#101 |
square body man
Re: test my knowledge-
#102 |
Has Training Wheels
id check either of those, my brothers car did that, youd push the clutch in and it would go straight to the floor, like it was spring loaded? and have 1/4 inch between it being disengaged and engaged, even with it pushed in the car would move when running and grind gears. we bled it and still nothing, it had some bleeder valve ontop of the transmissin, had no resevoir or anything, then it just started working normally again.
could be air, or low fluid, or the cylinders ^^ check the fluid level first Last edited by beaniebmx : 01-15-2008 at 08:31 PM. |
#103 |
Checked it a few days ago, completely dry lol, added some fresh dot 3 brake fluid and checked it next day and it was dirty as hell. I think there is air in the lines because of the low fluid level.
And that Lincoln was riding on tshe bumpstops, it could probably lay another two inches without them lol |
#104 |
square body man
#105 |
Only 91 up heads (A codes) have the d-shaped exhuast ports, the intakes are rectangular like almost every other engine out there (yeah they make ovals too but never d-shapes) and from the fiero heads i've seen the a-code is a lot better. blocking off the coolant lines running to and from the intake will not starve the top end of coolant, it flows out the front through the thermostat like its supposed to, so if you want to run a fiero head (you gotta change two head bolt holes, the pads already cast for both) run the matching intake for that head and you should be fine. The newer cranks are stronger then the 85-86 ones, and i think it gets better the newer you get but i've seen some older looking ones in newer blocks so it might just be luck. we get 6400 out of ours for 15 laps every weekend during the summer and we have yet to spin a bearing even when theres no oil in it (ovalized a wrist pin hole which lead to the piston hitting the head but all bearings looked normal) and have yet to launch a rod, although i'm not looking forward to that. Run light pistons and you save your crank, and probably your block too they aren't much stronger then the crank, but i have yet to break either. |
#106 |
I need to fix this POS and sell it asap lol,
Let's see, injector seals, master or slave cylinder, handful of oil leaks... About the only thing that aint leaking is the valve cover, I put a new gasket on and cover both sides with rtv lol that bitch better not leak. |
#107 |
#108 |
No more blazer
so question... im deleting my heater core and want to get rid of as many hoses as i can... can i put a plug in the side of my intake, back by the firewall? and cap the other lines off? if not what should i do to not create any overheating or other potential problems..? |
#109 |
square body man
#110 |
square body man
#111 |
No more blazer
lol my s10 is a permanent convertible, bagged and bodydropped lol. im not too worried about the winter since it sits in the garage lol. but that is def good news, so if i plug the line at the water pump, then the line on the intake, i should be good to go? |
#112 |
square body man
#113 |
No more blazer
#114 |
I barely made it to school today, the clutch wouldn't disengage. At school we took off the master and slave cylinder and turns out there was a big flat spot on the piston seal in the slave cylinder. Just bought a new one, but my truck is stuck at school lol.
#115 |
The Eye is watching you!!
#116 |
square body man
#117 |
in higher output engines, running lean can kill the engine in under a minute. the forum that gets my attention most is about the Cressidas, lots of people in there running very high output supra engines, including a few that have blown up or at least damaged them. even the stock engine is known the world over for blowing the head gasket. Just the head gaskets $80 minimum ![]() Last edited by kamesama980 : 01-16-2008 at 07:02 PM. |
#118 |
square body man
#119 |
Has Training Wheels
so while trying to remove the fuel injector, it cracked on me, i removed the clip, and took the FPRegulator off to dink around with that too, injector started to come out and crack, both o rings are still good, the ones Napa gave me are way too small, the smallest one isnt even big enough to fit where the smallest one goes. so i put it back in, start it up, and notice its wet ontop, dry it off, wet, dry, wet, it keeps getting wet with fuel=leaking out the top where its cracked.
so i just bathed it in RTV sealant and im going to let it dry and check it, should i jbweld the crack instead? i dont wanna spend $100 on an injector... i cant even afford to put gas in! Last edited by beaniebmx : 01-16-2008 at 07:49 PM. |
#120 |
square body man
#121 |
Has Training Wheels
how much $$ for it? if its not too expensive ill buy it, i have paypal
i just read the package, says rtv is no good for a gasket if its immersed in gasoline.. took that all off, and just doused it all in JB weld. ill have fun getting the injector out ![]() ill check it in a couple of days and see if its wet, if it is i might just have to go to the local pick n pull and "borrow" an injector ![]() Last edited by beaniebmx : 01-16-2008 at 08:17 PM. |
#122 |
square body man
#123 |
Has Training Wheels
i just pushed it around the block as far as i could, and drove it from the garage in the alley to the street, coasted and shut it off halfway, hopefully that didnt **** up the still wet jb-weld.
would jb weld hold? i made sure i caked that shit on there as thick as a 300lb woman. how much did you want for the injector? i really dont want to go to the junkyard and steal one, they looked at me weird last time i "borrowed" a part i couldnt afford but fit in my shoe, they check your bag/toolbox whatever u bring also where are you located? i need a cat converter put on, shop will want atleast $150, and i need $35 in sensors, and i need gas in my tank im at like 1/2 tank and ive only gone like 85 miles= 170 miles to a 13 gallon tank? my mileage is so horrible i cant figure it out i rarely drive the damn thing around town and it uses up the same amount of gas as it did when i used to drive it around 24/7 Last edited by beaniebmx : 01-16-2008 at 08:49 PM. |
#124 |
square body man
btw j b weld should hold, at least hold better than alabama chrome (duct tape) Last edited by irondukeman : 01-16-2008 at 08:59 PM. |
#125 |
Has Training Wheels
i live in nw iowa, so georgia would cost me about $9000 in gas at my mileage, 14mpg range, and cost me hotel room and work time, im only 19
![]() my fuel dinger isnt bent, ive poked it with my finger a few times, but its always maxed out to the top part of the L on the dash when i top off the tank, and still maxes out when i top it off. the way i know im geting like 14mpg, is cause i write down my mileage, then when i go to fill up, write down current mileage, then write down how many gallons till it shuts off, and then say i drove 140 miles and used 10 gallons, i got 14mpg i had 99932 when i topped it off, right now i have 10019 and im at like 1/2 tank- 1/16th above that, somewhere aroudn there, it doesnt seem normal, last tank was 14mpg, last highway tank was 14.9, i got 28.29 highway in the summer ![]() so right now ive gone about 87 miles on half tank= 6.5 gallons, thats around 13.5-15mpg range estimated.... Last edited by beaniebmx : 01-16-2008 at 09:07 PM. |
#126 |
square body man
#127 |
Has Training Wheels
i can check that, i know my front rotors are warped and drag in one spot, but its so minimul, with the front jacked up, you can hear it slighlty go krr krr krr, but the wheel doesnt slow down all that fast, so its not dragging majorly, and only in the one spot.
the rears, im not sure, the emergency brake was rusted and didnt even work, found that out when my truck started to roll down the incline backwards while in gear, it kept slipping, like it wanted to roll out of gear but didnt. not sure if they are dragging majorly or none at all, im thinking the straight pipe exhaust is causing half of it. no cat at all, it sounds like popcorn in my exhaust. and then theres my coolant temp sensor and gauge, the gauge doesnt even work at all, it stays at 100 even though my afermarket says 195F the stock coolant temp sensor is plugged in and sitting on the head/valve cover, it made no diffrence when it was screwed into the water inlet. do you think i need to buy a new coolant temp sensor and the head sensor for the gauge and plug the new one in, or keep the aftermarket one i have in? would it improve mileage any? i know im gonna replace both of those and get a cat on, but if i dont need those ill just get the cat. i do however know that my front brakes like to drag a little when im turning, when im backing into a parking spot turning more than halfway, it makes a krr krr krr dragging sound from my front brakes, not sure if its the brake line being pulled tight or something. i dont know how to adjust disc brakes, i sorta know how to do drum brakes, i put new pads and hardware on my old truck i can pull it into the garage friday and check all 4 brakes to see if any are dragging |
#128 |
if you pull the plugs out of the intake and get the same size pipe plugs it'll clean that up without hurting it. The coolant that flows through the intake comes from a 1/2 inch opening behind number 4 cylinder. its not much of an opening and its sent through the intake for the sole purpose of heating the floor under the tbi to vaporize any puddling of fuel at low rpm driving where there is not enough air velocity to hold all the fuel in suspension on its own. the computer also senses how warm any air going into the engine through the iat sensor (intake air temp)that is in the intake manifold and can compensate for it if you cool the air by blocking/stopping flow of coolant through it.
As far as blocking off the intake coolant - i had to make my own intake gaskets for my race engine because i didn't feeling like porting a gasket and did not cut the hole for the coolant jacket. its since seen 6400 rpms 20 times every weekend during the last summer and i've never blown a head gasket running 11 to one compression. since fuel vaporization isn't a concern on a race engine this might only be helpful on such engines. i have a feeling your intake wasn't the only culprit to you blowing a head gasket but just added to another problem that somehow sent it over the edge. |
#129 |
square body man
#130 |
knock the plug out of the back of any 2.5 head you'll see its not part of the cooling system its extra. it is not meant to help the cooling system its just there to heat the intake. most of the coolant flows back to the front of the engine and leaves through the thermostat housing-and if you block off the port all of it goes to the thermostat.
#131 |
square body man
#132 |
Has Training Wheels
so in simple terms, the engine was designed so you cant get any more horsepower out of it no matter what you do, and is aimed towards old people?
#133 |
square body man
#134 |
Has Training Wheels
mine has plenty of horsepower, right at the moment its about to do a massive wheelie, it loses all power
on a serious note, you cant find many parts to get more power out of it, its doomed to pretyy much be stock grandma motor ive yet to hear an exhaust that even sounds good on it |
#135 |
No more blazer
i was going to use a stock type muffler on mine... but only problem is, i ditched my cat cause it was huge. is this going to cause any problems for me? or is my exhaust going to sound like shit? oh and ya the exhaust will dump straight out of the muffler right before the axle. do you think it would be a good idea to get one of those resonated pipe sections and put it where my cat would be? i actually want mine quiet. but not that it restricts the shit out of it ya kno? |
#136 |
quiet and restricted are the same thing.
#137 |
No more blazer
#138 |
According to the haynes manual I've got, the IAT does NOT feed information to the ECU for fuel adjustment. it controls the TAC hose valve that regulates the intake temperature and (according to the book) if the intake temp is under 130 when the engines warm, stuffs busted.
As far as the potential for the engines... it was made for low end torque and being a reliable economy engine. The ECU isn't very good (adaptable) in the first place but with enough time, fabrication, and money you can probably get some decent bang out of it. a little headwork, long tube exhaust header, new intake manifold, port injectors, late model crank, 305 rods, 350 pistons (so so I've head...both machined as needed) and an aftermarket ECU you probably could get much better power out of it. |
#139 |
square body man
#140 |
Has Training Wheels
plus a v8 sounds better, s10 sounding like it has balls even if it doesnt from the v8=good, s10 sounding like a sewing machine with no balls=BAD.
i wouldnt advise taking the cat converter off, i took mine off, and ive had nothing but problems with my exhaust, it sounds like popcorn, my mileage dropped, 14mpg city 15mpg highway, and all this happened after i took the cat off |
#141 |
305 rods ARE 350 rods and they both WON'T work. besides being too short the bearing journal is 2.10 on a 68 up sbc and the 2.5 is 2.00. early sbc is 2.00 and you can get long ones of those nowadays pretty cheap ($500 for a v-8 set) 350 pistons work great just machining the block or not (if you like sqiush then yes) The bottom end in design is amazing for a high rpm machine, and the top isn't far off either, depending on what head. with a large bore to stroke ratio 4 in bore 3 in stroke and a 2 to one rod ratio this thing should be a good screamer - and i'm gunna try it If my sponsorship this year allows me to build another engine i'll take pictures of a well planned n/a engine that should be somewhat safe up to 6500 but i'll try for 7000 anyways and have the potential for 200+ hp lol. Theres way too much miss information on this site for the 2.5 internals. I'll do my best to get rid of that when i get back to work on my 2.5 before race season. i've already got a 5.3 v-8 head coming i'm hoping the stem length of the valves is long enough for the a code head if so that would be one of the first things to do to any high hp 2.5. Last edited by Rizzle : 01-17-2008 at 07:19 PM. |
#142 |
i replaced the slave cylinder and still its not getting any pressure so i bought a new master cylinder and im gonna see if that fixes it
#143 |
#144 |
I've never heard of that before, so let it hang of the hose coming off the master cylinder and bleed it like that? What about the pushrod from the slave cylinder, will it press in so i can bolt it back up? I hope I didn't pay over $100 for parts just because I didn't bleed it right
#145 |
yes, it will require a little of muscle, but it will go back in. Dude I spend 3 hrs trying to bleed it, went back the next day, popped it out, bled it, bam, back in in under 5 minutes.
#146 |
No more blazer
SHITTY... i threw my cat away awhile ago. would the lack of backpressure affect this? i might have to buy an aftermarket one or something... |
#147 |
Has Training Wheels
i was told the lack of backpressure cuases the popcorn sound and some fuel mileage, about 4mpg?
right now im at 14.06mpg on the last tank, just bought a new fuel injector, hoping that will atleast get me up to 15mpg, i think the cold weather is effecting most of it, my truck didnt want to start up this morning or at lunch, my battery was frozen, 1F plus wind chill= -30F yeah.... irondukeman, i have 3 Chevy V8 Oil pan Left/Right sets "universal", 1 is bad, 2 are perfect, the bad one just has a knick in the tab, nothing major but everyone is anal about them being 110% perfect so its no good to us, the other 2 are perfect like i said. i can give you a perfect set of left/right or all 3 if you want.but you have to do one thing for me, get me a coolant temp sensor that screws into the intake, and a head pcm water temp gauge sender that screws into the head for the dash gauge. i need those 2 sensors or atleast find me a place to get them cheap, its supposed to be -10 and -30F out this weekend so its too cold to go to the pick n pull and search ![]() ![]() ^^^ shows the bad set, the tab is knicked and half cut off, the top gasket is still good, but the bottom one is nicked. ![]() Last edited by beaniebmx : 01-18-2008 at 03:05 PM. |
#148 |
Replaced master cylinder today and bled it and finally got some pressure. Finished bleeding it and now its like having a brand new clutch,
#149 |
square body man
#150 |
Has Training Wheels
thats about all i need, ive replaced the rest of the engine pretty much, and those are the last 2 sensors that i havnt replaced, along with the manifold intake air sensor dealy
those are all i need, unless you want to install a 350 v8 while im sleeping, i have a heated garage that gets warm enough you can wear shirt and shorts when its -30F outside ![]() i just need the sensor on the water inlet underneath the thermostat, and the one on the back of the head near firewall with the 1 wire that sends the signal to the dash gauge, water temp gauge sensor thing? if you got the manifold air temp sensor deal too, that would be nice Last edited by beaniebmx : 01-18-2008 at 08:11 PM. |
