Can't find replacement pilot bearing... - S-10 Forum
post #1 of 14 Old 03-04-2009, 12:22 AM Thread Starter
User is: dads56 is offline
My son has '92 2wd, 2.5 with a 5 spd manual trans. He is doing an engine swap and can't find a correct pilot bearing. The OD of the pilot bearing specified by the books is too small. Any ideas?
dads56 is offline
post #2 of 14 Old 03-04-2009, 01:29 AM
Float like a butterfly
dimerunner88's Avatar
User is: dimerunner88 is offline
Send a message via AIM to dimerunner88 Send a message via MSN to dimerunner88
Re: Can't find replacement pilot bearing...
napa part number
Part: BRG B661
Clutch Pilot Bearing I.D. : .594"
Clutch Pilot Bearing O.D. : 1.093"
Clutch Pilot Bearing Width : .745"
Tom
1988 S-10 2.8/5-spd - scrapped
1992 k3500 CCLB
2002 blazer 4wd 5spd
post #3 of 14 Old 03-04-2009, 03:43 AM
User is: mobileaudio219 is offline
Is it a bearing or bushing?
Project Car Forum - Where Dream Cars Are Built!
Visit: http://projectcarforum.com
http://www.caraudiocentral.net/CAC_Mafia_Life/
post #4 of 14 Old 03-04-2009, 05:11 AM
User is: max1million is offline
A bushing is basically a type of bearing, especially in this case. Yeah just a small cylindrical lining or sleeve pressed into the end of crank. You can hydraulicly press it out. Pack it with grease and ram it out with a drift that just fits inside of it and hammer. If you don't have good size drift flip a sock on an extension backwards (or pack it too). Then clean grease out of crank and off flywheel. After you check new bushing on the tranny input shaft (snug fit, clutch kit can have a couple), press it into crank. Check the instructions, it may say to not grease the oil impregnated pilot bearing/bushing, or some such. I missed that, mine's greased full and done.
Just in case your thinking of the throw out bearing, it's a much larger bearing assembly. Probably pre packed and sealed (see instructions). But put a little grease on it and other wear points.
post #5 of 14 Old 03-04-2009, 11:23 PM
R/C Guru
92 s10 project's Avatar
User is: 92 s10 project is offline
Send a message via AIM to 92 s10 project
Make absolutely sure that you pick the right one the first time...when you dont have the means to use the above grease trick, cutting them out sucks the big one...
Jason
Black '92 S10, Reg Cab Short Bed, 2.5L w/ 5spd, lowered 2" on ZQ8's and a little this and that.
Looking for first gen bedrug...
post #6 of 14 Old 03-05-2009, 03:38 AM
A bearing is a bearing, a bushing is a bushing. A bearing spins, a bushing stays stationary. So no, a bushing isnt a type of bearing. In this case, they serve the same purpose, but do so in different ways.
I believe the s10's can potentially have a pilot shaft bushing OR bearing, depending on which manual transmission your truck has.
post #7 of 14 Old 03-05-2009, 09:42 PM
see 3a 3b bearing and a dime is a coin with a value of 1/10 of a dollar.
In my '92 2wd S10, 2.5 with a 5 spd manual trans, the pilot bearing is pressed into the end of crank.
post #8 of 14 Old 03-05-2009, 10:28 PM
considering it is being called a bearing i would assume its a bearing,they have a bushing listed aswell and its like $4 cheaper.
btw the truck came from the factory with a bushing but a bearing is offered to replace it along with bushing.
Tom
1992 k3500 CCLB
post #9 of 14 Old 03-05-2009, 11:52 PM
Do you know how many people call bushings, bearings?
I didnt know if he was looking for a bushing, but calling it a bearing. It happens, alot.
Go to the parts stores and have them show you the ones they have in stock, make sure it slids into the pilot shaft before tapping it in the crank.
post #10 of 14 Old 03-06-2009, 01:24 AM
The definitions of both (bearing/bushing) fit in this case, also Plain bearing, which are typically split. What ever you want to call it, the point is, it's referring to the same thing. If it's apart you might as well change it, its cheap insurance.
I'd suggest that you at least check it's inside diameter is somewhat close to the outside diameter of the shaft it is supposed to bear in the hole it is to bush. Mine was so worn that when I slid it on the tranny's input shaft it looked like the wrong part.
For a 1992 Chevrolet Truck S10 P/U 2WD (2.5L TBI)
Autozone has 2 listed in Shopping | Drivetrain |Clutch Pilot Bearing/Pilot Bushing:
Timken / Clutch Pilot Bearing/Pilot Bushing
PB656HD $11.99
Motormite / Clutch Pilot Bearing/Pilot Bushing
14650 $5.99
Guess they were confused too. They also list kit or set (same but not), and other parts for clutch in Drivetrain.
Somebody found out what happens when the pilot thing is gone.
post #11 of 14 Old 03-29-2009, 04:22 PM Thread Starter
napa part number
Part: BRG B661
Tom, I tried that bushing too. The O.D. id still too small for the crank. The ID of the crank hole is 1.170. The motor he is using came from the salvage yard. I'm wondering if the motor or crank came out of something else.
dads56 is offline
post #12 of 14 Old 04-03-2009, 05:26 PM
brakenit's Avatar
User is: brakenit is offline
Maybe the engine didn't come from an S10? Maybe it's from a car.
'04 Colorado - Bent-frame-arado
'91 S10 - The Bucket
'91 S10 - The Basket
'02 Silverado - Stockerado v2.0
brakenit is offline
post #13 of 14 Old 04-05-2009, 10:32 PM
ok, did the engine come from an automatic? the autos don't have the correct hole for the pilot bearing.
Tom
1992 k3500 CCLB
post #14 of 14 Old 04-13-2009, 11:14 AM Thread Starter
Tom, it may have came from an automatic truck. there was no tranny in the truck when he pulled the motor. Is there any other way to tell if it came from an automatic transmission vehicle? So the crank in an automatic transmission vehicle was a different crank? I have been thinking about turning a bushing on a lathe. Is there any other reason you would not want to use an automatic motor with a five speed? It seems like someone would make a bushing for the swap.
Dan
dads56 is offline
