missing
Old 10-27-2009, 09:50 PM   #51
Re: missing
Alright thanks. Yeah I forgot to check that. I'll go look at it real quick.
Old 10-27-2009, 10:14 PM   #52
Re: missing
I just pulled out the PROM then put it right back in and then started the truck up, (it was still warm) and it didn't seem to make any difference.
The ECM said remanufactured by GM on it...
Old 10-31-2009, 04:43 AM   #53
Re: missing
New problem-
Yesterday I my truck started being difficult to start. By that, I mean that I now have to crank it over for a while for it to start.
What could cause this? Leaky injector? Dying fuel pump?
I don't think I have any kind of fuel leak, as I have never noticed smelling gasoline when I am around my truck.
Old 11-01-2009, 06:25 PM   #54
Re: missing
This morning I changed the fuel filter, and I'll post up later tonight whether or not it helps my hard to start problem.
Old 11-02-2009, 10:37 AM   #55
Re: missing
I have the exact same problem as gregz-28 post on 10-31. Yesterday, I took the injector out and switched on the fuel pump. Immediately lots of fuel gushed into the throat of the TBI. So it's getting plenty of gas to the injector. If I give it some ether, it will usually start, but I have to keep the throttle fairly wide open to run. It also will run fine once it "gets going". When I look inside the TBI when it is running, usually someone else has to press on the gas pedal to keep it running, I see gas dropping from injector, and swirling on the walls on the TBI. It appears its flooding out when trying to start, hence the hard starting, due to a bad injector not providing a misty fan spray to the TBI. It would also explain why going down the road there's no problem, because it can burn the excess fuel being delivered to it. Does this seem to make sense? With the injector installed, and by turning on the fuel pump, but not starting the engine, should you be able to see a fine misty spray inside the TBI coming from the injector?
Old 11-02-2009, 11:59 AM   #56
Re: missing
Just as a FYI, my 4.3L truck is doing the same thing right now. Weak fuel spray and by pressing the gas its opening it up more so it will fire and start. I think a few of us are gonna be buying fuel pumps soon.
Old 11-02-2009, 02:11 PM   #57
Re: missing
Quote: Originally Posted by Shaddix
... I think a few of us are gonna be buying fuel pumps soon.
Maybe someone will give us a group discount
Changing my fuel filter didn't help, but it was the cheapest possible solution, so it was worth trying.
Over 488 miles I drove in about 2 weeks, I got 23.6 mpg. Is this good, bad, or normal?
Old 11-02-2009, 08:46 PM   #58
Re: missing
Hey, I got my ole boy going! I feel embarrassed, but all it was, was the PLUGS! New plugs in, and he started right up. Stumbled a little, but as engine warmed up smoothed out. Drove him down the road, lots of power. I think now I'll do the rest of the tune-up. DUH. Sometimes we overlook the obvious, at least I do.
Old 11-03-2009, 10:44 PM   #59
Wire Splicin Fool :-)
lesterl's Avatar
Re: missing
An EP386 (AC Delco) pump on www.amazon.com $47 free shipping, if you apply for the Amazon card IIRC they give you a discount from there...
Old 11-04-2009, 02:50 AM   #60
Re: missing
I do hope I don't need a new fuel pump. I haven't looked into my new problem again yet.
My EGR valve didn't show up today, (**** fedex) but now they say it will tomorrow.
How should I hook up a fuel pressure gauge, and how much pressure should I have?
Old 11-04-2009, 11:01 PM   #61
lesterl's Avatar
Re: missing
12+ PSI
You will have to unhook the filter and hook up there or at TBI.
Old 11-05-2009, 01:50 AM   #62
Re: missing
Quote: Originally Posted by lesterl
12+ PSI
I'll try hooking one up at the throttle body, I discovered the other day that it's a PITA to access the fuel filter.
Today I received and replaced my EGR valve, and it still runs the same, ( ) but it still hasn't given me any codes.
When I took the air cleaner off I noticed that it looked like smoke was coming out of the throttle body. Could that be a sign of the injector leaking? Or could it possibly be exhaust gas?
My truck always has shut off a little rough, but I'm not sure if that is relevant.
Another new problem: This started the other day. My blower motor usually doesn't work, but it will come on partly sometimes. I replaced the switch, and that didn't fix the problem, so I tested the voltage at the motor, and it was receiving 12 volts in every speed, except for off. It seems like it should be receiving less than 12 volts at lower speeds? And if the blower motor was the problem, wouldn't it not work all the time?
Old 11-05-2009, 10:21 PM   #63
lesterl's Avatar
Re: missing
Sounds like the blower motor is open, hence reading 12v. If you are curious, hook a headlight across the +/- on the blower contacts and try the settings, intensity should change.
Smoke is a byproduct of combustion, could be possibly normal, IDK I am not there.
Hows the timing sitting? Fuel pressure yet?
Old 11-05-2009, 11:13 PM   #64
Re: missing
I know I will be. I have been having the starting problem for a couple months now. I figured it was the fuel pump as I have tried and tested everything else...I am hoping it fixes itself as I don't want to drop the tank.
Old 11-06-2009, 01:28 AM   #65
Re: missing
Damn man, you have owned your same S-10 for 20 YEARS? Thats insane! Id love to have driven my truck when it was BRAND NEW, I bet it felt so nice to drive and close the door and not worry about the latch and hinges breaking off =)
Old 11-06-2009, 03:25 AM   #66
Re: missing
I'll try to remember to try the headlight thing tomorrow. I didn't check the fuel pressure or timing yet. What is the timing supposed to be set to? There's probably a sticker under my hood that says...
Old 11-06-2009, 11:57 AM   #67
Re: missing
LOL. It's pretty hard to remember driving it without some sort of problem. I do remember that at 225000km wondering if the duke would ever pack it in so I could drop an small block in. It never gives me a $1000 bill to warrant a replacement motor but it does nickel and dime me. It now has 370000km and I put them all on. LOL.
I had this same truck and motor in the hayday of mini trucks. Used to travel up and down the coast with a club called Low Altitude Minis and showed at NorthWest Mini Truck Council shows. Oh the memories.
Old 11-06-2009, 06:13 PM   #68
Re: missing
Just now on my way home it gave me code 32 again.
Is it possible that my original problem and my hard to start problem are related, both being caused by a bad injector? Maybe I'll have time to test the fuel pressure tomorrow.
Old 11-06-2009, 10:21 PM   #69
Re: missing
Did you buy a brand new AC Delco EGR valve for the right transmission?
Is the truck still missing or whats it doing?
Just hard to start might be a bad fuel pump relay Ive heard, as it will take a while before the oil pump builds up the 4psi it takes to turn on the fuel pump without the relay through the oil pressure switch.
EGR needs to have the solenoid connected with the right valve installed. Is your code 32 consistant or does it come and go?
Old 11-07-2009, 04:00 AM   #70
Re: missing
Yes... maybe I'll double check the part# anyways...
Is the truck still missing...
Yes
I'll look into that. Do you know where the fuel pump relay is located?
The solenoid is connected.
I'm not exactly sure what you're asking. I'll try to describe what happens exactly. After I first reset the code after I got it the first time, it took a lot of driving before it happened again. After the SES light comes on, it soon goes off, but the code is stored. Even though the code is stored the light won't come on while I'm driving after it happens once.
Old 11-07-2009, 02:05 PM   #71
Re: missing
Yes
I was asking about the code coming and going, because on a few trucks, the code 32 will come on and go away while your driving it. It just stores the code and doesnt affect the way it runs. Highways it will try to test it, and when the EGR system fails to work properly, it will throw the code like yours.
Some people talk about the code coming on and staying on making the truck run in OPEN LOOP therefore never running very good at all!
I am just puzzled by your EGR solenoid operation. You said that you get FULL manifold vacuum through the EGR solenoid when the connector is plugged in and working even at idle. When the EGR solenoid is unplugged from the computer, it stops all EGR flow, because an idling motor should NOT have any EGR flow at all.
HOW ON EARTH IS THAT POSSIBLE? WHY IS THIS EGR VALVE OPENING AT IDLE? What the hell is the EGR solenoids job if it is open at all times including cold idle?
If the EGR valve is opening all the time, at idle, crusing, anytime the throttle plate is open, this is NOT THE WAY EGR's are supposed to work at all. It should only open on a part throttle cruise I thought???
Old 11-07-2009, 03:40 PM   #72
Re: missing
Sounds like what happened to me.
Yeah, I don't think that happened. Maybe it did the first time, and that is why the truck felt like it had no power while the light was on.
I must have said the wrong thing earlier. The solenoid recieved no power to it when I started the truck cold, for the first ten minutes it ran. My solenoid is hooked up to ported manifold vacuum, and it lets all the vacuum through it that it receives, but since it is hooked up to ported vacuum, there is no vacuum to it at idle, but it gets full vacuum once I open the throttle blade.
From what I can tell, the EGR valve receives no vacuum only during the first 10 minutes the truck is running and at idle.
Old 11-08-2009, 03:33 PM   #73
Re: missing
Hmmm OK then, well if you have a fully working EGR system, with an AC Delco valve and solenoid it should be working as intended!
The only things coming to mind is an older, slow reading O2 sensor that maybe is detecting changes slowly and when it tests and shows the reading is slow to the ecm, maybe thats is its part of the check????
The code is coming on when your ecm is checking the egr solenoid at part-throttle cruise at 40+MPH right? Not at idle...
I have the exact same problem as you man. To the tee in my truck. I need to buy an EGR valve for mine but you have just spent $80 on one and it isnt fixing the problem. Thats why I really am interested and concerned here as I dont want to buy a damn valve and not have it work!!!
Old 11-08-2009, 10:44 PM   #74
Re: missing
I already replaced the 02 sensor, didn't help at all.
Correct
I haven't done anything with my truck the last few days except drive it, so I'm really not making any progress with this problem.
Old 11-09-2009, 11:52 PM   #75
lesterl's Avatar
Re: missing
Fuel Pump relay is on the fender next to another relay.
I would check fuel pressure and fuel spray from the injector, is base time at 8*
Old 11-12-2009, 04:21 AM   #76
Re: missing
On Tuesday I tested the blower motor by hooking the wire to it up to a headlight, and I determined that the problem is the blower motor.
Haven't had time to do much else, been busy insulating the garage. It is cold this time of year!
Old 11-12-2009, 07:31 AM   #77
Re: missing
The blower you might just try unplugging the connector at the motor a few times, or just wiggling it around, while you have it turned on so can hear if it starts.
Old 11-12-2009, 04:37 PM   #78
Re: missing
Tried that already.
Old 11-14-2009, 11:00 PM   #79
Re: missing
today when I accelerated (trying to get into traffic, so 3/4+ throttle) and the truck was cold it would seem to miss/stumble at over 25 mph in 2nd gear. To me this would be another indication of a dying fuel pump. I still haven't tested my fuel pressure, because the other day when I was going to, I realized my fuel pressure gauge only goes to 10 psi. So, I think I'll just replace the fuel pump. It can't be that hard anyways. Tonight I'll order a new Delco fuel pump and a blower motor.
Old 11-15-2009, 02:51 PM   #80
Re: missing
Have fun bro! I gotta drop my Blazer gas tank this weekend and get a new pump in it too. Have you ever changed the fuel filter behind the TBI unit near the firewall?
Old 11-15-2009, 03:54 PM   #81
Re: missing
Yeah, that's kinda a PITA. Glad I don't have to do that for another 20,000 miles.
Oh and I am now getting 23.96 MPG.
Old 11-16-2009, 02:31 AM   #82
Re: missing
I checked the timing today, and I wish I would have done that a lot sooner. It was set to 4* advanced, and I set it to 8* advanced. It runs noticeably better, but it still has that same miss.
Old 11-16-2009, 11:46 PM   #83
lesterl's Avatar
Re: missing
Pull the bed to replace the pump instead of dropping the tank, 6 large bolts and lift the bed off.
Old 11-18-2009, 03:18 PM   #84
Re: missing
Why do I never think of this stuff? I guess that's why I come here.
Should I replace the flex lines between the tank lines and the body lines??, and what kind of hose is it, and how much do I need?
Now my hard start problem only occurs sometimes, not sure why that would be because before it started being hard to start it never was, then for a while it was hard to start everytime I tried to start it, now it is only maybe once a day...
My fuel pump should arrive tomorrow, and I don't have to work tomorrow, so guess what I'll be doing?
Yesterday I replaced the blower motor and now it works perfectly! I bought one from Napa instead of ordering one, it was a little cheaper at Napa.
Old 11-18-2009, 07:00 PM   #85
86, 2.5L, 4spd
Re: missing
Twenty years ain't bad, I've had mine for a tick over 15. Bought it used with 58000 on it for 4k back in 94, the thing was mint. I'm the third proud owner.
Old 11-20-2009, 12:06 AM   #86
Re: missing
Today I replaced my fuel pump, took about 1.5 hours.
I'm not sure if that fixed my hard to start problem, since it only does it sometimes now, but I'll post up in the next couple of days if it made a difference. It still has that miss though.
Old 11-20-2009, 12:28 PM   #87
Re: missing
How are your spark plugs gapped. Mine are at .060" like it says for stock, but I hear that these engine can really misfire at that large stock plug gap. I am gonna lessen my gap to see if it helps my intermittant misfire as well.
Secondly, have you replaced your fuel pump relay or checked it yet? It may be why your truck is hard to start because your oil pump has to build up 4psi of oil pressure from the starter turning until it kicks on the pump if the relay is dead. You will know if relay is dead cause it takes a lot longer to crank and start.
Old 11-20-2009, 09:44 PM   #88
Sending Big Oil a Message
Steady Eddie's Avatar
Re: missing
How are your spark plugs gapped. Mine are at .060" like it says for stock, but I hear that these engine can really misfire at that large stock plug gap. I am gonna lessen my gap to see if it helps my intermittent misfire as well.
Autolite AP666 from Walmart..they are platinum tipped and will last for many 10s of thousands of miles..best part is: they only cost about two bucks each. Gap 'em at 45 thou...
BTW--I changed out my fuel pump relay and the old girl starts right up, usually on the first cylinder up on the compression stroke..a remarkable difference...
These little motors LOVE a strong battery and GOOD grounds, they need both. And bad grounds and a weak(er) battery spell trouble.
Old 11-20-2009, 10:37 PM   #89
lesterl's Avatar
Re: missing
Hows the compression?
Page generated in 0.62653 seconds with 31 queries
[Output: 186.29 Kb. compressed to 171.51 Kb. by saving 14.79 Kb. (7.94%)]
