So I took it to the dealer today...
Old 10-27-2008, 08:32 PM   #1
FF7
FF7 is on a distinguished road
these events are interesting since my last post was asking about a future build, now it's a necessary one. I took the truck in to the dealer today because the tranny was slipping quite a bit, and a fluid change didn't help any. Also because there was oil in the air filter housing coming in through the breather filter. The tranny needs a new valve body, thats getting thrown in. He suggested just leaving the oil in the air filter housing alone, because it's probably time for a rebuild (which he made very clear was not worth the trouble for this engine). Seeing as how something needs to be done about the engine, I've been toying with a few ideas, the first one was this:
1) http://www.gmperformanceparts.com/En...230&engCat=rpo
However, I'm fairly sure I wouldn't be able to use my transmission, computer or radiator so I'm not gonna go with that unless someone knows a magical way to mate it with my tranny.
2) Finding a shop to rebuild it the way I want it rebuilt, a bit higher compression, and new internals.
3)New engine from autozone, advance, or Napa.
4) Do not suggest V8, gas mileage is something I'm trying to preserve here.
Any suggestions?
Old 10-27-2008, 11:42 PM   #2
~Sunkin Sins~
Wybrow is on a distinguished road
Re: So I took it to the dealer today...
Quite honestly, if you have some oil in your air filter housing, big frigen deal, replace your PCV valve and drive on. By no means do you have to replace or rebuild your engine. If you went to a GM dealer you either misunderstood them, or they are trying to yank your chain. A valve body is completely legit for your tranny, but a motor, come on.
Old 10-27-2008, 11:48 PM   #3
Wire Splicin Fool :-)
lesterl's Avatar
lesterl is on a distinguished road
X2^^^^
But if you want a 3.4l get one out of a RWD Camaro. What trans is in the truck now?
What MPG do you get now?
Swap that auto for a T5.
Old 10-27-2008, 11:54 PM   #4
is that fender straight??
dimerunner88's Avatar
dimerunner88 has much to be proud ofdimerunner88 has much to be proud ofdimerunner88 has much to be proud ofdimerunner88 has much to be proud ofdimerunner88 has much to be proud ofdimerunner88 has much to be proud ofdimerunner88 has much to be proud ofdimerunner88 has much to be proud ofdimerunner88 has much to be proud of
the 2.8/3.1/3.4's have the same bellhousing pattern as the 2.5
but anyway just replace the crankcase filter and pcv valve and the oil should stop.
Old 10-28-2008, 12:14 AM   #5
FF7
So the guy, might really be full of it? he did say he didn't look at the source of the oil, just assumed that it was an engine on it's way out...
Also the 3.4 would bolt on to a 4l60?
Old 10-28-2008, 12:30 AM   #6
lesterl's Avatar
you have a 4l60? That explains the valve body issues. I thought the 2.5 had the small block bolt pattern? Not the 60* pattern, I dunno. Sounds like Dime may have done that before.
Old 10-28-2008, 12:39 AM   #7
FF7
That's just my assumption. It's a 93' A code sonoma automatic, I thought those came with 4l60, I may be wrong.
Old 10-28-2008, 12:46 AM   #8
lesterl's Avatar
700R4 I believe.
Old 10-28-2008, 12:53 AM   #9
FF7
700R4 I believe.
Ok, I don't believe that would mate with a 3.4. Thanks for clarifying. Here's my plan: I was planning on getting the head redone anyway, so i'll have that pulled and when it's pulled the necessity of rebuilding the bottom end should be obvious when the head comes off, correct?
Also, how much could I learn from compression check readings about the necessity of a bottom end rebuild? I've got the results, I'll post them tomorrow. Cuz if they can shed a significant light on what is necessary I'd like to hear what you guys think.
Old 10-28-2008, 01:18 AM   #10
lesterl's Avatar
I would think maybe Oil pressure hot at idle should tell you more about bottom end fitness. Whats wrong with the head? Compression will tell you about compression i.e. rings/ valves/ cylinder linings.
How many miles are on the thing?
Does anybody know about the little old white mail trucks? They have a Duke in them!
Old 10-28-2008, 08:23 AM   #11
FF7
It's got about 105,000 on it.
Old 10-28-2008, 10:46 AM   #12
~Sunkin Sins~
You dont need a motor, the guy who told you that is full of shit. Replace your PCV valve, clean out your air box and replace your air filter, drive it for a week or two and you should notice there now is no oil in your airbox. Oh, and go back to the dealer you went to, and smack the asshole you told you that.
Old 10-28-2008, 04:12 PM   #13
a 4l60 and 700r4 are the same transmission,there are two different types though. theres the 60 degree bellhousing trans and the 90 degree bellhousing trans. the only difference is the case,the bellhousing is different of course. the inside parts are the same components.
Old 10-28-2008, 10:17 PM   #14
lesterl's Avatar
I would still drop a T5 in it as the auto is prob a dog.
Page generated in 0.15356 seconds with 11 queries
