Think with ur dip stick Jimmy...
Old 10-29-2009, 01:08 AM   #1
lol Just saw that commercial an though it would be a catch title.
But on a serious note about dip sticks , do any of you other guys find that
the oil dip stick on your duke is VERY un accurate ? Like I check mine often sometimes cool / sometimes warm an I can never get a good reading ..
How do I know this you ask ?
Well when I check my oil it says I am fine , well when I change my oil it is noticeably not X amount of quarts.(my pan has a quart reading).
Old 10-29-2009, 01:10 AM   #2
Re: Think with ur dip stick Jimmy...
Also on the note of oil , I noticed some sludge build up in my oil last time i changed it ( about 3000+ miles ago) ... I was wondering what is recomended that I can run in the oil before the next oil change that will break down this sludge an try an remove some of it through a oil change ..
(perfer something I can get from the parts store.)
Old 10-29-2009, 02:49 PM   #3
Get a can of SeaFoam. IT coems in a white metal can with red and black lettering. Dump 2/3 of the can into the old oil. Follow the directions to suck the remaining 1/3rd can down the brake booster line and down the TBI unit and kill the engine. YOu want the engine to be loaded up with seafoam when it dies. Dont dump it down and wait 10 seconds to turn off the ignition. DO it right away to clean the cylinders better. Wait 10 minutes and fire it up. You will have a neighborhood block full of smoke coming out the exhaust pipe. Run the cleaner in the engine oil for 50+ miles and then do a full drain and refill on oil. I like to use seafoam before I cahnce oil every now and then. It will scrub all the carb off the walls and usually fixes a lot of idle issues and such.
The is hands down, the best and only engine cleaner out. DO NOT fall for chevron techron system cleaner, engine flushes, fuel system cleaners, or any of that garbage. No other brand is near as good as seafoam except Mopar CCC. Just change your oil a lot, and use Seafoam. I have used it in over 12 vehicles, and it does wonders!!!
Old 10-29-2009, 03:13 PM   #4
4x4 v6 blazer
neo71665's Avatar
Your only supposed to check the oil when its had enough time to sit and cool down. This allows any oil in the block to drain back into the pan.
Old 11-01-2009, 11:20 AM   #5
wi11ie's Avatar
And since the duke has a shitty oil return system to begin with always check it when it is cooled down.
I have, in the past, been on the road and added a quart to the crankcase at a fuel stop.Then a day later got home and changed it and my 5 quart oil change pan was WAY overfull even before dropping the filter.
wi11ie
Old 11-01-2009, 11:45 AM   #6
Newb
97s104x4's Avatar
techron does work for me...
Old 11-01-2009, 12:26 PM   #7
Has Training Wheels
beaniebmx's Avatar
i cant even use my dipstick, my engine burns oil, or it disapears, filled it up awhile back cause it was low, went on a 2 hour roadtrip and almost got to my location when the engine started to make noise... still had some oil pressure.. dumped 2 quarts in and sound went away
Old 11-01-2009, 01:07 PM   #8
whore turned lurker
dimerunner88's Avatar
i dissagree, there are several engine cleans that work. the best engine cleaner is a good oil,semi-syn and full synthetics will breakdown the sludge in your engine and prevent it from coming back.
Old 11-01-2009, 04:21 PM   #9
carries a gun at work
bill 4.3l 5spd's Avatar
i've always liked seafoam. used it on a few cars, including yesterday my dad's durango.
Old 11-03-2009, 09:58 PM   #10
I know how to check the oil , reguardless I can never seem to get an accurate reading .. like I can pull the dip stick 5 times an it will get a different reading every time sometimes higher sometimes lower.
Page generated in 0.56877 seconds with 31 queries
[Output: 72.27 Kb. compressed to 67.83 Kb. by saving 4.44 Kb. (6.14%)]
