No inertia switch I know of, you say no spark? You said it runs great if you prime the TBI, is this a new symptom? Did you figure out the voltages on the injector yet? Will dive back into it on Sunday (it's been along week of drywall!). Best, Rob |
how many relays do you have on your firewall ? I know 5 spd trucks have 1 an auto trucks sometimes have 2-3 . Above to the right of the brake booster.
how many relays do you have on your firewall ? I know 5 spd trucks have 1 an auto trucks sometimes have 2-3 . Above to the right of the brake booster. Best, Rob |
Success!
Sorta. I have a running truck, that’s kickass. But, not sure how all of this is going to add to the knowledgebase. I traced the red wire back from the injector. It mated up with the pink\black wire from the alternator as well as with the pin\black wire from the EGR on the breather (I believe). All three wires were joined to a single pink\black wire that went to the bottom, center terminal on the fuse block, next to the starter solenoid wire. These wires were always grounded. The blue wire on the injector went to the ECM. I pulled out the old manual trans harness and tracked the injector wires. Both went to the ECM So, I decided to put the manual harness back on the truck. Several wires\connectors were crushed, or thrashed in some way. Just made sure everything was taped. Robbed some connectors off the other harness. Connected the ECM and battery. It fired right off. Purred like a 2.5l kitten (missing a donut gasket). Thanks again for all the help. Best, Rob |
SK= Midwest's Elite
this is the same problem im having now, thanks for posting the progress on this.
So you're saying that the ECM sends the GROUND signal to the injector via the blue wire, and that the red wire is always hot via an ignition on power wire? I traced the blue wire back to the ECM, and i tried the positive testlight trick on the blue wire- it didnt flash nor turn on for that matter. I also grounded the test light and hooked the other end to the red wire of the injector and turned the ignition on... no light. So, now im thorougly confused. Does the ECM itself need to be negatively grounded to work properly? And where does the red wire from the injector get its power from... i lost it in the loom. FYI- i have an 88 w/ 5 spd. |
