#51 |
Re: missing
Alright thanks. Yeah I forgot to check that. I'll go look at it real quick.
#52 |
Re: missing
I just pulled out the PROM then put it right back in and then started the truck up, (it was still warm) and it didn't seem to make any difference.
The ECM said remanufactured by GM on it... |
#53 |
Re: missing
New problem-
Yesterday I my truck started being difficult to start. By that, I mean that I now have to crank it over for a while for it to start. What could cause this? Leaky injector? Dying fuel pump? I don't think I have any kind of fuel leak, as I have never noticed smelling gasoline when I am around my truck. |
#54 |
Re: missing
This morning I changed the fuel filter, and I'll post up later tonight whether or not it helps my hard to start problem.
#55 |
Re: missing
I have the exact same problem as gregz-28 post on 10-31. Yesterday, I took the injector out and switched on the fuel pump. Immediately lots of fuel gushed into the throat of the TBI. So it's getting plenty of gas to the injector. If I give it some ether, it will usually start, but I have to keep the throttle fairly wide open to run. It also will run fine once it "gets going". When I look inside the TBI when it is running, usually someone else has to press on the gas pedal to keep it running, I see gas dropping from injector, and swirling on the walls on the TBI. It appears its flooding out when trying to start, hence the hard starting, due to a bad injector not providing a misty fan spray to the TBI. It would also explain why going down the road there's no problem, because it can burn the excess fuel being delivered to it. Does this seem to make sense? With the injector installed, and by turning on the fuel pump, but not starting the engine, should you be able to see a fine misty spray inside the TBI coming from the injector?
#56 |
Re: missing
#57 |
Re: missing
Changing my fuel filter didn't help, but it was the cheapest possible solution, so it was worth trying. Over 488 miles I drove in about 2 weeks, I got 23.6 mpg. Is this good, bad, or normal? |
#58 |
Re: missing
Hey, I got my ole boy going! I feel embarrassed, but all it was, was the PLUGS! New plugs in, and he started right up. Stumbled a little, but as engine warmed up smoothed out. Drove him down the road, lots of power. I think now I'll do the rest of the tune-up. DUH. Sometimes we overlook the obvious, at least I do.
#59 |
Wire Splicin Fool :-)
Re: missing
An EP386 (AC Delco) pump on
#60 |
Re: missing
I do hope I don't need a new fuel pump. I haven't looked into my new problem again yet.
My EGR valve didn't show up today, (**** fedex) but now they say it will tomorrow. How should I hook up a fuel pressure gauge, and how much pressure should I have? Last edited by gregsz-28 : 11-04-2009 at 02:52 AM. |
#61 |
Re: missing
You will have to unhook the filter and hook up there or at TBI. |
#62 |
Re: missing
Today I received and replaced my EGR valve, and it still runs the same, ( ) but it still hasn't given me any codes.When I took the air cleaner off I noticed that it looked like smoke was coming out of the throttle body. Could that be a sign of the injector leaking? Or could it possibly be exhaust gas? My truck always has shut off a little rough, but I'm not sure if that is relevant. Another new problem: This started the other day. My blower motor usually doesn't work, but it will come on partly sometimes. I replaced the switch, and that didn't fix the problem, so I tested the voltage at the motor, and it was receiving 12 volts in every speed, except for off. It seems like it should be receiving less than 12 volts at lower speeds? And if the blower motor was the problem, wouldn't it not work all the time? Last edited by gregsz-28 : 11-05-2009 at 01:54 AM. Reason: spelling |
#63 |
Re: missing
Sounds like the blower motor is open, hence reading 12v. If you are curious, hook a headlight across the +/- on the blower contacts and try the settings, intensity should change.
Smoke is a byproduct of combustion, could be possibly normal, IDK I am not there. Hows the timing sitting? Fuel pressure yet? Last edited by lesterl : 11-05-2009 at 10:22 PM. |
#64 |
Re: missing
#65 |
Re: missing
#66 |
Re: missing
I'll try to remember to try the headlight thing tomorrow. I didn't check the fuel pressure or timing yet. What is the timing supposed to be set to? There's probably a sticker under my hood that says... |
#67 |
Re: missing
It now has 370000km and I put them all on. LOL.I had this same truck and motor in the hayday of mini trucks. Used to travel up and down the coast with a club called Low Altitude Minis and showed at NorthWest Mini Truck Council shows. Oh the memories. Last edited by bansheeair : 11-06-2009 at 12:02 PM. |
#68 |
Re: missing
Just now on my way home it gave me code 32 again.
Is it possible that my original problem and my hard to start problem are related, both being caused by a bad injector? Maybe I'll have time to test the fuel pressure tomorrow. |
#69 |
Re: missing
Did you buy a brand new AC Delco EGR valve for the right transmission? Is the truck still missing or whats it doing? Just hard to start might be a bad fuel pump relay Ive heard, as it will take a while before the oil pump builds up the 4psi it takes to turn on the fuel pump without the relay through the oil pressure switch. EGR needs to have the solenoid connected with the right valve installed. Is your code 32 consistant or does it come and go? |
#70 |
Re: missing
I'm not exactly sure what you're asking. I'll try to describe what happens exactly. After I first reset the code after I got it the first time, it took a lot of driving before it happened again. After the SES light comes on, it soon goes off, but the code is stored. Even though the code is stored the light won't come on while I'm driving after it happens once. |
#71 |
Re: missing
Some people talk about the code coming on and staying on making the truck run in OPEN LOOP therefore never running very good at all! I am just puzzled by your EGR solenoid operation. You said that you get FULL manifold vacuum through the EGR solenoid when the connector is plugged in and working even at idle. When the EGR solenoid is unplugged from the computer, it stops all EGR flow, because an idling motor should NOT have any EGR flow at all. HOW ON EARTH IS THAT POSSIBLE? WHY IS THIS EGR VALVE OPENING AT IDLE? What the hell is the EGR solenoids job if it is open at all times including cold idle? If the EGR valve is opening all the time, at idle, crusing, anytime the throttle plate is open, this is NOT THE WAY EGR's are supposed to work at all. It should only open on a part throttle cruise I thought??? |
#72 |
Re: missing
#73 |
Re: missing
Hmmm OK then, well if you have a fully working EGR system, with an AC Delco valve and solenoid it should be working as intended! The only things coming to mind is an older, slow reading O2 sensor that maybe is detecting changes slowly and when it tests and shows the reading is slow to the ecm, maybe thats is its part of the check???? The code is coming on when your ecm is checking the egr solenoid at part-throttle cruise at 40+MPH right? Not at idle... I have the exact same problem as you man. To the tee in my truck. I need to buy an EGR valve for mine but you have just spent $80 on one and it isnt fixing the problem. Thats why I really am interested and concerned here as I dont want to buy a damn valve and not have it work!!! |
#74 |
Re: missing
#75 |
Re: missing
Fuel Pump relay is on the fender next to another relay.
I would check fuel pressure and fuel spray from the injector, is base time at 8* |
#76 |
Re: missing
On Tuesday I tested the blower motor by hooking the wire to it up to a headlight, and I determined that the problem is the blower motor.
Haven't had time to do much else, been busy insulating the garage. It is cold this time of year! |
#77 |
Re: missing
The blower you might just try unplugging the connector at the motor a few times, or just wiggling it around, while you have it turned on so can hear if it starts.
#78 |
Re: missing
#79 |
Re: missing
today when I accelerated (trying to get into traffic, so 3/4+ throttle) and the truck was cold it would seem to miss/stumble at over 25 mph in 2nd gear. To me this would be another indication of a dying fuel pump. I still haven't tested my fuel pressure, because the other day when I was going to, I realized my fuel pressure gauge only goes to 10 psi. So, I think I'll just replace the fuel pump. It can't be that hard anyways. Tonight I'll order a new Delco fuel pump and a blower motor.
#80 |
Re: missing
#81 |
Re: missing
Oh and I am now getting 23.96 MPG. |
#82 |
Re: missing
I checked the timing today, and I wish I would have done that a lot sooner. It was set to 4* advanced, and I set it to 8* advanced. It runs noticeably better, but it still has that same miss.
#83 |
Re: missing
Pull the bed to replace the pump instead of dropping the tank, 6 large bolts and lift the bed off.
#84 |
Re: missing
Should I replace the flex lines between the tank lines and the body lines??, and what kind of hose is it, and how much do I need? Now my hard start problem only occurs sometimes, not sure why that would be because before it started being hard to start it never was, then for a while it was hard to start everytime I tried to start it, now it is only maybe once a day...My fuel pump should arrive tomorrow, and I don't have to work tomorrow, so guess what I'll be doing? Yesterday I replaced the blower motor and now it works perfectly! I bought one from Napa instead of ordering one, it was a little cheaper at Napa. |
#85 |
86, 2.5L, 4spd
Re: missing
Twenty years ain't bad, I've had mine for a tick over 15. Bought it used with 58000 on it for 4k back in 94, the thing was mint. I'm the third proud owner.
#86 |
Re: missing
Today I replaced my fuel pump, took about 1.5 hours.
I'm not sure if that fixed my hard to start problem, since it only does it sometimes now, but I'll post up in the next couple of days if it made a difference. It still has that miss though. |
#87 |
Re: missing
Secondly, have you replaced your fuel pump relay or checked it yet? It may be why your truck is hard to start because your oil pump has to build up 4psi of oil pressure from the starter turning until it kicks on the pump if the relay is dead. You will know if relay is dead cause it takes a lot longer to crank and start. |
#88 |
Sending Big Oil a Message
Location: The Great Pacific Northwet User is: OffLine |
Re: missing
Autolite AP666 from Walmart..they are platinum tipped and will last for many 10s of thousands of miles..best part is: they only cost about two bucks each. Gap 'em at 45 thou... ![]() BTW--I changed out my fuel pump relay and the old girl starts right up, usually on the first cylinder up on the compression stroke..a remarkable difference... These little motors LOVE a strong battery and GOOD grounds, they need both. And bad grounds and a weak(er) battery spell trouble. Last edited by Steady Eddie : 11-20-2009 at 09:48 PM. |
#89 |
Re: missing
Hows the compression?
