truck wont start unless i spray some starting fluid? - S-10 Forum
post #1 of 40 Old 12-28-2007, 04:25 PM Thread Starter
blazin_low_713's Avatar
User is: blazin_low_713 is offline
well my trck will not start up unless i spray some starting fluid in the tbi, but one its on on it runs great with no problem. i just changed my fuel filter, injector and did a tune up on it what can it be.
post #2 of 40 Old 12-28-2007, 06:07 PM
The Eye is watching you!!
kamesama980's Avatar
User is: kamesama980 is offline
Send a message via AIM to kamesama980 Send a message via Yahoo to kamesama980
Re: truck wont start unless i spray some starting fluid?
does it eventually start if you keep cranking it? if it starts eventually on it's own, then you have a ever so slight leak losing pressure as it sits overnight. not enough to lose gas just enough to lose pressure when it sits for long periods. My car does that...I figure it give me time to pressurize the oil system.
If it won't start at all whatsoever without starting fluid ten you've got me.
-Russell
1990 Toyota Cressida 7MGE 3l I6/5-speed manual
1987 S10 2.5 not even power brakes it's so base model
"You don't get to judge me for how I fix what you broke."
read this and obey or face my wrath
post #3 of 40 Old 12-28-2007, 06:13 PM Thread Starter
Yea It Only Starts Up With Starting Fluid And I Leave It Of For A While Ill Have 2 Do It Again , I Know Its Fuken Wierd I Cant Figure Out What It Is
post #4 of 40 Old 12-30-2007, 03:01 PM
User is: bonestock is offline
Friend of mine had this problem with a 2.8. Replace the coolant temp sensor and was good .
Bonestock
post #5 of 40 Old 12-30-2007, 08:27 PM
Death before Dishonor
dropped_92sdime's Avatar
User is: dropped_92sdime is offline
Send a message via AIM to dropped_92sdime
never had that problem with my 2.5 I just hit the key and if it didn't start the first time then I'd shut it off and hit it again and it fired right up, that happened to my ford ranger tho and i replaced the fuel filter and flushed the fuel lines and also checked for any dry rot on them and then put it back together
post #6 of 40 Old 12-30-2007, 10:03 PM
User is: brian00 is offline
id say fuel pump probaly shot replace it its not that pricey or go to harbor frieght and get a tester
brian00 is offline
post #7 of 40 Old 12-31-2007, 08:39 AM
It's "Neanderthal"
SH-60B's Avatar
User is: SH-60B is offline
Can you have someone crank it while you look at the injector? It sounds like no fuel while cranking.
Teamsters Local 1150
SH-60B is offline
post #8 of 40 Old 12-31-2007, 10:38 AM
The Schnauzberrys
bmack8613's Avatar
User is: bmack8613 is offline
I had the same problem with mine after i did a tune up, it would only run if gas was dumped or starter fluid. It turned out that i broke a small tab off of the distributor when i was replacing the cap.... that sucked, got a new distributor and was extra careful and it runs great now
Originally Posted by nox View Post
i usually pop a boner so big that it honks the horn
I like to drag my balls on the ground!
post #9 of 40 Old 12-31-2007, 05:48 PM Thread Starter
Well I Guess Ill Replace The Fuel Pump Beacuse I Have A Brand New Fuel Injector And Fuel Filter On It
post #10 of 40 Old 01-07-2008, 09:21 PM
Forum Dictator
What?'s Avatar
User is: What? is offline
http://www.s10forum.com/forum/f105/i...lation-303943/
R.I.P. Grant ('82-'02), BagNDragS10 ('80-'06), Loenuff ('66-'07), Terryl ('57-'09) Gearstix ('93-'10), Gimp ('84-'16)
If you have any problem, issue, thread/post change, request. Feel free to PM me.
What? is offline
post #11 of 40 Old 01-07-2008, 11:34 PM
square body man
irondukeman's Avatar
User is: irondukeman is offline
fuel pump man, these things quit alot... has the truck sat for a while?
post #12 of 40 Old 01-10-2008, 04:16 PM Thread Starter
yea im goin 2 change it and see what happens from there
post #13 of 40 Old 01-23-2008, 07:19 PM
Too Broke
Kingtut777's Avatar
User is: Kingtut777 is offline
Send a message via MSN to Kingtut777 Send a message via Yahoo to Kingtut777
Be easy with the starting fluid, as the motor becomes addicted to the ether (starting fluid).
Whoever appeals to the law against his fellow man is either a fool or a coward.
Whoever cannot take care of himself without that law is both.
For a wounded man shall say to his assailant,'If I live, I will kill you. If I die, you are forgiven'.
Such is the rule of honor.
post #14 of 40 Old 01-24-2008, 03:03 PM
It's "Neanderthal"
SH-60B's Avatar
LOL!Yeah, mine's already addicted to gasoline, I don't want it picking up any other bad habits!
SH-60B is offline
post #15 of 40 Old 01-24-2008, 08:32 PM Thread Starter
What Will Happen If I Keep Doing It, Thats The Only Way For Me 2 Start It
post #16 of 40 Old 01-24-2008, 10:33 PM
it's too late. it's already addicted.
-Russell
post #17 of 40 Old 01-25-2008, 01:43 AM
square body man
be careful using ether/starting fluid... it burns way hotter than gasoline, therefore burning your rings up, and valves if you rev it high rpms, acts kinda like a torch on the valves, its also dangerous because it will backfire into the intake, burning any gas there
93 Blazer (bone stock)
2010 z06 corvette (sold)
searching for my next big toy
post #18 of 40 Old 01-25-2008, 02:36 AM
Advanced Life Form
Megaglow_Z's Avatar
User is: Megaglow_Z is offline
Well,see if you can get a small spray bottle with gas in it.then give it a squirt using that??
Would be better then using starting fluid all the time.
But you really need to get it fixed.
post #19 of 40 Old 01-25-2008, 02:20 PM
Forum Dictator
What?'s Avatar
you cannot get any cheaper than this unless ebay route for cheaper fuel pump bug you get what you pay for
this is pretty good deal because you buying the pump alone while buying the 1 from auto store/dealership, you buying the whole set, mount., fuel sending unit, float, pump, etc
What? is offline
post #20 of 40 Old 01-25-2008, 03:28 PM Thread Starter
i know i need it fixed but cant figure out what it is
post #21 of 40 Old 01-27-2008, 07:06 PM
I don't know why people always say "fuel pump" without reading the post. You state that it runs fine after you get it started--that means the fuel pump is doing its job. I also think you said it will start fine until it sets for a while (cools down). Then you have to spray it again.---COOLANT TEMP SENSOR.
Bonestock
post #22 of 40 Old 01-27-2008, 07:34 PM Thread Starter
Where Is That Located If U Have A Pic Or Something I Would Appreciate It
post #23 of 40 Old 01-27-2008, 08:03 PM
Rarely goes over 20mph
beaniebmx's Avatar
User is: beaniebmx is offline
coolant temp sensor is located on the thermostat/water intake housing. it faces the a/c compressor and is threaded into the water inlet has a connector on i
03 S10 Ext Cab-BD 3.5" bagged- 18/20s its ORANGE
1991 s10 reg cab 5spd- SOLD- biggest mistake
1985 2wd 2dr jimmy-totaled- samwhiched in a 5 car pileup
post #24 of 40 Old 01-27-2008, 09:31 PM Thread Starter
ok i see wich one it is
post #25 of 40 Old 01-28-2008, 06:39 PM Thread Starter
well i changed the coolant temp sensor today and no luck still wont start
post #26 of 40 Old 02-05-2008, 08:49 PM Thread Starter
i finally put a new fuel pump and still no luck im out of ideas
post #27 of 40 Old 02-06-2008, 01:57 PM
Too Broke
Kingtut777's Avatar
Have you checked the timing? You may want to try retarding the timing (turn the distrubutor counter clockwise, just a little). If this helps check the vacuum line going to your disributor. It may need replaced, or the timing advance in distibutor may need replaced. Just something to check out, hope it helps.
post #28 of 40 Old 02-06-2008, 02:01 PM
Too Broke
Kingtut777's Avatar
If there isn't a vacuum line running to your distributor it will use a spring advance (it's been a while so I don't remember). You'll need to check the spring, it may be weak or broken.
post #29 of 40 Old 02-06-2008, 02:33 PM
vettezx-6's Avatar
User is: vettezx-6 is offline
Let's reason this out. To get the truck to start you have to add fuel, correct? Therefore you have a fuel delivery problem, not an ignition problem. GM fuel pumps are notorious for being too weak to start the engine. Once the engine is running the pump has no problem supplying enough fuel for the truck to operate normally. Since you replaced the pump you should have that ruled out.
Next move should be to make sure the fuel pump "prime" is working. Basically the ECM will run the fuel pump for about 2 seconds when you turn the key to the run position. You can check this by having someone turn the key while you listen for the pump to run (don't crank the engine over, just turn the key to run). You will have to turn the key to off for about 5 seconds to reset the ECM prime. If your pump is not priming you will have to crank it for a really long time to get the engine to fire - assuming it ever would.
post #30 of 40 Old 02-06-2008, 05:52 PM Thread Starter
Thanxx Guys Ill Take All That In Mind
post #31 of 40 Old 03-02-2008, 11:03 AM
leadfoot's Avatar
User is: leadfoot is offline
Question Re: truck wont start unless i spray some starting fluid?
Did you figure out your problem?
I'm having the same prob with my '02 Xtreme 4.3. Truck sat for awhile and won't start, but I remember it was not running good the last time I used it. (would not downshift when I floored it-auto trans)
I smell gas and it almost wanted to fire, but does not -even with starting fluid!
Truck only has 40K on it and seems to be falling apart sitting in the driveway??
Doug E
'02 Xtreme: Syclone powered; AWD; 4.3/4L60e; 0411PCM; Coil overs, 4" static drop, 4WDisc brakes; A/C delete, cruise delete, remote oil delete.
'06 Mazda 6i sport
'66 Chevelle convertible (6.5) SS clone
leadfoot is offline
post #32 of 40 Old 03-02-2008, 11:13 AM
I gots a new toy
lodime's Avatar
User is: lodime is offline
I have the, to the T, same freaking problem and it sux, any luck with yours?
Ryan
lodime is offline
post #33 of 40 Old 03-02-2008, 04:20 PM
leadfoot's Avatar
i heard the pump prime when I keyed the ignition. Ordered the fuel pressure tester, so I will diagnose the fuel system when that gets here.
On most of my last fuel injected cars it was usually as the cam position sensor that prevented start up, but I am not sure if this truck has one??
I also may drain the tank and replace the fuel as I think I may have old/stale fuel -like I have nothing better to do...
Doug E
'06 Mazda 6i sport
leadfoot is offline
post #34 of 40 Old 03-03-2008, 09:29 PM Thread Starter
nope i have not been able 2 figure it out , but know i have more problems with it
post #35 of 40 Old 12-03-2011, 10:42 AM
Red Dog's Blazer
Chris's_96Blazer's Avatar
User is: Chris's_96Blazer is offline
Send a message via Yahoo to Chris's_96Blazer
I have had the same issue with mine for past 6 months, the shops around here want to much to tell me what wrong ( they said they can do tests on it and tellme ) i really so bad need it fixed, its very very annoying to have to pop hood spray it then crank it.
sometimes mine will crank if i keep turning the key for 5 secs, then turn off, turn on again ( priming it as someone said) but it doesn't always do it by itself.
its getting colder and colder and don't want to be standing out in the cold, wet,snow doing this. hope I can get it fixed soon
BTW I have put on a new fuel filter, throttle position sensor and cleaned the mass air sensor none of these helped anything
sorry i just now seen the date this thread is WAY old
"If its too loud,your too old"
1998 Blazer 4d 2wd.Stock.
Chris.
post #36 of 40 Old 12-03-2011, 11:25 PM
Wire Splicin Fool :-)
lesterl's Avatar
User is: lesterl is offline
Test your fuel pressure, now if you have a 96, then you are in the WRONG forum and you should be looking for a higher fuel pressure (around 60 PSI on prime, any lower than that and you should suspect the fuel pump.)
That being said for those of this forum, fuel pressure is around 12 PSI on prime, much below 9PSI and they wont start/ start well.....
lesterl is offline
post #37 of 40 Old 12-03-2011, 11:32 PM
User is: 805pyro is offline
wat u shuld try dng is run a switch to ur ignition fuse. cuz when i turn the switch on ur turns on the fuel pump nd u wuld hear the fuel pump prime while its priming turn on the truck nd it shuld fire right up. its like a kill switch to. wont turn on unless the switch is on. i did it to my truck. the fuse im tlkng about it the one that turns on ur odometer nd fuel pump. cuz theres like 5 ignition fuse's.
805pyro is offline
post #38 of 40 Old 07-23-2015, 12:13 PM
User is: harper789 is offline
So blazen_low_713 did you ever figure out the problem? I have same issue - need to prime my 2002 S10 to get it to start. Runs great otherwise.
post #39 of 40 Old 07-23-2015, 01:22 PM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
Welcome...
Did you happen to see how old this thread is?
The OP probably doesn't have this truck anymore.
Suggestion:
Start your own thread and describe your problem.
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
2) '85 S10, 3.4, 700R4 4x4 stretch cab (Redneck) 3) '90 S10 2.5, 5 speed shorty
6) '83 S10, 327, TH 350, shorty (13.00 best) Sold
7) '92 S10, 2.5 5 speed, Shorty
8) 1979 LUV, Buick 3.8 V6, TH 350 Shorty.
Mad Max is offline
post #40 of 40 Old 06-08-2016, 01:42 AM
User is: gt4daddy is offline
gt4daddy is offline
