test my knowledge-
Old 08-12-2008, 12:37 AM   #451
mr. killyoass
killyoass's Avatar
Re: test my knowledge-
i know its just a ground thing
Old 08-12-2008, 12:41 AM   #452
mr. killyoass
killyoass's Avatar
so what does the temp sensor do if it dont run the gauge?????
Old 08-12-2008, 08:06 PM   #453
Wire Splicin Fool :-)
lesterl's Avatar
Its probably open if it doesnt work. Engine block ground to pin should have a reading http://i191.photobucket.com/albums/z...ensorchart.gif
Old 08-13-2008, 01:48 AM   #454
Definite Obsessions
Madkaw_16's Avatar
I just find it hard to believe that none of the stores have it in their system, ya know? They keep telling me it's a coolant temperature sensor (#su109) but that's the one on the front, next to the radiator hose. This one has a different plug on the wire, and it fits the sensor.
I'm gonna try what Killyoass gave me today. Hopefully it works, since i'm driving it to RA in 2 weeks, lol.
Old 08-18-2008, 09:08 PM   #455
mr. killyoass
killyoass's Avatar
ok so why is this truck rinning 265 degrees
changed the thermostat= nothing
were gonna take it out next see what that does
Old 08-18-2008, 09:43 PM   #456
lesterl's Avatar
Put an ohmmeter across the CTS and read what the coolant temp is, use the chart I posted to check it against the temp you think it is (265 would be very low, just a few ohms) (you should be seeing around 200 ohms on a warmed up engine.)
Old 08-21-2008, 04:58 PM   #457
88 S10 2.5 radiator leaking
Here's the history of this truck since I've had it.
-oil pressure light came on during idle went off during higher rpms
-Valve cover gasket leaking
-radiator leaks when parked right after driving (leak at the top)
-changed oil to synthetic 10w40 high mileage oil light doesn't come on anymore
-slight tapping/knocking during idle
-180,000 miles
I assume that when oil is not being sent properly throughout the engine pressure builds up in the engine and causes leaks in the valve cover and radiator. Now if I replace the radiator with a new one and replace the valve cover gasket, will my engine lock or blow up? Should I replace the oil pump before sealing the leaks?
Any comments will help. Thanks.
Old 08-21-2008, 07:02 PM   #458
lesterl's Avatar
Start a new thread man.
Old 09-09-2008, 09:30 AM   #459
On truck replacement of timing gear possible?
Is it possible to replace the Iron Duke's camshaft timing gear without taking the engine apart? Once the grille, radiator, fan etc. are removed, there is plenty of room to work on the timing gear assembly while the engine is in the truck. But can anything be done except to admire the damaged parts?
Old 09-09-2008, 09:48 PM   #460
lesterl's Avatar
see post #458, It has been done tho.
Old 09-18-2008, 09:48 PM   #461
Hi !!
I'm trying for a long time now to find what's the problem
My 1996 jimmy 4.3 drinks too much fuel , it's consumes WAY too much fuel.
Ex : With 80$ ( +or- 14 gallons) .... I can barely drive 180 miles !
It's around 13 MPG
The tune up is done from A to Z (wire , spark plugs , Rotor , Cap , Air filter , Fuel filter .... )
The only thing I did not change so far on the tune up are the o2 sensors .
Brakes are not stuck .... Engine goes well .... No fuel leak , no leaking injectors (I removed the intake to check it) ...... Can't figure what it could be !! Any help would be appreciated!!!
thanks
Old 09-19-2008, 12:47 AM   #462
lesterl's Avatar
#1 Start a new thread
#2 Start said new thread in 4.3l forum not the 2.5l Iron Duke Forum
#3 Check your fuel pressure and post all your above info into that forum.
Old 10-03-2008, 05:54 PM   #463
TonkaTruk92's Avatar
I need help got a iron duke motor from a rebuilder is washington and put it in my truck and it leaks oil in the back some where, it looked like the plate i took it off and resealed it and it wasnt that, im stumped man. and the temp. gauge plug in the back of the block what does that plug look like?
Old 10-03-2008, 09:59 PM   #464
lesterl's Avatar
Not to be rude or redundant, start a new thread. This one is old and should be dead.
Old 10-14-2008, 03:53 PM   #465
WWW.CAROLINATRUCKSCENE.
FarEastDime's Avatar
Quote: Originally Posted by irondukeman
not to brag, just here to help... any questions or unsolved mysteries? i can just about answer anything about these little engines- i love them, i have owned 23 lol -
ok heres one for you, that i think i figured out but lets see what you think.
88 S10 standard trans, 2.5. when i was working at my friends garage another friend brought this truck to me. new problem came, it started stalling out every now and then, and then it was a regular problem, when it warmed up, and got up to about 55 mph, the shift light would pop on, and it would stall out and you wouldnt be able to start it for atleast a half an hour. he replaced fuel filter, plugs before bringing it to me. luckily there was a boneyard in our town that my boss knew the owner pretty well, so we swapped out the dist, ecm,, and after my friend didnt want to dump any more into it he gave up and sold it to me for dirt cheap. what your oppinion.
Old 10-14-2008, 07:48 PM   #466
lesterl's Avatar
I think the Dukeman is gone, or DOA. RIP IRONDUKEMAN
Old 10-14-2008, 08:06 PM   #467
so what your saying is no one has an answer for me??
Old 10-14-2008, 09:52 PM   #468
lesterl's Avatar
NO, saying this is a long dead thread, start a new one so if some answers come to you that it will be easier to understand than a thread with 500 posts and 200 questions especially if someone else is having trouble too then they can look for the title and say "hey thats what mine is doing, wonder what they found out." Like I said not trying to be rude, this thread is dead it is easier to troubleshoot and answer a small thread.
Old 10-18-2008, 07:59 PM   #469
I've got a 88' short bed std. cab. With a 2.5 5spd. How many horse's or should I say. Lack of horse's doe's the two five put out. I just installed a new catylic converter and a 40 series Flowmaster. Boy it sure didn't sound like I expected it to.
Old 10-19-2008, 05:12 AM   #470
Batty's Avatar
heres one for ya knowlege... The lil sticker on my fan shrouds decayed to the point its unreadable...
Whats the timing suppose to be set at on an 87 2.5L l4... and all my repair manuals just say to "read the tag under the hood".. but like i said my stickers are all decayed under there...
Old 10-19-2008, 08:29 PM   #471
fix my truck.
see my thread.
Old 10-19-2008, 09:46 PM   #472
lesterl's Avatar
Veteran, duke rated around 95HP.
Batty, all GM 4 cyl are 1,3,4,2 firing order.
START A NEW THREAD, lets not clog this one up furter.
Old 10-20-2008, 03:41 AM   #473
Batty's Avatar
dont need the firing order... was asking how many degrees the timing needs to be set at... firing orders stamped right into the intake..
Old 10-20-2008, 09:17 PM   #474
lesterl's Avatar
8* With A/B terminal on ALDL jumpered, been mentioned in other threads ALOT, the search function leaves a lot to be desired, but it does work.
Old 10-21-2008, 06:28 AM   #475
Batty's Avatar
ty... me and search boxes never get along.... they never find what im looking for...
Old 11-06-2008, 01:33 AM   #476
Well let me start out by saying I have a 89 s10 l4 standard transmission
When I first got the truck, it started but shuttered very hard until the truck began to idle high and gradually smooth out! It had a lot of drag when I drove it home which there it sat until I began to work on it
My dad and i manually set the first piston to TDC on the compression stroke today to check the timing because we figured the previous owner just got the timing all whacked out! So we start it up BEFORE we try to time it and everything sounds smooth and better than before, we then base timed the engine and then cut it back off to tighten everything down, and now when we start it back up, IT SOUNDS JUST LIKE BEFORE IF NOT WORSE! AND THE DAY ENDED WITH THE TRUCK NOT WANTING TO KICK OVER ANYMORE !
One second its runs like a champ, and the next it doesnt run at all!!! Any ideas? IS IT THE TIMING OR WHAT???
While I was in there I also checked out the:EGR,and changed the spark plugs (except for 4) cause my dad thinks its stripped out!!!
Old 11-06-2008, 01:34 AM   #477
Old 11-10-2008, 03:57 AM   #478
I've got a 88' S10 std. cab. short bed. 5speed 2.5 my question is this. How much horsepower (lack of) doe's the 2.5 put out! My 40 serie's definately don't sound off like it should... Flowmaster suggested to have at least 160 horse's or better. Would a K&N,Tornado and maybe a performance injector do the trick? I'd like to keep the 4 but if not I'll go to either a 2.8 or 4.3 V6 Thanks Sam B Elyria,Ohio
Old 11-10-2008, 02:08 PM   #479
Batty's Avatar
for 88
2.5L's had an output of 92hp/132 ft-lb
2.8L 125hp/150 ft-lb
4.3L 150hp/230 ft-lb
Old 11-17-2008, 02:33 PM   #480
kaba168's Avatar
Ok here is my question. I have an 87 4x4 with a 4 spd man. and a 2.8, I would like to drop a 2.5 in it. What kind of advantages/ disadvantages will I have with this setup?
Old 11-18-2008, 05:39 AM   #481
Batty's Avatar
im not sure on this point.. but ive heard the cross memebers were different between the L4's and v6's.. but dont know 100% on that.. so hopefully someone else will be able to answer that part..
As far as advantages... greater hp and tq.. which would allow you the oppertunity to pull heavier trailer loads than you could with the L4... Little quicker acceleraction because of the hp and tq the engine wouldnt be having to work as hard from a dig..
main dissadvantage i could see for it is slightly worse gas mileage.. but i dont know what the v6's from that yr were getting.. my 2.5L L4 gots 17mpg before i rebuilt the engine...(it had some issues) but now its getting 22 mpg..
but there is quite a few performance parts out there for the v6 to help it get more power and better fuel mileage if you know where to look.. or least so ive heard..
Old 11-18-2008, 11:40 AM   #482
kaba168's Avatar
So, you would recommend I stay with the 2.8?
Old 11-18-2008, 11:33 PM   #483
Batty's Avatar
woops i read that as going from 2.5L to the 2.8 when i replied... but in answer to your second question.. yeah id stay with the 2.8L...
Old 12-19-2008, 01:24 AM   #484
I have a '96 4wd 4.3 jimmy.
Left work today, was like 12 degrees out.
Soon as i hit the road, my engine light came on, and it seemed to idle kind of strange when i got to the gas station.
Got home, shut it off, restarted, and gave it some gas from throttle body to check for engine noise. Revved to about 2500 rpm's, and let off, and idle set at 2000 in park and neutral.
Haven't checked DTC yet, but will tomorrow.
Any ideas?
Old 12-19-2008, 02:41 PM   #485
lesterl's Avatar
Any ideas?
Yeah, dont mean to sound rude, but this thread is dead and in the 2.5l forum, try the 4.3l forum.
Old 01-05-2009, 07:42 PM   #486
I've got an '89 2.5L 2wd. Rebuilt the bottom end and put the engine back in. It didn't start at first. We loosened the fuel fitting at the throttle body to check for fuel; there was gas there. The truck started. I started it for a few days and eventually drove it down the road. The second day of driving it, I went up and down my road a couple times to get it up to temperature and when I stopped back at the garage it wouldn't start back up again.
Once again, we loosened the fuel fitting and w/ the key on gas presented itself lol
Any ideas?
Only 22,000 miles on the truck... but it had been torn apart for 6 months that I know of, before I bought it and put the engine back together..
Old 01-05-2009, 09:48 PM   #487
lesterl's Avatar
Any ideas?
Start a new thread that is easier to follow. THNX.
Old 01-11-2009, 05:29 PM   #488
so ive had an oil leak in my engine for some time now and i tried fixing it by replacing the valve gasket but its still leaking a little from some place else. and when i look under the engine i can see its coming through the flywheel and the transmission. do you have an idea of where a possible leak could be coming from?
Old 01-17-2009, 08:17 PM   #489
S10toSonomaowner's Avatar
Any idea or suggestion on how often the transmission fluid on the manual 5 speed transmission should be replaced?
I found where I should change the differential fluid once a year or 12000 miles or 20000 kms here in Canada but can't find a recommendation on tranny fluid. Any info appreciated.
Old 01-18-2009, 01:15 PM   #490
lesterl's Avatar
Start a new thread for your issue if you want a reply, Irondukeman hasnt posted in nearly a year.
Old 01-18-2009, 02:53 PM   #491
Moderator
What?'s Avatar
Time to Close, ANY FURTHER QUESTIONS. Search, research, PM member/s, start new thread.
Page generated in 0.65985 seconds with 31 queries
[Output: 178.25 Kb. compressed to 163.11 Kb. by saving 15.15 Kb. (8.50%)]
