test my knowledge-
Old 01-18-2008, 11:47 PM   #151
new question
if i replace those lifters will that 2.5 quieten down some or is this going to be like this, i know everyone says there noisy but can i quieten it down for a bit? i run it without valve cover just long enough to see there is only about 3 of'em oiling good, and yes, the pushrods are clean, and no the rockers dont show signs of excive wear and the guy i got it from said today it sounds just like it did when he got it four years ago, yes even after all the work i've done to it blah blah blah, but it runs great tick tick tick tick tick tick tick tgick on idle noisy little bugger great gas 100miles 1/4 tank or less
Old 01-19-2008, 12:40 AM   #152
Has Training Wheels
beaniebmx's Avatar
Re: test my knowledge-
the ticking sound your hearing is the fuel injector, its a fact, the fuel injector will always make a tick tick ticking sound, my old one did, my brand new one does, its life.
i used to think it was my lifters and all that, but quickly found out on here, its just the fuel injector noise.
Old 01-19-2008, 11:05 AM   #153
square body man
irondukeman's Avatar
either that or your cam gears, 2.5s run rollers, if they tap, your engine wont run right at all
Old 01-19-2008, 03:51 PM   #154
Educating da masses
SgtM's Avatar
How do I disconnect the emergency brake? I'm trying to pull my dash to replace the heater core.
Old 01-19-2008, 03:57 PM   #155
square body man
release the brakes, remove the end of the cable, from the keeper (the small braided cable with a stop clamp)and pull the plastic case around the cable off the bracket and it should pull directly out
Old 01-19-2008, 05:40 PM   #156
"Candy Man"
hey thanks about the map sensor thing. I took it to one autozone and they said it was good. So for the heck of it I took it to another one and they tested it out bad, so I got one from the junk yard for 2.00 and that one tested good, put it on, and the hickup was gone. thanks alot. now if only I could figure out my wipes, and dash lights. lol
Old 01-19-2008, 07:12 PM   #157
square body man
usually autozone does a pretty good job, must have been a fluke, glad to hear that it is fixed, and junk yard parts are usually good as new...
Old 01-19-2008, 07:55 PM   #158
chucked's Avatar
junk yard parts good as new? 1st time i heard that one.... Ive been in autozone, those guys barely know how to check if their shoe laces are tied...
Old 01-19-2008, 08:01 PM   #159
I've got a question
I've got an '88 2.5L 2wd reg cab reg bed (short bed?). We just redid the clutch on it amongst other things and before it went under the knife the clutch would not bite until the pedal was about 95% out then that last 5% was the biting point.
We've put a new master and slave cylinder on it as well as a new clutch and I was just wondering if there's any adjustment you can make to the clutch to change where the biting point is? I believe it's a hydraulic clutch so I don't know if there is any.
Old 01-19-2008, 08:27 PM   #160
Educating da masses
SgtM's Avatar
Thanks for the help dude! With the exception of some wires, the dash is out.
Old 01-19-2008, 09:04 PM   #161
square body man
Quote: Originally Posted by winston856
I've got a question
i might be wrong on this, but some after market clutch throw out bearings or the clutch springs cause that, being over sized i believe. on other cars, i have taken about a 1/2 inch off the slave cylinder pushrod (the end that enters the tranny)and it helped alot. just make sure you round off the end and make sure there are no burrs or rough spots that could hurt the seal
anybody agree?
Old 01-19-2008, 09:05 PM   #162
square body man
autozoners is what they are called. if you know what to look for in a junk yard, you can get some good parts that work like new, in my opion, if it works right, its as good as new
most of the people that work at the closest autozone are ex mechanics or are very knowlegdable about cars. but the other close one, they are either *&*holes or idiots, everytime i go there, they sell me the wrong part or say they dont know what i am asking for, and i have to call the other store and get the part number
Old 01-19-2008, 09:13 PM   #163
i took the heater core out and back in with dash in, but now i know also to take out the bolt on passenger side of dash so you get a little more clearance for plastic cover, but on that tick tick im talkin bout is definitely not the injecter, i know what the injector sounds like my fullsize has two of'em and they are noisy, the one on s10 is a single and it ticks a little but not what i hear, and irondukeman, the guys at the chevy dealer in villa rica said the timing gears should not go bad until maybe 250 to 300 hundred thousand miles they also told me if the gears went bad it woould mean something catastrophic happened to my engine and i would have to get a new one but what about the rockers, if i dont have oil coming up the pushrods wont the rockers give a tick tick? just a thought! thought i might could put new lifters in, ever try that?
Old 01-19-2008, 11:05 PM   #164
Has Training Wheels
beaniebmx's Avatar
been there done that, tried to get a fuel injector oring set=2 orings, and the guy gave me a package with like 12 really tiny ones no diffrent sizes, oh this is for cpi, no tbi. went to othe rplace, yeah we have 1 of those.. it has 2orings.. but they are like.. made for a midget injector or something... however they did have the injector when i cracked mine, and at $85! ^^ place wanted $151, online wanted 140, place was napa that got me it cheap. most of the employees are teenagers=my friends
Old 01-20-2008, 12:24 AM   #165
square body man
i have had a bunch of the little engines man, i know all about them lol.. the cam gears go bad at about 120k simply because they are not even metal. they are carbon material that has teeth, and the teeth wear in the spaces between each other causing the cam to kinda rattle, sounding like the lifter. since the cam is hard to turn the cam goes, tick tick tick at the hard spot. i have expirience over alot of these guys that say, i have had one or two, i have had 23, going on the 24th and ran everyone of them and worked on everyone of them, never owned a new one, couldnt tell you what they even sound like new, most have had at least 100k with a few exceptions. it could be rocker arms, even without oil on them, if your lash is set correctly, you wont have the tick sound. did you properly set the lifters and zero lash? how did the cam look? did over heating it scar the cam/pushrods? did all your lifters prime before you put them in the block? alot of people dont check that and end up putting back bad lifters
ever cam gear set i have replaces ran like a champ afterwards, nothing catastrophic happened to them either- just worn out- but experience over books- you choose
Old 01-20-2008, 03:32 AM   #166
hey irondukeman, i am with you 100 percent! you say 120 uh, my truck has 145 so i think i will put them gears in soon, i didn't pull the lifters out, i pulled head off and stuck a new gasket under and back on the road she went, so lifters probably maintance list soon also or just pull em and clean em and that yellow stuff in breather no more happens since new headgasket! yeah i hooked the hose back up on back of breather gas mileage is better with it off though i think, hey, when i put the clutch kit i put new trans mount the old one was half gone, i think it was half gone for a reason, after 2 sets of u-joints and one different drive shaft the vibration is back, aaaahhaa i think i know !!!!!!!!pinion angle!!!!! new trans mount raised it up a good inch am i right i hope so, who ever put that t5 borg warner back in i think put the trans cross member upside down i didnt know better and i reinstalled it the way i took it out, it dont even look like the right one either, its all black and the only thing down there that is so i think i will see if i can flip it so as to get pinion angle back stock its been that way for a long time because someone had welded the stock replacement muffler to it, just didnt cause any problem with the support whittled down to nothing(old one didnt have the bolt at all)
Old 01-20-2008, 03:58 AM   #167
anybody agree?
how does a half inch help? when i put clutch kit in all that seems to be pre set to work, i drove a lot of old old trucks and like a dump truck or a big rig you had to crawl under there and back that damn lock nut off and adjust the clutch manually with a combination wrench, on these little trucks it seems to not be enuogh clutch pressure to really require this, but taking off the half inch on pusher will make it bite much sooner and at the same time not disengage it as much either i would think, this is also gonna be hard to adjust it back later if you need to(new slave cylinder unit?) if you have a old unit or plan on purchasing a new one shave a little at a time till you acheive your goal? just some thoughts, irondukeman has done this and he has worked on a lot of these and he recka mends half a inch, from exp with old dump trucks and what not in clutch adjust ment it can vary on every truck, and what seems like a little can make a heck of a lot of difference in grinding gears and not at high rpms you need to fully disengage down there or you will ggrreeiinddd em till you find em like me he he i need all the help i can get, most time flipping radiio dials or on cell miss half gears
Old 01-20-2008, 04:01 AM   #168
after thought! what about a custom bushing between bellhousing and slave cylinder!
Old 01-20-2008, 09:34 AM   #169
JML
Hey guys I was checking the coolant level on the radiator and underneath the cap is a thick doo-doo brown liquid. Do you think my headgasket is blown?
Old 01-20-2008, 01:13 PM   #170
square body man
is the doo doo oil? does the truck run like crap? how does the oil look?
Old 01-20-2008, 01:16 PM   #171
square body man
if someone flipped the crossmember it will cause vibrations, but if the release point on the clutch is all the way at the top, taking off some metal off the pushrod will work and put the release point back into the middle, bushing is also a good idea, whatever works i guess
Old 01-20-2008, 01:30 PM   #172
TNewby7801's Avatar
yup, one big injector, two seals, little one close to the nozzle, big one up top, you can change it with the motor in, just pull the injector
need some info. just changed the fuel pump on a 2.5 pump turns on ok when you go to start it and look at the injector while turning it over it pukes some gas out no spray then nothting not enough to start would that be a bad injector?
Old 01-20-2008, 01:38 PM   #173
mine was like that till i put the head gasket now it all good
Old 01-20-2008, 01:45 PM   #174
JML
It doesn't smell like oil, and the truck doesn't run like complete crap, but it chugs at low rpms, and the SES light comes on while going down the highway for about 5 minutes. The brown stuff is just on the cap, , I don't see any in the radiator or in the overflow tank.
Old 01-20-2008, 01:51 PM   #175
"Candy Man"
junk yard parts are good. I usually look for one that the front of it was smashed usally an indication the truck was running and driving when crached. lol
Old 01-20-2008, 02:05 PM   #176
Has Training Wheels
beaniebmx's Avatar
clean your rad cap, and then pull it off a day or two later and see if it has crap on it, if it does, then somewhere you have some gunk in the cooling system, it could be oil, it could be corrosion, could just be random gunk, hard to tell
Old 01-20-2008, 02:06 PM   #177
is the water green from antifreeze? my oil didnt show water till the gasket went kaapooy bad, the doo doo just kept getting worse for several weeks, ses light has always come on on my fullsize? maybe a problem maybe not, did you check to see what code your getting?
Old 01-20-2008, 02:12 PM   #178
oh yeah, check and see iff you have yellowish liquid in the breather if all breather hoses are still on, the hose going to valve cover in back is where you might get this, and there could be a lot of it causing ses light and stuff
Old 01-20-2008, 02:42 PM   #179
square body man
yes dirty injector or bad fuel pressure regulator
Old 01-20-2008, 02:42 PM   #180
JML
The breather is clean and dry, just smells like gas. And there wasn't much brown stuff just a little around the cap. And yeah its green
Old 01-20-2008, 02:44 PM   #181
any help with knowing what sup with this crossmemeber irondukeman?
Old 01-20-2008, 02:44 PM   #182
square body man
then drive it till the wheels fall off man
Old 01-20-2008, 02:51 PM   #183
man dont sound like head gasket, beanibmx prob hit it when said a little trash in cooling system, prob come from heater core?
Old 01-20-2008, 02:57 PM   #184
on the tranny cross member on passenger side there is a bend and the member bolts to side of frame, mine is currently with bend going down? holding tranny higher, anyone know if this is right or if i flip it with bend goig up then tranny would sit a lot lower i would but pics but my digital camare wont sync with laptop shitty
Old 01-20-2008, 03:11 PM   #185
square body man
i will have to go look at my s10 and ill send a pic- not sure how it looks right now
Old 01-20-2008, 03:19 PM   #186
JML
Cool. Also that stovepipe that goes from the exhuast manifold to the breather is that necessary? I know it helps warm the truck up, the stove pipe goes into some type of valve and there is also a vacuum hose going from it to the intake manifold i think, I haven't looked at it in a while.
Old 01-20-2008, 03:22 PM   #187
square body man
not necessary at all, i always take that crap off lol
Old 01-20-2008, 03:22 PM   #188
Has Training Wheels
beaniebmx's Avatar
anyone know how to keep my battery warm/charged?
bought a new battery late summer from walmart, got one with more cranking amps then the one that was in, and all was good, till now, it wouldnt start up one morning, jumped it, drove it around for awhile and alls good till this morning, SES light and battery light were barely lit, it was like -30F this weekend, couldnt even get any noise, tried to jump start it, barely wanted to, but the other battery had enough juice to start it, drove it around and gave it hell once it warmed up, my stereo shut off when i turned it up 3/4 way. so i shut it off and just drove around charging it.
so my question is, anyway to keep it warm enough to start? i put a sheet of fiberglass cloth around it with some pajama bottoms and a shirt tucked infront, am i doomed and have to bbuy a better battery like an optima, or just deal with it till winter is over?
right now i have a 2x4, jumper cables and a spare dead battery that barely holds anything above half charge.
i go to work at 650am, so it is normally about 1F outside, i dont want to have to jumpstart it till spring and i dont wanna spend $180 on a battery, ive dumped enough money into this thing
Old 01-20-2008, 03:27 PM   #189
square body man
when i lived in the mountains, everyone i know would tape cardboard to the end of the batteries and bring them in at night or to work with them and set it somewhere safe and warm, -30 will bust a battery wont it? i would just take it in of a night or before work, i know its work but you can at least have a battery that works
Old 01-20-2008, 03:59 PM   #190
Has Training Wheels
beaniebmx's Avatar
it was more like -11F but with windchilld -35F, i opened my hood and the whole motor had frost on it, my belt tensioner is squeeking horribly, i greased it up and it was fine for a few weeks, put some more grease in it.. cant seem to keep my truck happy
ive never known an engine that has wanted this much attention before, its like a new born child, i have to baby it, feed it new parts, change its diaper, buy new clothes for it=tires, its as much work as a newborn child for christs sake... so irondukeman, want to put a 350 v8 in it? ill buy you dinner... and you can sleep on the couch too! hell you can be the first one to do a wheelie in it
Old 01-20-2008, 04:07 PM   #191
square body man
ill do it from here, ill guide you through it, i have been taking pictures so far, from beginning to where im at now, i can pretty much give you a step by step, for free, and i can sleep in my bed and my wife cook dinner lmao! if you lived closer i would give ya a hand lol
Old 01-20-2008, 04:20 PM   #192
http://infinitipartspeople.com/searc...Battery+Warmer
http://www.jcwhitney.com/Battery-Acc.../600000917.jcw
try these man, easier than taken battery out and they from truck to truck something you can keep for a while you know like a good tool
Old 01-20-2008, 05:24 PM   #193
The Eye is watching you!!
kamesama980's Avatar
Autozone is hit or miss. most of the guys at mine max out putting altezza tails on their civic. they hired 2 ditsy blondes that can't even run a cash register over me last fall too
Never owned a Cressida then :-p Cressidas are all that and worse...they're intelligent and wily like a bitchy jealous GF that knows shes too good in bed for you to dump her. I tried getting my paycheck to finally pay for the S10 a few weeks ago and the cressida blew the clutch master I bought new this summer...
As for the battery situation...check for a parasitic draw when the engine's off too. I can send you a circuit diagram for a backup battery with automatic disconnect so it starts and charges like normal but when you turn the key off it opens the circuit. also remember that every time you drain a battery, you halve it's capacity and lifespan and it's cumulative.
Old 01-20-2008, 05:53 PM   #194
square body man
anybody want stock rims, bent bumber, good wiring harness, straight bed, good gas tank and ugly brown interior?
Old 01-20-2008, 06:14 PM   #195
hey man, the 5.7 your putting in, what did it come out of? is that bed long or short and would the frame of truck be different either way?
Old 01-20-2008, 06:30 PM   #196
square body man
engine bay is the same on all s10s, 5.7 i bought remanned from a shop, casting numbers show its a high nickel block froma late model heavy duty pickup 73- 81 4 bolt main with big valves, 2.02 intake valves w/ 1.6 exhaust valves
Old 01-20-2008, 07:18 PM   #197
i meant would a long bed bolt to a short bed frame, is only the bed different or is the frame of truck longer? i also was interested in the swap too, how is that going?
Old 01-20-2008, 07:26 PM   #198
square body man
i dont think the beds are interchangeable, because the bumpers bolt to the frame, so i would imagine that they aren't. the swap is going smooth as hell, i am just stressing the wiring issue i will have. but as far as the physical attributes, never been easier.
Old 01-20-2008, 07:38 PM   #199
Has Training Wheels
beaniebmx's Avatar
i dont have an engine hoist or any money to buy a 350 v8 id love to squeel both tires and do a wheelie down the block, but unfortunatly im stuck with this poopy 2.5 thats mentally mpg challenged
Old 01-20-2008, 08:05 PM   #200
beLUVed
luvtruck's Avatar
i got a couple questions...i got a 93 2.5 that i got for $250 bucks that i was going to use for a parts truck but i changed my mind and now i want to drive it...i got it from a guy that bought it from a mechanic/tow service...he said the mechanic said all it needed was a head gasket....i came across a rebuilt 2.5 with no accessories and just decided to make a swap...the plan was to use all the 93 accessories alt/intake/carb and so on...i went to change the intake manifold...it turns out that the heads are not the same..the rebuilt one is i guess older..i don't know what year...are the heads interchangeable or do i need to get an intake for that year 2.5? if the head gasket blew, whats the chance of messing up the head?....and are the distributors interchangeable? they dont have the same cap....ant help would be great..i don't know anything bout these motors..thanks
Page generated in 0.71488 seconds with 31 queries
[Output: 229.25 Kb. compressed to 210.92 Kb. by saving 18.33 Kb. (8.00%)]
