can you pull the oil pan with engine in the truck - S-10 Forum
post #1 of 17 Old 08-09-2007, 10:02 PM Thread Starter
bender88's Avatar
User is: bender88 is offline
I am pretty sure I wiped a rod bearing, i need to see. Is it possible to remove the oil pan without pulling the engine or jacking it up.
bender88 is offline
post #2 of 17 Old 08-09-2007, 10:16 PM
Float like a butterfly
dimerunner88's Avatar
User is: dimerunner88 is offline
Send a message via AIM to dimerunner88 Send a message via MSN to dimerunner88
Re: can you pull the oil pan with engine in the truck
you need an engine hoist,just unbolt your motor mounts and lift the engine up until it starts lifting the truck. thats the only way you have enough room. i've had to replace a rod bearing this way, it works but its kinda difficult.
Tom
1988 S-10 2.8/5-spd - scrapped
1992 k3500 CCLB
2002 blazer 4wd 5spd
post #3 of 17 Old 08-09-2007, 10:20 PM Thread Starter
bender88's Avatar
thanks, ill look into it next week
bender88 is offline
post #4 of 17 Old 08-10-2007, 12:05 AM
good luck try not to drive it too long with the bad bearing, it'll tear up your crank surface and the new bearing will go out within minutes of start-up.
Tom
1992 k3500 CCLB
post #5 of 17 Old 08-10-2007, 02:12 AM Thread Starter
bender88's Avatar
I think I drove about 5 miles with it bad. I had the windows down and noticed a loss of power. I rolled them up and heard the knock, then I lost oil pressure, so I pulled over and got a tow back into town. I really want to do a v8 swap, but cant come up with the 4 grand right now.
bender88 is offline
post #6 of 17 Old 08-10-2007, 08:14 PM
that shouldn't be too bad then,just run your finger over it checking for sharp edges and burrs
Tom
1992 k3500 CCLB
post #7 of 17 Old 08-18-2007, 08:41 PM Thread Starter
bender88's Avatar
So I did manage to get the oil pan out, but I had to take out the oil pump and pickup tube, then remove my radiator and take it out the front. Its really tight in there. I am going to replace all four since I got the pan out, but I am concerned about getting a good seal on the pan. I am not sure if I should run a bead of atv on the block or the pan and if I should do it before or after I wiggle the pan back in there. My old s10 had the 2.8 and its pan had a cork style gasket. This one does not. I think I will go ahead and replace the forward and aft seals while its off.
bender88 is offline
post #8 of 17 Old 08-19-2007, 01:31 AM
ya, they don't use a gasket on the front or rear of the pans,the dumbest thing on these engines. when i did mine i put RTV on the block and the pan,just to be sure,lol. if you use too much it'll just come out when you change the oil. haha
Tom
1992 k3500 CCLB
post #9 of 17 Old 08-20-2007, 12:29 AM
Rarely goes over 20mph
beaniebmx's Avatar
User is: beaniebmx is offline
thats what i did with mine, most of it came out the sides and then i ran my finger along it to make sure its perfectly sealed, works like a charm
post #10 of 17 Old 08-22-2007, 03:09 AM Thread Starter
bender88's Avatar
Spent 5 hours under the truck tonight. Got all new bearings in and everything put back together. I am going to let the rtv cure over night then fill it with oil and see if i f'ed it up or not tomorrow. For some reason when I put the oil pan vack in, only one sides bolt holes lined up right. The others were only half lined up. It was a wicked pain in the ass to get the pan bolts back in. I used the black rtv and put two lines around it and around the bolt holes. Something I thought was weird was that the back drivers side of the pan doesn't seem to sit flush with the block. The block has a raised portion on that side in the back. I just hope if it leaks it wont leak too bad.
bender88 is offline
post #11 of 17 Old 08-22-2007, 09:54 AM
ya, that section is weird but i dunno. good luck
Tom
1992 k3500 CCLB
post #12 of 17 Old 08-23-2007, 09:53 PM Thread Starter
bender88's Avatar
Apparently I elongated my bearing journal because I still have the damn knock. I know it was the bearing cause that bitch was smashed out of the side. That rod cap was also particularly hard to get off. So, I guess its time to pull the plates and let her sit until I can afford my v8 swap. I'm not about to go through that again, as well as pulling the head to get the new rod in. At that point I may as well rebuild it and its a damn 2.5.
bender88 is offline
post #13 of 17 Old 08-23-2007, 10:16 PM
sucks man
Tom
1992 k3500 CCLB
post #14 of 17 Old 08-24-2007, 03:17 AM Thread Starter
bender88's Avatar
Yeah, your tellin me. I have not decided on a 4.3 or a v8 swap. I have always wanted a v8 s10 but I can get a complete 4.3 truck for 1500 and swap everything. Not sure what I should do.
bender88 is offline
post #15 of 17 Old 08-24-2007, 09:53 AM
you could do a carbed 4.3 so later on down the line a 350 will bolt right in with new mounts and exhaust
Tom
1992 k3500 CCLB
post #16 of 17 Old 08-24-2007, 03:53 PM Thread Starter
bender88's Avatar
I have been looking at doing a vortec 350 swap. I want to stay fuel injected and the vortec with FI should keep me in the 25mpg range. Im not going to race this truck, I just want to be able to do 70 on the freeway and pass a car.
bender88 is offline
post #17 of 17 Old 08-24-2007, 06:04 PM
if your going the FI route i would just do the 350 first since that what you'll ultimatly want. you can get a full harness from jared at current performance wiring for around $800. it may seem alot but its a plug and play harness no wire splicing involved. i recommend a manual trans like the nv3500 instead of an auto. i've went through several auto trans on my 350. i'm currently saving up to purchase a t-56 6-speed which runs around 1500 just for the trans.
Tom
1992 k3500 CCLB
