square body man
test my knowledge-
not to brag, just here to help... any questions or unsolved mysteries? i can just about answer anything about these little engines- i love them, i have owned 23 lol -
square body man
Re: test my knowledge-
a little engine info-
fuel problems! dont we hate them? most of the studdering and cold weather issues and hard starting derive from this issue. most fuel issues come from when a s-10 sits for a while or a fuel pump goes down. the plastic/foam pipe that connects it is usually eaten up in the process of the transformation from gas to turpintine. then, most people unknowingly (like me) change the fuel pump and try to crank it, throwing that gunk into the throttle body, which basically has the same affect of sugar. in the process, it travels past the fuel filter, into the tbi, with no problem, and is partially burned away. the rest tries to make its journey back to the fuel tank, but is stopped at the fuel pressure regulator and is built up along the bottom edge of the rim. fuel the pressure regulator is at the side of the tbi on top, it has 4 torx bit screws that retain it. simply clean it and it will help alot. as for the IAC get trash also, so it should be removed and cleaned and adjusted. it is on the passenger side at the bottem with 2 torx bits retaining it with a small harness. the extention and nozzle should not extent more than 1 inch passed the plastic housing. tpi sensors do go bad and autozone does test them. as far as missing, or lean fuel, the hall effect in the distributer wears out also. it picks up a magnectic current to open and close the injector. sometime those little tanges rust and it doesnt pick up the signal as well as it should. sand paper and wd40 fixes that. the hall effect is under the rotor button and can be removed with a 5.5 mm socket, two small boths with a pigtail harness with three prongs. it also varies the amount of fuel consumption in conjunction with the mat/map. explains poor fuel mileage. injector issues, leaking or dripping injectors- there are two rubber o-rings that dry-rot after a while without running. one small at the tip of the injector, which no book depicts how it is to be placed, and the top one, that has a grove for it, which i havnt seen that one go bad yet, but the bottom one fails alot, causing rough idle and poor compression on the #4 cylinder because of leaking fuel and washing the cylinder wall. some much for fuel erg system erg valves get stopped up alot, causeing rough or high idle and poor operating conditions. quick way to test it! first remove it. remove the breather, and get a 1/2 in wrench. open end part, remove the two bolts that retain it and dont break the vacuum line in half, they are hard to find. take it off and suck the vacuum hose with your mouth, usually you can hear it actuate. if not, its stopped up. clean it good or replace it. 2.5 will smoke it the egr system is not hooked up properly. one big metal line from the valve cover to the side of the tbi, make sure it is not stopped up and the pcv (positive crank case ventilation) valve is not all gooed up. next, which is not orthodox, i prefer to plug the second pcv port that runs to the breather, on the back of the valve cover. i have expirienced better gas mileage doing that and the vacuum is stroger in the crank case which removes stress from the main seal to aid is the loss of leaks. nothing more to say here. timing, pain in the ass, inductive type light, 8* btdc idle idle is sometimes high, due to the little idle screw backing off. attach a tach to the negative wire to the dist. and get ready to adjust! the screw location is located beside the IAC, but its hidden behind a little backout preventer which will have to be punched out to be adjusted, small phillips head does the trick evey time. should be adjusted to around 600 rpm or what your under hood sticker says to adjust to. check your erg valve first before any adjustment. MAP sensors do go bad but still function somewhat. best thing to do is remove it and take it to get it tested at autozone. keep in mind, autozone does not charge to test it. replace because there is no adjustment. valve noise very rare in my opinion. valves cannot be adjusted, only replaced. if you have a sound like a tap, its one of two things: cam gears or a lifter not priming. i covered the timing gears below. valve seals are a common problem, leaking and causing a fuss with smoking and burning oil. how to change them: remove the breather, remove the valve cover with a 10 mm socket. remove the spark plugs and take off the battery cable. start with cylinder 1, turn it so that it is tdc (top dead center) and find a about 5 foot of 1/2 inch rope. turn the cylinder so that it opens a little, about half a stroke. fill the cylinder with rope and LEAVE ONE END HANGING OUT, trust me. turn the engine so the it compresses the valves up on the compression stroke, threfore, making your valves stay seated without compression! take a spring comressor lever (i make mine) and compress your springs, remove the keepers with a magnet and DO NOT DROP IT!, pull the valve seal and buy you some new ones, replace the sping and keepers put everything back together and your done! no more leaking without removing the head! cam gears- sound like a lifter worn out, ya know, tap tap tap tap at an idle... get the haynes manual for this one! any questions? Last edited by irondukeman : 12-31-2007 at 05:00 PM. |
Has Training Wheels
i recently have been getting horrible gas mileage.
i took my cat converter off in the spring, and ever since, it started sounding worse and worse. from the exhaust tip, it sounds like popcorn inside the exhaust, it just sounds like popcorn popping, and it keeps getting worse. check engine light was on and n oone could help me, so i took it to the dealership, $250 fo rifx ignition module, and it still did it, but then the engine started knocking and it kept dying on me, took it back, they replaced egr valve, still knocked. so i went and bough ta new ECM, because on the way home it acted up, the SES light came on, started flashing at me, random flashes some slow some super fast, no pattern. hasnt done it since. then my engine overheated 250F, so we replaced head gasket, intake, exhaust gasket, water gaskets, spark plugs with acdelco, and it ran good, but i checked my mileage, going 55mph, i got 14.9mpg when i got 28.9mpg going 65 ![]() we tried to hand turn the crankshaft with a socket wrench, and we couldnt even move the crankshaft, it was bound up and didnt want to move, but yet it moved before. so far it drives great and acts normal, but its using ALOT of gas. i topped it off, and ive gone 40 miles and im 1/16th past full, so its used up about 1/8th of a tank? 13 gallon. the mileage has been getting worse and worse, i remember it being at 18mpg once. it baffles me because ive replaced so much of my engine that the only thing that i can think of, is the cat converter not being on is getting me bad mileage and making my exhaust sound like popcorn at idle. it doesnt idle high, its timed at 8* btdc, heres what ive replaced spark plugs,wires,cap,rotor, ignition module tps sensor map sensor exhaust manifold, straight piped to a super turbo no cat serpentine belt electric fan-was on when i was getting 28mpg highway battery starter radiator head gasket,intake gasket, exhaust gasket, valve cover, water gaskets IAC was cleaned out twice egr valve-dealership put in air filter, fuel filter, oil filter, 10w40 oil 35psi in tires, same as when i was getting 28mpg im thinking the cat converter is the main problem. when i bought the truck, the stock front coolant temp sensor was unplugged and an aftermarket water temp gauge was hooked in. the dash coolant gauge kept fluxuating so much it would go from 100* to 280* so fast it would make a ticking sound. so i rehooked up the old water temp sensor, and it didnt make any diffrence. the gauge doesnt work at all. ill have to check mileage for city this weekend, i only drive it 25 blocks a day, so its not like i drive it very far. this spring, im gonna have a cat converter welded in, get a new ignition coil and spark plug wires, and both coolant temp sensors. the truck runs great, just gets horrible mileage |
square body man
well, does your engine vibrate any? auto or manual? check the harmonic balancer if it has one- some do, some don't. the go bad if it is equiped and it will throw off a bunch of things too
try one thing for me and i can tell you alot of things by this- take out all you plugs, then rotate the crankshaft by hand, any resistance? any grinding? noises? air, unusual smells like burned metal? when was the last time you changed your oil? did it have metal shavings? or gunky like material? |
Has Training Wheels
changed oil 2-3 weeks ago, had 700 miles on the oil before i changed it, we changed the head gasket and changed oil and filter before we started it up.
oil was fine, no water in it or anything. looked good enough you could almost put it back in, minus it being dark brown, not black. no metal shavings, no gunk, nothing. i just took the crankcase breater tube off, started it up, and it ran like it normally does, just a HAIR better, the exhaust sound went away HALFWAY, its still there, but at idle, it actually sounded like a v6 instead of a popcorn machine, it still has it, but not as badly. on revving up, its got a slight whooshing sound, like the sound a fan makes. which leads me to beleive its because of no cat=no back pressure=whooshing air. my engine does vibrate a little bit on start up and when you turn it off, whole truck moves on shut down. its a 5 speed, 99915 miles the main thing that made me and my father change head gasket, was it overheated, and there was some yellowish clear liquid inside the air filter, coming from the crankcase breather. i was told its just condensation. when i blocked off the crankcase breather, the engine didnt really vibrate at all, it has a ticking noise thats been there since i bought it, havnt been able to find where its from. the valves on the cylinder side looked brand new other than being black, no damage or sign of hitting. the truck runs and drives fine, its just not getting as great of gas mileage, and the exhaust sound is embarrasing i dont have anywhere to work on it, so doing something like taking out spark plugs and checking that wont happen till spring, im open to ideas, its not that big of a deal right now, becuase like i said, i drive it 25 blocks a day, on weekends i dont even drive it unless i need to, so $15 lasts me 1 1/2-2 weeks, in the summer $25 would last me a week, cause i drove it all over nonstop Last edited by beaniebmx : 12-31-2007 at 08:56 PM. |
Ill let you know if I need you shortly. I was having a few problems. Also, my work just got a modis scanner from snap-on, Im learning how to use it on my truck. I was having rough idle when cold, then high idle when warm. also, my timing would jump around while trying to time (10-20 degrees in either direction) I replaced the map because even with the vacuum line unhooked, i was still getting jumpy readings. That straightened up my timing problem. But today it acted up again, and I got a check engine light for low circuit or short in coolant temp circuit. So I hooked up the modis and low and behold i got 300* C in the motor (whats that like 600*F?) I just replaced the coolant temp sender in the front of the motor with a brand new GM one, so I know thats good. I actually cut the 2 wires going to the ECM and it still read 300*C. So i ran the service numbers on the ECM, low and behold its for a freekin trans am with a TPI 305. The idiot that worked on it before me replaced every single electrical part on the truck except for the bad one, sometimes replacing them with the wrong one (coolant temp sender and ECM) So Hopefully the junkyard is open tomorrow. HERES ONE FOR YA RIGHT NOW!!!! Can I use any ECM with a 2.5 manual for this truck? I was picking through a Fiero with a 2.5 in it. For the 1st time in 5 years the closest j-yard to me had no s-10s or blazers! Also, considering I dont know the proper ecm service code for this truck.
square body man
if the car is a 5 speed and so is your s-10, it should be compatible, but make sure to look at the ingnition coil on the pontiac fieros engine and make sure that it has a distributor and not 4 sperate coils, because that differance will not be compatible. the chevy 2.8 has the same computer though, i cross reference the part number at GM parts place and there is really no differance in the parameters nor part number. be careful not to get a 4.3 computer because that is the same as the chevy 5.7 ltr computer |
I just got back from the junkyard. I found a truck identical to mine in options except it had a 5 speed. I took the ecm and put it in mine, I am now getting ALL correct readings and the truck runs excellent.
i cannot find the where to hook up the green wire. i cant find the symbol on coil either. i diagram would help very much. i have looked at the other posts but am still having problems
square body man
You can't say fuck
Location: 26.34°N 127.78°E -39.96Ft. User is: OffLine |
I got a puzzle for you...Figure out the answer to the forum guveaway and send me the answer =PP
square body man
im looking at engine bay. the plug that sends the wires to the distributor. negative one right?? there are two wires. im hooked into one of them. there is a plain black and a black one with a purple stripe.
square body man
square body man
i got all my wires hooked except for the green. my dad told me to hook it to the negative side of the coil. i found the negative side and spliced into one of the wires. nothing is working in thetach. only the light. i dont know what i did wrong. ive neverstalled them in a truck like this. only v8s
just registered. iam looking to buy my first truck, and just waiting for a good s10 to come up on craigslist, i want one that has a good engine and thats about it, so i am coming to you for advice to tell me how these engines are, are they bullet proof or if not cared about break down easily. because its been a headache finding one with low kilometres/miles. and iam just wondering if a s10 with high miles have problem after problem.
i know if any engine is cared about they want last very long but generally how durable are these engines. thanks |
Has Training Wheels
2.5l suck for power, if you just want good gas mileage from a 1st gen and dont care about speed power, or exhaust, go for it, otherwise get a 4.3l
on a sidenote, i just checked my fuel mileage, 14mpg CITY, driving like a grandma, not bogging the engine down or anything. im hoping its just the weather, because i know theres a diffrence when driving the truck 5 blocks when its 10F out compared to 60F, but getting 14mpg city is worse than most v8! so plugging in my old coolant temp sensor into the water neck, did nothing. |
square body man
they are good engines, and gas savers.. just not hot rods |
square body man
thanks for the input.... so basically if they were takin care of, they should be fine to buy with high mileage.
i while back i was reading "truckin" magazine and they had an article about these little 2.5's, and i dont know if its worth it but they make air intakes, headers and exhaust for these things, i just dont know how much they help, but it cant hurt. |
Has Training Wheels
air filter is a few weeks old and still looks brand new, the filter before that wasnt that old either, changed them every 3 1/2 months/3000 miles
not sure if the injector is clean, its been a few months since ive ran injector cleaner through it |
[quote=insane polack;4778378]thanks for the input.... so basically if they were takin care of, they should be fine to buy with high mileage.
#24 |
square body man
they also have D shaped exhuast and air intake ports into the heads, and no room to port them. the heads are solid and stead. pontiac did make a z head for these engines used in the fieros, that flow alot better, and have round ports, but you have to use the stock intake with the heater lines in it because it flows through the engine into the intake and the to the radiator in that order, and omission of th heater lines in the intake will result in starving the upper engine of coolant. as far as dependability, as long as they are not over revved to much in the past, they are ok. they have small and i mean really small crankshafts and wristpins. they are great engines though, alot better than the old 2.5s in the vegas and monzas, that have the stovetop engines. just make sure it dont knock or has low compression. even if they do, they are a really easy rebuild,basic engines, i have taught alot of people how to rebuild engines using these becaue the are soooo simple. Last edited by irondukeman : 01-03-2008 at 09:34 AM. |
#25 |
Has Training Wheels
i rebuilt the whole top end of my motor, to replace a head gasket, and i dont know anything about motors, but after reading haynes manuel and on here, i could probably pull the engine and reuild it all to showroom specs
![]() as long as it was a daily driver/highway miles and an older guy/girl driving it, it will be good, but if some punk teenager was driving it doing burnouts and revving to to redline like import racers do, then it may not last as long, may not even make it a few blocks ![]() |
#26 |
yeah for sure, thanks guys.
#27 |
whore turned lurker
only thing i can't figure out is the valve lash, everywhere just says to torque the rockers to 30 ft-lbs but i wanna check the actual lash.
#28 |
Has Training Wheels
my book says to torque the rockers to 24ft lbs
#29 |
whore turned lurker
i still wanna know actual valve lash not just torque specs,things wear and clearances change
#30 |
There is no lash, this motor has hydraulic lifters, the lifters expand with the wear of your engine.
#31 |
square body man
#32 |
cup of transmission fluid? Ive heard of this before, do you keep it in there or do you change it after awhile?
#33 |
square body man
#34 |
Has Training Wheels
just dumped in some tranny fluid into my oil, 1 cup, we'll see what effects it does, ive been having valve? noise ever since i got the engine, with the aircleaner lid off you can hear it ticking, not sure where its coming from but its there.
i have valve stem seals, but me and my father didnt want to mess around trying to get them in. |
#35 |
Stockin'!
Hi Irondukeman, thanks for the thread should give some help to people.
Anyway, I have a 1990 S10 2wd 2.5L it has about 109K miles on it. I recently noticed the idle being high. I've taken the ERG out and put my finger over it and there was no change in the idle than when it was in the head. I've noticed a small oil leak at the back of the head and I was wondering if that could be the cause of the high idle or if the ERG valve is just bad. But to the best of my knowledge the guy who owned it before me said it was getting 19-21MPGLast edited by DietP : 01-04-2008 at 08:13 PM. |
#36 |
whore turned lurker
#37 |
#38 |
Yeap,
My injector with the air cleaner top off sounds like 2 skeletons fornicating on a tin roof! willie |
#39 |
really? mines just a really fast, "tick tick tick tick tick tick tick tick tick tick tick ..." lol |
#40 |
Has Training Wheels
so thats what that sound is
![]() all this time i thought my engine was ready to blow up ![]() |
#41 |
whore turned lurker
#42 |
square body man
#43 |
square body man
#44 |
One thing I should add...... When i was lookin to test my EGR, it said you cannot test it using a vacuum pump because it will not hold vacuum, it needs vacuum from the other side to actuate.
#45 |
I.D.Man: About base timing, what has been your experience with it? Is 8 BTDC just 'OK' or does the engine benefit from being set at 10 or 12??
#46 |
I.D.Man: Also, I read somewhere that you can buy a harmonic balancer (originally for fieros) for the older 2.5's (mine's an 86), but I can't find that thread. Do you know the part number?
#47 |
Has Training Wheels
off of a gauge view, and mileage count, i seem to have gotten way better mileage than before, ive gone 50 miles and im still above 7/8ths tank, halfway between the full line and 7/8ths, last time i filled with city only driving, 56 miles got me to 3/4 tank, so with my estimation, im at 18-20mpg city range?
all i did was block off the pcv crankcase breather on the valve cover, put 1 cup of transmission fluid in my oil, and lightly sanded down my Hall Effect Switch, or whatever is under the cap, it had 3 t15 screws, and 2 holding some black peice ontop for the rotor, the 3 screw deal slid off an dhad a magnet on the bottom, it looked rusty, so i lgihtly sanded it and sprayed wd40 on and let it dry, still got popcorn sound from my exhaust, but so far so good, my check engine light came on yesterday, code 32=egr or 4wal but i dont have 4wal so its egr. i paid $120 for the dealership to replace my egr and its related parts... so i reset the computer and it went away and hasnt been back, but now it idles high at startup for a second, not a big deal its normal? ill check my mileage after i get to like 1/2 tank, especially at $3.17 a gallon! hopefully itll drop, it rose 20 cents ![]() Last edited by beaniebmx : 01-08-2008 at 06:03 PM. |
#48 |
Wannabe Dragger
This one shouldn't be too hard for you. A co-worker has a 90ish 2.5 5-speed. Last year he had the distributor replaced because it would crank hard when it got moist out. Now this year it started cranking hard again recently (it's been moist lately) and just today he was cranking it and it wouldn't start. Now it's doing nothing, probably killed his battery, but even if he charges it, I doubt it'll start. Any clue?
#49 |
The Eye is watching you!!
condensation in the cap. Mine's doing the same thing right now. Continued cranking will just (as you found out) kill the battery. new cap frequently or dry it out before you start it whenever its moist
#50 |
Wannabe Dragger
That's all you can do, honestly? Isn't there a seal or some shit that should keep the moisture out so you don't have to? If not, is there an aftermarket one that has a seal?
